<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is there 4 camera system for CS-FPD-CAM Series?]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I am interested in 4 camera system over FPD-Link III that would work with Jetson Nano, TX2, and ARM-based system (i.e. RK3399) such as ASUS Tinkerboard.</p>
<p dir="auto">Is there any VEYE product in CS-FPD-CAM series with that spec?</p>
<p dir="auto">Thanks.</p>
]]></description><link>http://forum.veye.cc/topic/219/is-there-4-camera-system-for-cs-fpd-cam-series</link><generator>RSS for Node</generator><lastBuildDate>Sun, 13 Sep 2026 20:10:18 GMT</lastBuildDate><atom:link href="http://forum.veye.cc/topic/219.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 25 Feb 2022 06:27:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is there 4 camera system for CS-FPD-CAM Series? on Tue, 22 Nov 2022 05:29:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sophiajackson22" aria-label="Profile: sophiajackson22">@<bdi>sophiajackson22</bdi></a> Thank you for the information, I will keep an eye on it.</p>
]]></description><link>http://forum.veye.cc/post/1936</link><guid isPermaLink="true">http://forum.veye.cc/post/1936</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Tue, 22 Nov 2022 05:29:59 GMT</pubDate></item><item><title><![CDATA[Reply to Is there 4 camera system for CS-FPD-CAM Series? on Fri, 18 Nov 2022 13:30:16 GMT]]></title><description><![CDATA[<p dir="auto">Hi, Did you check e-con Systems' FPD-Link camera? It has interesting features like Global shutter, onboard ISP, up to 15m coaxial cable support, and many more.</p>
<p dir="auto"><a href="https://www.e-consystems.com/nvidia-cameras/jetson-agx-orin-cameras/ar0234-global-shutter-fpd-link-iii-synchronized-multi-camera.asp" rel="nofollow ugc">https://www.e-consystems.com/nvidia-cameras/jetson-agx-orin-cameras/ar0234-global-shutter-fpd-link-iii-synchronized-multi-camera.asp</a></p>
]]></description><link>http://forum.veye.cc/post/1933</link><guid isPermaLink="true">http://forum.veye.cc/post/1933</guid><dc:creator><![CDATA[sophiajackson22]]></dc:creator><pubDate>Fri, 18 Nov 2022 13:30:16 GMT</pubDate></item><item><title><![CDATA[Reply to Is there 4 camera system for CS-FPD-CAM Series? on Wed, 02 Mar 2022 00:36:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/serene" aria-label="Profile: serene">@<bdi>serene</bdi></a><br />
Sorry, that was a mistake. CS-TX2-XAVIER-nCAM-IMX385 is designed only for TX2 and agx xavier.<br />
This kit takes VEYE-MIPI-IMX385 as its core and makes an adapter board, which supports many platforms.</p>
]]></description><link>http://forum.veye.cc/post/1401</link><guid isPermaLink="true">http://forum.veye.cc/post/1401</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Wed, 02 Mar 2022 00:36:26 GMT</pubDate></item><item><title><![CDATA[Reply to Is there 4 camera system for CS-FPD-CAM Series? on Tue, 01 Mar 2022 19:42:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a><br />
What I meant was, on that product description (CS-TX2-XAVIER-nCAM-IMX385), it says that it supports Raspberry Pi. But you mentioned that Raspberry Pi doesn't support 4 cameras.</p>
<p dir="auto">Could you clarify what it means?</p>
]]></description><link>http://forum.veye.cc/post/1399</link><guid isPermaLink="true">http://forum.veye.cc/post/1399</guid><dc:creator><![CDATA[serene]]></dc:creator><pubDate>Tue, 01 Mar 2022 19:42:39 GMT</pubDate></item><item><title><![CDATA[Reply to Is there 4 camera system for CS-FPD-CAM Series? on Tue, 01 Mar 2022 07:38:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/serene" aria-label="Profile: serene">@<bdi>serene</bdi></a><br />
Yes, this is our product.<br />
We don't have access to UCM-iMX8PLUS yet. imx8mplus is in the plan.</p>
]]></description><link>http://forum.veye.cc/post/1395</link><guid isPermaLink="true">http://forum.veye.cc/post/1395</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Tue, 01 Mar 2022 07:38:13 GMT</pubDate></item><item><title><![CDATA[Reply to Is there 4 camera system for CS-FPD-CAM Series? on Tue, 01 Mar 2022 00:53:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a><br />
Thank you.</p>
<p dir="auto">I found CS-TX2-XAVIER-nCAM-IMX385 in Amazon:<br />
<a href="https://www.amazon.com/CS-TX2-XAVIER-nCAM-IMX385-Jetson-Devkit-Xavier-YT1-0-5-1/dp/B09DB8786P/" rel="nofollow ugc">Amazon - CS-TX2-XAVIER-nCAM-IMX385</a></p>
<p dir="auto">On the description it says:<br />
"<em>Support Raspberry Pi Zero &amp; W,Pi 4,3 b+,Pi 3, Pi CM. Jetson Nano, Xavier NX.</em>"</p>
<p dir="auto">Btw, how about with UCM-iMX8PLUS that has <em>2x MIPI-CSI, 4 data lanes</em>?</p>
]]></description><link>http://forum.veye.cc/post/1390</link><guid isPermaLink="true">http://forum.veye.cc/post/1390</guid><dc:creator><![CDATA[serene]]></dc:creator><pubDate>Tue, 01 Mar 2022 00:53:00 GMT</pubDate></item><item><title><![CDATA[Reply to Is there 4 camera system for CS-FPD-CAM Series? on Tue, 01 Mar 2022 00:39:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/serene" aria-label="Profile: serene">@<bdi>serene</bdi></a><br />
Hello, I think this first depends on whether the motherboard support, rather than the camera can access.<br />
For example: Jetson,nano,imx8m,rk3399 and rpi, they do not support 4 mipi csi-2 interfaces.</p>
<p dir="auto">For TX2, yes.<br />
<a href="http://wiki.veye.cc/index.php/CS-TX2-XAVIER-nCAM_Series" rel="nofollow ugc">http://wiki.veye.cc/index.php/CS-TX2-XAVIER-nCAM_Series</a></p>
]]></description><link>http://forum.veye.cc/post/1389</link><guid isPermaLink="true">http://forum.veye.cc/post/1389</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Tue, 01 Mar 2022 00:39:06 GMT</pubDate></item><item><title><![CDATA[Reply to Is there 4 camera system for CS-FPD-CAM Series? on Mon, 28 Feb 2022 23:12:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a><br />
Thank you. How about MIPI CS-2?<br />
Do you have a set of breakout board with 4 cameras that is compatible with Jetson (Nano and TX2) and Raspberry Pi equivalent - i.e. ASUS Tinkerboard (RK3399) and NXP iMX8M SBC?</p>
]]></description><link>http://forum.veye.cc/post/1388</link><guid isPermaLink="true">http://forum.veye.cc/post/1388</guid><dc:creator><![CDATA[serene]]></dc:creator><pubDate>Mon, 28 Feb 2022 23:12:23 GMT</pubDate></item><item><title><![CDATA[Reply to Is there 4 camera system for CS-FPD-CAM Series? on Mon, 28 Feb 2022 00:35:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/serene" aria-label="Profile: serene">@<bdi>serene</bdi></a> We do not have GMSL2 products.</p>
]]></description><link>http://forum.veye.cc/post/1378</link><guid isPermaLink="true">http://forum.veye.cc/post/1378</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Mon, 28 Feb 2022 00:35:36 GMT</pubDate></item><item><title><![CDATA[Reply to Is there 4 camera system for CS-FPD-CAM Series? on Fri, 25 Feb 2022 18:56:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a><br />
Thank you for the prompt response.</p>
<p dir="auto">How about for GMSL2?</p>
]]></description><link>http://forum.veye.cc/post/1374</link><guid isPermaLink="true">http://forum.veye.cc/post/1374</guid><dc:creator><![CDATA[serene]]></dc:creator><pubDate>Fri, 25 Feb 2022 18:56:10 GMT</pubDate></item><item><title><![CDATA[Reply to Is there 4 camera system for CS-FPD-CAM Series? on Fri, 25 Feb 2022 07:09:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/serene" aria-label="Profile: serene">@<bdi>serene</bdi></a><br />
We are very sorry, fpdlink has been out of stock for a long time due to chip availability.</p>
]]></description><link>http://forum.veye.cc/post/1368</link><guid isPermaLink="true">http://forum.veye.cc/post/1368</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Fri, 25 Feb 2022 07:09:39 GMT</pubDate></item></channel></rss>
