<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error installing driver V4L2 on raspberry pi]]></title><description><![CDATA[<h2>Good day,<br />
during install on Raspberry pi 4 8GB I get the following error:<br />
pi@raspberrypi:~/raspberrypi_v4l2/release $ sudo ./install_driver.sh csimx307</h2>
<h2>usage: sudo ./install_driver.sh veye327/csimx307/cssc132</h2>
<h2>Enable i2c0 adapter...</h2>
<h2>Add dtoverlay=csimx307 to /boot/config.txt</h2>
<h2>Add gpu=400M to /boot/config.txt<br />
Add cma=128M to /boot/cmdline.txt</h2>
<h2>Installing the csimx307.ko driver</h2>
<p dir="auto">install: cannot stat './driver_bin/5.10.17-v7l+/csimx307.ko': No such file or directory<br />
install: cannot stat './driver_bin/5.10.17-v7l+/csimx307.dtbo': No such file or directory</p>
<p dir="auto">Any Idea how to solve?</p>
]]></description><link>http://forum.veye.cc/topic/37/error-installing-driver-v4l2-on-raspberry-pi</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 16:18:56 GMT</lastBuildDate><atom:link href="http://forum.veye.cc/topic/37.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 11 Apr 2021 20:21:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error installing driver V4L2 on raspberry pi on Fri, 30 Apr 2021 11:45:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a><br />
Problem solved, this topic can be closed.<br />
Thx!</p>
]]></description><link>http://forum.veye.cc/post/399</link><guid isPermaLink="true">http://forum.veye.cc/post/399</guid><dc:creator><![CDATA[MK]]></dc:creator><pubDate>Fri, 30 Apr 2021 11:45:17 GMT</pubDate></item><item><title><![CDATA[Reply to Error installing driver V4L2 on raspberry pi on Wed, 21 Apr 2021 01:05:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tj" aria-label="Profile: tj">@<bdi>tj</bdi></a> Thank you very much, I will merge you commit.</p>
]]></description><link>http://forum.veye.cc/post/316</link><guid isPermaLink="true">http://forum.veye.cc/post/316</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Wed, 21 Apr 2021 01:05:05 GMT</pubDate></item><item><title><![CDATA[Reply to Error installing driver V4L2 on raspberry pi on Tue, 20 Apr 2021 18:08:04 GMT]]></title><description><![CDATA[<p dir="auto">I created a pull request with the new drivers: <a href="https://github.com/veyeimaging/raspberrypi_v4l2/pull/6" rel="nofollow ugc">https://github.com/veyeimaging/raspberrypi_v4l2/pull/6</a></p>
]]></description><link>http://forum.veye.cc/post/313</link><guid isPermaLink="true">http://forum.veye.cc/post/313</guid><dc:creator><![CDATA[tj]]></dc:creator><pubDate>Tue, 20 Apr 2021 18:08:04 GMT</pubDate></item><item><title><![CDATA[Reply to Error installing driver V4L2 on raspberry pi on Tue, 20 Apr 2021 12:11:27 GMT]]></title><description><![CDATA[<p dir="auto">I'm trying to do this (compiling now). I found the wiki a bit hard to follow. In step 8.6 (Add compilation options), it says 'the path is driver --&gt; multimedia --&gt; i2C', however for me it was 'Device Drivers --&gt; Multimedia Support --&gt; Media ancillary drivers --&gt; Camera sensor devices --&gt; '</p>
]]></description><link>http://forum.veye.cc/post/310</link><guid isPermaLink="true">http://forum.veye.cc/post/310</guid><dc:creator><![CDATA[tj]]></dc:creator><pubDate>Tue, 20 Apr 2021 12:11:27 GMT</pubDate></item><item><title><![CDATA[Reply to Error installing driver V4L2 on raspberry pi on Mon, 12 Apr 2021 00:44:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mk" aria-label="Profile: mk">@<bdi>mk</bdi></a><br />
There are really too many kernel versions of raspberry pie. We have not provided the compiled ko file for your version of kernel, could you please compile it according to the code?</p>
]]></description><link>http://forum.veye.cc/post/220</link><guid isPermaLink="true">http://forum.veye.cc/post/220</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Mon, 12 Apr 2021 00:44:57 GMT</pubDate></item></channel></rss>
