<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[VEYE -MIPI-IMX462 - how to configure manual shutter&amp;gain]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I tried to follow the instructions for setting the manual gain and shutter by using the new manual exposure mode. Camera confirms that automatic exposure is not used, both new_mgain and new_mshutter are set.<br />
However, I can see that some autoexposure algorithm is still in effect, is there detailed guidance how the command sequence should look like?</p>
<p dir="auto">Milan</p>
]]></description><link>http://forum.veye.cc/topic/343/veye-mipi-imx462-how-to-configure-manual-shutter-gain</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 16:17:43 GMT</lastBuildDate><atom:link href="http://forum.veye.cc/topic/343.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 09 Feb 2023 11:00:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to VEYE -MIPI-IMX462 - how to configure manual shutter&amp;gain on Sun, 12 Feb 2023 00:58:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/milank" aria-label="Profile: milank">@<bdi>milank</bdi></a></p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/milank" aria-label="Profile: milank">@<bdi>milank</bdi></a> said in <a href="/post/2095">VEYE -MIPI-IMX462 - how to configure manual shutter&amp;gain</a>:</p>
<p dir="auto">I assume FW cannot be upgraded by the user, right?</p>
<p dir="auto">yes</p>
]]></description><link>http://forum.veye.cc/post/2099</link><guid isPermaLink="true">http://forum.veye.cc/post/2099</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Sun, 12 Feb 2023 00:58:09 GMT</pubDate></item><item><title><![CDATA[Reply to VEYE -MIPI-IMX462 - how to configure manual shutter&amp;gain on Fri, 10 Feb 2023 12:14:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a><br />
Yes, I got it now, no problem. Just ordered the correct one.<br />
]]></description><link>http://forum.veye.cc/post/2095</link><guid isPermaLink="true">http://forum.veye.cc/post/2095</guid><dc:creator><![CDATA[milank]]></dc:creator><pubDate>Fri, 10 Feb 2023 12:14:13 GMT</pubDate></item><item><title><![CDATA[Reply to VEYE -MIPI-IMX462 - how to configure manual shutter&amp;gain on Fri, 10 Feb 2023 06:51:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/milank" aria-label="Profile: milank">@<bdi>milank</bdi></a> Sorry this place is not expressed very clearly. This refers to the firmware version of the camera.</p>
]]></description><link>http://forum.veye.cc/post/2094</link><guid isPermaLink="true">http://forum.veye.cc/post/2094</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Fri, 10 Feb 2023 06:51:20 GMT</pubDate></item><item><title><![CDATA[Reply to VEYE -MIPI-IMX462 - how to configure manual shutter&amp;gain on Fri, 10 Feb 2023 06:48:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a></p>
<p dir="auto">I understood that this is <a href="http://i2c.sh" rel="nofollow ugc">i2c.sh</a> release version, not the HW version.</p>
<p dir="auto">This maybe needs to be mentioned more explicitelly, to be clear.<br />
This explains the camera behaviour.<br />
Maybe that the script could find out the hw version itself and report if not as expected?<br />
Thank you, anyway.</p>
]]></description><link>http://forum.veye.cc/post/2093</link><guid isPermaLink="true">http://forum.veye.cc/post/2093</guid><dc:creator><![CDATA[milank]]></dc:creator><pubDate>Fri, 10 Feb 2023 06:48:43 GMT</pubDate></item><item><title><![CDATA[Reply to VEYE -MIPI-IMX462 - how to configure manual shutter&amp;gain on Fri, 10 Feb 2023 01:09:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/milank" aria-label="Profile: milank">@<bdi>milank</bdi></a> said in <a href="/post/2088">VEYE -MIPI-IMX462 - how to configure manual shutter&amp;gain</a>:</p>
<p dir="auto">videoformat</p>
<ol>
<li>Please check hdver first.<br />
<a href="http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/#new_expmode" rel="nofollow ugc">http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/#new_expmode</a></li>
</ol>
<pre><code>The following new features are only supported in versions with release time later than 2022-11-22.
<ol start="2">
<li>Do not set 'brightness ' if you want to use manual mode.</li>
<li>Pls read those params  and check it.</li>
</ol>
]]></description><link>http://forum.veye.cc/post/2092</link><guid isPermaLink="true">http://forum.veye.cc/post/2092</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Fri, 10 Feb 2023 01:09:41 GMT</pubDate></item><item><title><![CDATA[Reply to VEYE -MIPI-IMX462 - how to configure manual shutter&amp;gain on Thu, 09 Feb 2023 15:27:23 GMT]]></title><description><![CDATA[<p dir="auto">Currently, I am using the script like:</p>
<p dir="auto">./veye_mipi_i2c.sh -w -f videoformat -p1 PAL<br />
sleep 1<br />
./veye_mipi_i2c.sh -w -f new_expmode -p1 1<br />
sleep 1<br />
./veye_mipi_i2c.sh -w -f new_mshutter -p1 40000 # fixed 40 ms<br />
sleep 1<br />
./veye_mipi_i2c.sh -w -f new_mgain -p1 10<br />
sleep 1<br />
./veye_mipi_i2c.sh -w -f brightness -p1 0x07<br />
sleep 1<br />
./veye_mipi_i2c.sh -w -f contrast -p1 0xa0<br />
sleep 1<br />
./veye_mipi_i2c.sh -w -f paramsave</p>
]]></description><link>http://forum.veye.cc/post/2088</link><guid isPermaLink="true">http://forum.veye.cc/post/2088</guid><dc:creator><![CDATA[milank]]></dc:creator><pubDate>Thu, 09 Feb 2023 15:27:23 GMT</pubDate></item></channel></rss>
