<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[veye_mvcam: disagrees about version of symbol module_layout]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1676254546863-f50b54a5-ad69-432e-908c-d66e74865b18-image-resized.png" alt="f50b54a5-ad69-432e-908c-d66e74865b18-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">根据此处的教程而来，最后一步检查系统状态时候和教程结果不一致。<br />
相机是MV-MIPI-SC130M。<br />
内核版本<br />
Linux raspberrypi 5.15.61-v8+ #1579 SMP PREEMPT Fri Aug 26 11:16:44 BST 2022 aarch64 GNU/Linux</p>
]]></description><link>http://forum.veye.cc/topic/345/veye_mvcam-disagrees-about-version-of-symbol-module_layout</link><generator>RSS for Node</generator><lastBuildDate>Fri, 04 Sep 2026 22:40:07 GMT</lastBuildDate><atom:link href="http://forum.veye.cc/topic/345.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Feb 2023 02:17:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to veye_mvcam: disagrees about version of symbol module_layout on Mon, 13 Feb 2023 09:22:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> 感谢</p>
]]></description><link>http://forum.veye.cc/post/2118</link><guid isPermaLink="true">http://forum.veye.cc/post/2118</guid><dc:creator><![CDATA[ff1211]]></dc:creator><pubDate>Mon, 13 Feb 2023 09:22:37 GMT</pubDate></item><item><title><![CDATA[Reply to veye_mvcam: disagrees about version of symbol module_layout on Mon, 13 Feb 2023 09:17:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ff1211" aria-label="Profile: ff1211">@<bdi>ff1211</bdi></a> 没问题，搞定了。</p>
]]></description><link>http://forum.veye.cc/post/2116</link><guid isPermaLink="true">http://forum.veye.cc/post/2116</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Mon, 13 Feb 2023 09:17:41 GMT</pubDate></item><item><title><![CDATA[Reply to veye_mvcam: disagrees about version of symbol module_layout on Mon, 13 Feb 2023 08:28:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> 您好，我重新编译之后，显示这个，正常了吗？<br />
[    8.164689] veye_mvcam: loading out-of-tree module taints kernel.<br />
[    8.859832] mvcam 10-003b: camera is: MV-MIPI-SC130M<br />
[    8.861876] mvcam 10-003b: firmware version: 0x1260132<br />
[    8.882341] mvcam 10-003b: Consider updating driver mvcam to match on endpoints</p>
]]></description><link>http://forum.veye.cc/post/2115</link><guid isPermaLink="true">http://forum.veye.cc/post/2115</guid><dc:creator><![CDATA[ff1211]]></dc:creator><pubDate>Mon, 13 Feb 2023 08:28:22 GMT</pubDate></item><item><title><![CDATA[Reply to veye_mvcam: disagrees about version of symbol module_layout on Mon, 13 Feb 2023 07:05:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ff1211" aria-label="Profile: ff1211">@<bdi>ff1211</bdi></a> 树莓派应该是i2c10吧</p>
]]></description><link>http://forum.veye.cc/post/2113</link><guid isPermaLink="true">http://forum.veye.cc/post/2113</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Mon, 13 Feb 2023 07:05:20 GMT</pubDate></item><item><title><![CDATA[Reply to veye_mvcam: disagrees about version of symbol module_layout on Mon, 13 Feb 2023 06:17:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> 您好，我尝试了下检测iic接口，输入 i2cdetect -y 1后显示的都是横线，网上说是没有检测到iic设备，是不是因为这个原因？排线没有接好或者还需要单独接iic线吗？</p>
]]></description><link>http://forum.veye.cc/post/2112</link><guid isPermaLink="true">http://forum.veye.cc/post/2112</guid><dc:creator><![CDATA[ff1211]]></dc:creator><pubDate>Mon, 13 Feb 2023 06:17:05 GMT</pubDate></item><item><title><![CDATA[Reply to veye_mvcam: disagrees about version of symbol module_layout on Mon, 13 Feb 2023 06:05:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> 我试下</p>
]]></description><link>http://forum.veye.cc/post/2111</link><guid isPermaLink="true">http://forum.veye.cc/post/2111</guid><dc:creator><![CDATA[ff1211]]></dc:creator><pubDate>Mon, 13 Feb 2023 06:05:05 GMT</pubDate></item><item><title><![CDATA[Reply to veye_mvcam: disagrees about version of symbol module_layout on Mon, 13 Feb 2023 06:02:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ff1211" aria-label="Profile: ff1211">@<bdi>ff1211</bdi></a> said in <a href="/post/2109">veye_mvcam: disagrees about version of symbol module_layout</a>:</p>
<p dir="auto">disagrees about version of symbol module_layout</p>
<p dir="auto">建议你参考这个文章，重新编译驱动，然后安装一下。<br />
<a href="http://wiki.veye.cc/index.php/Build_drivers_from_source_for_rpi/zh" rel="nofollow ugc">http://wiki.veye.cc/index.php/Build_drivers_from_source_for_rpi/zh</a></p>
]]></description><link>http://forum.veye.cc/post/2110</link><guid isPermaLink="true">http://forum.veye.cc/post/2110</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Mon, 13 Feb 2023 06:02:38 GMT</pubDate></item><item><title><![CDATA[Reply to veye_mvcam: disagrees about version of symbol module_layout on Mon, 13 Feb 2023 05:58:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> said in <a href="/post/2106">veye_mvcam: disagrees about version of symbol module_layout</a>:</p>
<p dir="auto">dmesg | grep mvcam</p>
<p dir="auto">[    6.743382] veye_mvcam: disagrees about version of symbol module_layout<br />
[    6.835960] veye_mvcam: disagrees about version of symbol module_layout<br />
[    6.880028] veye_mvcam: disagrees about version of symbol module_layout</p>
]]></description><link>http://forum.veye.cc/post/2109</link><guid isPermaLink="true">http://forum.veye.cc/post/2109</guid><dc:creator><![CDATA[ff1211]]></dc:creator><pubDate>Mon, 13 Feb 2023 05:58:53 GMT</pubDate></item><item><title><![CDATA[Reply to veye_mvcam: disagrees about version of symbol module_layout on Mon, 13 Feb 2023 05:58:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ff1211" aria-label="Profile: ff1211">@<bdi>ff1211</bdi></a><br />
<a href="https://github.com/veyeimaging/mvcam_raspberrypi" rel="nofollow ugc">https://github.com/veyeimaging/mvcam_raspberrypi</a></p>
]]></description><link>http://forum.veye.cc/post/2108</link><guid isPermaLink="true">http://forum.veye.cc/post/2108</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Mon, 13 Feb 2023 05:58:46 GMT</pubDate></item><item><title><![CDATA[Reply to veye_mvcam: disagrees about version of symbol module_layout on Mon, 13 Feb 2023 05:56:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> 还想问下mv_mipi_i2c.sh这个文件在哪，我在你们git仓库里没搜索到。</p>
]]></description><link>http://forum.veye.cc/post/2107</link><guid isPermaLink="true">http://forum.veye.cc/post/2107</guid><dc:creator><![CDATA[ff1211]]></dc:creator><pubDate>Mon, 13 Feb 2023 05:56:43 GMT</pubDate></item><item><title><![CDATA[Reply to veye_mvcam: disagrees about version of symbol module_layout on Mon, 13 Feb 2023 05:56:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ff1211" aria-label="Profile: ff1211">@<bdi>ff1211</bdi></a><br />
下面这个命令输出得到什么结果？</p>
<pre><code>dmesg | grep mvcam
]]></description><link>http://forum.veye.cc/post/2106</link><guid isPermaLink="true">http://forum.veye.cc/post/2106</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Mon, 13 Feb 2023 05:56:25 GMT</pubDate></item><item><title><![CDATA[Reply to veye_mvcam: disagrees about version of symbol module_layout on Mon, 13 Feb 2023 05:49:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> 输入v4l2-ctl --list-formats-ext后，得到Cannot open device /dev/video0, exiting.</p>
]]></description><link>http://forum.veye.cc/post/2105</link><guid isPermaLink="true">http://forum.veye.cc/post/2105</guid><dc:creator><![CDATA[ff1211]]></dc:creator><pubDate>Mon, 13 Feb 2023 05:49:26 GMT</pubDate></item><item><title><![CDATA[Reply to veye_mvcam: disagrees about version of symbol module_layout on Mon, 13 Feb 2023 03:33:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ff1211" aria-label="Profile: ff1211">@<bdi>ff1211</bdi></a><br />
这个提示可以忽略。 你插好camera，注意一下ffc cable的方向。 然后继续往下走走看。</p>
]]></description><link>http://forum.veye.cc/post/2104</link><guid isPermaLink="true">http://forum.veye.cc/post/2104</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Mon, 13 Feb 2023 03:33:27 GMT</pubDate></item></channel></rss>
