<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CS-USB-IMX307 Linux Error]]></title><description><![CDATA[<p dir="auto">使用在Ubuntu下, 系统可以检测摄像机设备，但它不能播放视频, 相机或驱动程序是否有问题？</p>
<p dir="auto">谢谢</p>
<p dir="auto">ffplay /dev/video0<br />
ffplay version 3.4.8-0ubuntu0.2 Copyright (c) 2003-2020 the FFmpeg developers<br />
built with gcc 7 (Ubuntu 7.5.0-3ubuntu1~18.04)<br />
configuration: --prefix=/usr --extra-version=0ubuntu0.2 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared<br />
libavutil      55. 78.100 / 55. 78.100<br />
libavcodec     57.107.100 / 57.107.100<br />
libavformat    57. 83.100 / 57. 83.100<br />
libavdevice    57. 10.100 / 57. 10.100<br />
libavfilter     6.107.100 /  6.107.100<br />
libavresample   3.  7.  0 /  3.  7.  0<br />
libswscale      4.  8.100 /  4.  8.100<br />
libswresample   2.  9.100 /  2.  9.100<br />
libpostproc    54.  7.100 / 54.  7.100<br />
nan    :  0.000 fd=   0 aq=    0KB vq=    0KB sq=    0B f=0/0<br />
nan    :  0.000 fd=   0 aq=    0KB vq=    0KB sq=    0B f=0/0</p>
<p dir="auto">============================================================================</p>
<p dir="auto">sudo v4l2-ctl -d /dev/video0 --all<br />
Driver Info (not using libv4l2):<br />
Driver name   : uvcvideo<br />
Card type     : CS-USB-IMX307: UVC Camera<br />
Bus info      : usb-0000:02:03.0-1<br />
Driver version: 4.18.20<br />
Capabilities  : 0x84A00001<br />
Video Capture<br />
Metadata Capture<br />
Streaming<br />
Extended Pix Format<br />
Device Capabilities<br />
Device Caps   : 0x04200001<br />
Video Capture<br />
Streaming<br />
Priority: 2<br />
Video input : 0 (Camera 1: ok)<br />
Format Video Capture:<br />
Width/Height      : 640/360<br />
Pixel Format      : 'YUYV'<br />
Field             : None<br />
Bytes per Line    : 1280<br />
Size Image        : 460800<br />
Colorspace        : Default<br />
Transfer Function : Default (maps to Rec. 709)<br />
YCbCr/HSV Encoding: Default (maps to ITU-R 601)<br />
Quantization      : Default (maps to Limited Range)<br />
Flags             :<br />
Crop Capability Video Capture:<br />
Bounds      : Left 0, Top 0, Width 640, Height 360<br />
Default     : Left 0, Top 0, Width 640, Height 360<br />
Pixel Aspect: 1/1<br />
Selection: crop_default, Left 0, Top 0, Width 640, Height 360<br />
Selection: crop_bounds, Left 0, Top 0, Width 640, Height 360<br />
Streaming Parameters Video Capture:<br />
Capabilities     : timeperframe<br />
Frames per second: 30.000 (30/1)<br />
Read buffers     : 0<br />
brightness 0x00980900 (int)    : min=0 max=100 step=1 default=50 value=50<br />
contrast 0x00980901 (int)    : min=0 max=100 step=1 default=50 value=50<br />
saturation 0x00980902 (int)    : min=0 max=100 step=1 default=50 value=50<br />
hue 0x00980903 (int)    : min=0 max=100 step=1 default=50 value=50<br />
error 5 getting ctrl White Balance Temperature, Auto</p>
]]></description><link>http://forum.veye.cc/topic/127/cs-usb-imx307-linux-error</link><generator>RSS for Node</generator><lastBuildDate>Fri, 04 Sep 2026 14:53:42 GMT</lastBuildDate><atom:link href="http://forum.veye.cc/topic/127.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 18 Aug 2021 03:55:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CS-USB-IMX307 Linux Error on Tue, 31 Aug 2021 01:26:12 GMT]]></title><description><![CDATA[<p dir="auto">客户已放弃此应用的研究。问题关闭。</p>
]]></description><link>http://forum.veye.cc/post/885</link><guid isPermaLink="true">http://forum.veye.cc/post/885</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Tue, 31 Aug 2021 01:26:12 GMT</pubDate></item><item><title><![CDATA[Reply to CS-USB-IMX307 Linux Error on Wed, 18 Aug 2021 04:29:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a></p>
<p dir="auto">是的, 在PC Ubuntu 或 STM32MP157C-DK2 板OpenSTLinux, 两者都失败了</p>
]]></description><link>http://forum.veye.cc/post/825</link><guid isPermaLink="true">http://forum.veye.cc/post/825</guid><dc:creator><![CDATA[patrick1957]]></dc:creator><pubDate>Wed, 18 Aug 2021 04:29:34 GMT</pubDate></item><item><title><![CDATA[Reply to CS-USB-IMX307 Linux Error on Wed, 18 Aug 2021 04:06:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/patrick1957" aria-label="Profile: patrick1957">@<bdi>patrick1957</bdi></a><br />
请问硬件是pc机吗？</p>
]]></description><link>http://forum.veye.cc/post/824</link><guid isPermaLink="true">http://forum.veye.cc/post/824</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Wed, 18 Aug 2021 04:06:52 GMT</pubDate></item></channel></rss>
