<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Read MV-MIPI-SC130M with openCV]]></title><description><![CDATA[<p dir="auto">我尝试使用三个v4l2_opencv_show.py示例读取相机视频流，然而均无法打开摄像头，使用的是cv2.vedioCapture()方法：</p>
<pre><code>cap = cv2.VideoCapture("v4l2src io-mode=dmabuf device=/dev/video0 ! video/x-raw, format=(string)GREY, width=(int)1280, height=(int)1024 ! appsink")
<p dir="auto">SC130M支持GREY、Y10等格式，但V4L2的x-raw并不支持，我尝试使用cv2.vedioCapture(0)、缺省format参数，x-raw支持的format=GRAY8进行读取，但是结果显示</p>
<pre><code>[ WARN:0] global ../modules/videoio/src/cap_gstreamer.cpp (1824) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module v4l2src0 reported: Device '/dev/video0' does not support 1:4:7:1 colorimetry
<p dir="auto">我也尝试使用相机支持的GREY进行读取，但是gstreamer无法识别：</p>
<pre><code>[ WARN:0] global ../modules/videoio/src/cap_gstreamer.cpp (734) open OpenCV | GStreamer warning: Error opening bin: could not link v4l2src0 to appsink0, v4l2src0 can't handle caps video/x-raw, format=(string)GREY, width=(int)1280, height=(int)1024
[ WARN:0] global ../modules/videoio/src/cap_gstreamer.cpp (501) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
camera open failed
]]></description><link>http://forum.veye.cc/topic/350/read-mv-mipi-sc130m-with-opencv</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 15:28:29 GMT</lastBuildDate><atom:link href="http://forum.veye.cc/topic/350.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 15 Feb 2023 07:08:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Read MV-MIPI-SC130M with openCV on Thu, 23 Feb 2023 02:33:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> 能否提供一些在python或是c/c++中可用的读取接口或程序示例，我需要一个确定可用的程序对摄像头进行功能测试，最好能兼容opencv和gstreamer</p>
]]></description><link>http://forum.veye.cc/post/2194</link><guid isPermaLink="true">http://forum.veye.cc/post/2194</guid><dc:creator><![CDATA[skyhorizon]]></dc:creator><pubDate>Thu, 23 Feb 2023 02:33:31 GMT</pubDate></item><item><title><![CDATA[Reply to Read MV-MIPI-SC130M with openCV on Tue, 21 Feb 2023 03:13:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skyhorizon" aria-label="Profile: skyhorizon">@<bdi>skyhorizon</bdi></a><br />
请参考以下这个回复<br />
<a href="http://forum.veye.cc/topic/304/%E6%B1%82%E5%8A%A9%E6%A0%91%E8%8E%93%E6%B4%BEmv-mipi-imx178m-%E4%BD%BF%E7%94%A8python%E8%B0%83%E7%94%A8cv2-videocapture%E6%98%BE%E7%A4%BAcan-t-open-camera-by-index/2">http://forum.veye.cc/topic/304/求助树莓派mv-mipi-imx178m-使用python调用cv2-videocapture显示can-t-open-camera-by-index/2</a></p>
]]></description><link>http://forum.veye.cc/post/2182</link><guid isPermaLink="true">http://forum.veye.cc/post/2182</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Tue, 21 Feb 2023 03:13:15 GMT</pubDate></item><item><title><![CDATA[Reply to Read MV-MIPI-SC130M with openCV on Thu, 16 Feb 2023 06:54:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skyhorizon" aria-label="Profile: skyhorizon">@<bdi>skyhorizon</bdi></a> 硬件平台是RPI 4B</p>
]]></description><link>http://forum.veye.cc/post/2140</link><guid isPermaLink="true">http://forum.veye.cc/post/2140</guid><dc:creator><![CDATA[skyhorizon]]></dc:creator><pubDate>Thu, 16 Feb 2023 06:54:04 GMT</pubDate></item><item><title><![CDATA[Reply to Read MV-MIPI-SC130M with openCV on Thu, 16 Feb 2023 06:50:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> <img src="/assets/uploads/files/1676529793394-a6d6c694-11aa-4fac-ac25-82bb547656f6-image.png" alt="a6d6c694-11aa-4fac-ac25-82bb547656f6-image.png" class=" img-fluid img-markdown" /><br />
RPI OS 5.15.84 驱动是本地编译的5.15_all。</p>
<pre><code>v4l2-ctl -d /dev/video0 --all
Driver Info:
	Driver name      : unicam
	Card type        : unicam
	Bus info         : platform:fe801000.csi
	Driver version   : 5.15.84
	Capabilities     : 0x85a00001
		Video Capture
		Metadata Capture
		Read/Write
		Streaming
		Extended Pix Format
		Device Capabilities
	Device Caps      : 0x05200001
		Video Capture
		Read/Write
		Streaming
		Extended Pix Format
Media Driver Info:
	Model            : unicam
	Serial           :
	Media version    : 5.15.84
	Hardware revision: 0x00000000 (0)
Interface Info:
	Type             : V4L Video
Entity Info:
	Function         : V4L2 I/O
	Flags         : default
	Pad 0x01000004   : 0: Sink
	  Link 0x02000007: from remote pad 0x1000002 of entity 'mvcam 10-003b': Data, Enabled, Immutable
Priority: 2
Video input : 0 (Camera 0: ok)
Format Video Capture:
	Width/Height      : 1280/1024
	Pixel Format      : 'GREY' (8-bit Greyscale)
	Field             : None
	Bytes per Line    : 1280
	Size Image        : 1310720
	Colorspace        : sRGB
	Transfer Function : Default (maps to sRGB)
	YCbCr/HSV Encoding: Default (maps to ITU-R 601)
	Quantization      : Default (maps to Full Range)
	Flags             :
Crop Capability Video Capture:
	Bounds      : Left 0, Top 0, Width 1280, Height 1024
	Default     : Left 0, Top 0, Width 1280, Height 1024
	Pixel Aspect: 1/1
Selection Video Capture: crop, Left 0, Top 0, Width 1280, Height 1024, Flags:
Selection Video Capture: crop_default, Left 0, Top 0, Width 1280, Height 1024, Flags:
Selection Video Capture: crop_bounds, Left 0, Top 0, Width 1280, Height 1024, Flags:
Selection Video Capture: native_size, Left 0, Top 0, Width 1280, Height 1024, Flags:
User Controls
                horizontal_flip 0x00980914 (bool)   : default=0 value=0
                  vertical_flip 0x00980915 (bool)   : default=0 value=0
                   trigger_mode 0x00981901 (int)    : min=0 max=2 step=1 default=0 value=0 flags=volatile, execute-on-write
                    trigger_src 0x00981902 (int)    : min=0 max=1 step=1 default=1 value=1 flags=volatile, execute-on-write
                    soft_trgone 0x00981903 (button) : flags=write-only, execute-on-write
                     frame_rate 0x00981904 (int)    : min=0 max=22 step=1 default=22 value=22 flags=volatile, execute-on-write
Camera Controls
         camera_sensor_rotation 0x009a0923 (int)    : min=0 max=0 step=1 default=0 value=0 flags=read-only
Image Processing Controls
                     pixel_rate 0x009f0902 (int64)  : min=750000000 max=750000000 step=1 default=750000000 value=750000000 flags=read-only
<pre><code>~ $ dmesg | grep mvcam
[    8.132715] veye_mvcam: loading out-of-tree module taints kernel.
[    8.648215] mvcam 10-003b: camera is: MV-MIPI-SC130M
[    8.649037] mvcam 10-003b: firmware version: 0x1260132
[    8.657495] mvcam 10-003b: Consider updating driver mvcam to match on endpoints
]]></description><link>http://forum.veye.cc/post/2139</link><guid isPermaLink="true">http://forum.veye.cc/post/2139</guid><dc:creator><![CDATA[skyhorizon]]></dc:creator><pubDate>Thu, 16 Feb 2023 06:50:16 GMT</pubDate></item><item><title><![CDATA[Reply to Read MV-MIPI-SC130M with openCV on Wed, 15 Feb 2023 09:34:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skyhorizon" aria-label="Profile: skyhorizon">@<bdi>skyhorizon</bdi></a> 你使用的主板是什么？ 运行环境是什么版本？</p>
]]></description><link>http://forum.veye.cc/post/2138</link><guid isPermaLink="true">http://forum.veye.cc/post/2138</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Wed, 15 Feb 2023 09:34:43 GMT</pubDate></item></channel></rss>
