<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Adjust framerate and shutter speed separtly]]></title><description><![CDATA[<p dir="auto">Hello, is it possible to set separetly framerate and shutter speed ? When I set shutter speed it seems to erase my framerate settings and the same happens when I set framerate, it seems shutter speed setting is erased.<br />
Can you confirm and let me know if it is possible to keep the two settings ?<br />
I want to get the best light sensitivity possible, testing on VEYE 327 and 462.<br />
Thanks</p>
]]></description><link>http://forum.veye.cc/topic/156/adjust-framerate-and-shutter-speed-separtly</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 23:54:34 GMT</lastBuildDate><atom:link href="http://forum.veye.cc/topic/156.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 Sep 2021 21:15:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Adjust framerate and shutter speed separtly on Mon, 27 Sep 2021 01:12:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watchever" aria-label="Profile: watchever">@<bdi>watchever</bdi></a><br />
Sorry, this can not be modified. IMX307 is slightly worse than 327 low illumination, but the actual difference is not very large.</p>
]]></description><link>http://forum.veye.cc/post/989</link><guid isPermaLink="true">http://forum.veye.cc/post/989</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Mon, 27 Sep 2021 01:12:21 GMT</pubDate></item><item><title><![CDATA[Reply to Adjust framerate and shutter speed separtly on Sun, 26 Sep 2021 19:46:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> yes but CS series don't have same sensor and are not as sensitive as VEYE series (especially 462 and 327).<br />
Is it a material limit or could be solved by a development on your side : add a specific register to set framerate ? Thanks</p>
]]></description><link>http://forum.veye.cc/post/988</link><guid isPermaLink="true">http://forum.veye.cc/post/988</guid><dc:creator><![CDATA[watchever]]></dc:creator><pubDate>Sun, 26 Sep 2021 19:46:07 GMT</pubDate></item><item><title><![CDATA[Reply to Adjust framerate and shutter speed separtly on Sun, 26 Sep 2021 01:15:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watchever" aria-label="Profile: watchever">@<bdi>watchever</bdi></a> said in <a href="/post/981">Adjust framerate and shutter speed separtly</a>:</p>
<p dir="auto">I really need to reduce pixel refesh rate on the material side, is it possible ?</p>
<p dir="auto">It's not supported for VEYE series.<br />
CS series support this feature.</p>
]]></description><link>http://forum.veye.cc/post/985</link><guid isPermaLink="true">http://forum.veye.cc/post/985</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Sun, 26 Sep 2021 01:15:29 GMT</pubDate></item><item><title><![CDATA[Reply to Adjust framerate and shutter speed separtly on Fri, 24 Sep 2021 08:20:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> thanks, I really need to reduce pixel refesh rate on the material side, is it possible ?</p>
]]></description><link>http://forum.veye.cc/post/981</link><guid isPermaLink="true">http://forum.veye.cc/post/981</guid><dc:creator><![CDATA[watchever]]></dc:creator><pubDate>Fri, 24 Sep 2021 08:20:12 GMT</pubDate></item><item><title><![CDATA[Reply to Adjust framerate and shutter speed separtly on Fri, 24 Sep 2021 08:02:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watchever" aria-label="Profile: watchever">@<bdi>watchever</bdi></a> said in <a href="/post/978">Adjust framerate and shutter speed separtly</a>:</p>
<p dir="auto">Is there a way to fully deactivate the auto exposure algorithm ? I think when I manually set mshutter it it the case ?</p>
<p dir="auto">This statement is partially correct. The exposure time will be fully manual by setting mshutter, but gain is still automatic. You can set agc to 0 to force the automatic adjustment of gain to be turned off.</p>
]]></description><link>http://forum.veye.cc/post/980</link><guid isPermaLink="true">http://forum.veye.cc/post/980</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Fri, 24 Sep 2021 08:02:10 GMT</pubDate></item><item><title><![CDATA[Reply to Adjust framerate and shutter speed separtly on Fri, 24 Sep 2021 07:59:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watchever" aria-label="Profile: watchever">@<bdi>watchever</bdi></a></p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watchever" aria-label="Profile: watchever">@<bdi>watchever</bdi></a> said in <a href="/post/977">Adjust framerate and shutter speed separtly</a>:</p>
<p dir="auto">if I well understand nodf ignore some frames but not really reduce the material framerate. Am I wrong ?<br />
Thanks</p>
<p dir="auto">You are right.</p>
]]></description><link>http://forum.veye.cc/post/979</link><guid isPermaLink="true">http://forum.veye.cc/post/979</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Fri, 24 Sep 2021 07:59:13 GMT</pubDate></item><item><title><![CDATA[Reply to Adjust framerate and shutter speed separtly on Fri, 24 Sep 2021 07:17:10 GMT]]></title><description><![CDATA[<p dir="auto">Is there a way to fully deactivate the auto exposure algorithm ? I think when I manually set mshutter it it the case ?</p>
]]></description><link>http://forum.veye.cc/post/978</link><guid isPermaLink="true">http://forum.veye.cc/post/978</guid><dc:creator><![CDATA[watchever]]></dc:creator><pubDate>Fri, 24 Sep 2021 07:17:10 GMT</pubDate></item><item><title><![CDATA[Reply to Adjust framerate and shutter speed separtly on Fri, 24 Sep 2021 07:10:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> thanks, if I well understand nodf ignore some frames but not really reduce the material framerate. Am I wrong ?</p>
<p dir="auto">Thanks</p>
]]></description><link>http://forum.veye.cc/post/977</link><guid isPermaLink="true">http://forum.veye.cc/post/977</guid><dc:creator><![CDATA[watchever]]></dc:creator><pubDate>Fri, 24 Sep 2021 07:10:27 GMT</pubDate></item><item><title><![CDATA[Reply to Adjust framerate and shutter speed separtly on Fri, 24 Sep 2021 06:22:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watchever" aria-label="Profile: watchever">@<bdi>watchever</bdi></a></p>
<p dir="auto">I have to say <strong>lowlight</strong> is not a method to adjust framerate. It's a exposure time parameter.</p>
<p dir="auto">Note that the set value is the minimum frame rate value and the actual frame rate value is affected by the automatic exposure algorithm.</p>
<p dir="auto">If you want to <strong>drop</strong> some frames, try <strong>nodf</strong>.</p>
]]></description><link>http://forum.veye.cc/post/976</link><guid isPermaLink="true">http://forum.veye.cc/post/976</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Fri, 24 Sep 2021 06:22:00 GMT</pubDate></item><item><title><![CDATA[Reply to Adjust framerate and shutter speed separtly on Fri, 24 Sep 2021 05:53:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> I use mshutter for shutter speed and lowlight for framerate.</p>
]]></description><link>http://forum.veye.cc/post/975</link><guid isPermaLink="true">http://forum.veye.cc/post/975</guid><dc:creator><![CDATA[watchever]]></dc:creator><pubDate>Fri, 24 Sep 2021 05:53:17 GMT</pubDate></item><item><title><![CDATA[Reply to Adjust framerate and shutter speed separtly on Fri, 24 Sep 2021 01:26:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watchever" aria-label="Profile: watchever">@<bdi>watchever</bdi></a><br />
Please tell me which command you use to configure framerate and which command to configure shutter?</p>
]]></description><link>http://forum.veye.cc/post/974</link><guid isPermaLink="true">http://forum.veye.cc/post/974</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Fri, 24 Sep 2021 01:26:27 GMT</pubDate></item></channel></rss>
