<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[相机抓图相关问题]]></title><description><![CDATA[<p dir="auto">我尝试做转接板让edge2开发板支持raw-mipi-sc132m相机。<br />
编译好驱动后，更改设备树如下：</p>
<pre><code>// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
	vcc_mipidphy0: vcc-mipidcphy0-regulator {//cam2-sc132m
		status = "okay";
		compatible = "regulator-fixed";
		gpio = &lt;&amp;gpio1 RK_PB2 GPIO_ACTIVE_HIGH&gt;;
		pinctrl-names = "default";
		pinctrl-0 = &lt;&amp;mipidphy0_pwr&gt;;
		regulator-name = "vcc_mipidphy0";
		enable-active-high;
		regulator-always-on;
&amp;csi2_dcphy0 {//cam2
	status = "okay";
	ports {
		#address-cells = &lt;1&gt;;
		#size-cells = &lt;0&gt;;
		port@0 {
			reg = &lt;0&gt;;
			mipi_in_dcphy0: endpoint@1 {
				reg = &lt;1&gt;;
				remote-endpoint = &lt;&amp;mvcam_out0&gt;;
				data-lanes = &lt;1 2&gt;;
		port@1 {
			reg = &lt;1&gt;;
			csidcphy0_out: endpoint@0 {
				reg = &lt;0&gt;;
				remote-endpoint = &lt;&amp;mipi0_csi2_input&gt;;
&amp;mipi_dcphy0 {
	status = "okay";
&amp;csi2_dcphy1 {//cam1
	status = "okay";
	ports {
		port@0 {
			reg = &lt;0&gt;;
			mipi_in_dcphy1: endpoint@1 {
				reg = &lt;1&gt;;
				remote-endpoint = &lt;&amp;imx415f_out1&gt;;
				data-lanes = &lt;1 2 3 4&gt;;
		port@1 {
			reg = &lt;1&gt;;
			csidcphy1_out: endpoint@0 {
				reg = &lt;0&gt;;
				remote-endpoint = &lt;&amp;mipi1_csi2_input&gt;;
&amp;mipi_dcphy1 {
	status = "okay";
&amp;csi2_dphy0 {//cam3
	status = "okay";
	ports {
		port@0 {
			reg = &lt;0&gt;;
			mipidphy0_in_ucam0: endpoint@1 {
				reg = &lt;1&gt;;
				remote-endpoint = &lt;&amp;imx415c_out0&gt;;
		port@1 {
			reg = &lt;1&gt;;
			csidphy0_out: endpoint@0 {
				reg = &lt;0&gt;;
				remote-endpoint = &lt;&amp;mipi2_csi2_input&gt;;
&amp;csi2_dphy0_hw {
	status = "okay";
&amp;i2c4 {//cam2
	status = "okay";
	pinctrl-0 = &lt;&amp;i2c4m3_xfer&gt;;
	dw9714b: dw9714b@c {
		compatible = "dongwoon,dw9714";
		status = "disable";
		reg = &lt;0x0c&gt;;
		pinctrl-names = "focusb_gpios";
		pinctrl-0 = &lt;&amp;focusb_gpio&gt;;
		focus-gpios = &lt;&amp;gpio1 RK_PA0 GPIO_ACTIVE_HIGH&gt;;
		rockchip,vcm-start-current = &lt;20&gt;;
		rockchip,vcm-rated-current = &lt;76&gt;;
		rockchip,vcm-step-mode = &lt;0&gt;;
		rockchip,camera-module-index = &lt;0&gt;;
	imx415b: imx415b@1a {
		compatible = "sony,imx415";
		status = "disable";
		reg = &lt;0x1a&gt;;
		clocks = &lt;&amp;cru CLK_MIPI_CAMARAOUT_M1&gt;;
		clock-names = "xvclk";
		power-domains = &lt;&amp;power RK3588_PD_VI&gt;;
		pinctrl-names = "default", "camb_gpios";
		pinctrl-0 = &lt;&amp;mipim1_camera1_clk&gt;, &lt;&amp;camb_gpio&gt;;
		rockchip,grf = &lt;&amp;sys_grf&gt;;
		reset-gpios = &lt;&amp;gpio1 RK_PB2 GPIO_ACTIVE_LOW&gt;;
		pwdn-gpios = &lt;&amp;gpio1 RK_PB3 GPIO_ACTIVE_HIGH&gt;;
		rockchip,camera-module-name = "CMK-OT2022-PX1";
		rockchip,camera-module-lens-name = "IR0147-50IRC-8M-F20";
		lens-focus = &lt;&amp;dw9714b&gt;;
		port {
			imx415b_out0: endpoint {
				remote-endpoint = &lt;&amp;mipi_in_dcphy0&gt;;
	mvcam: mvcam@3b{
        compatible = "veye,mvcam";
		status = "okay";
        reg = &lt;0x3b&gt;;
        pinctrl-0 = &lt;&amp;mipim1_camera1_clk&gt;;
        //power-gpios = &lt;&amp;gpio1 RK_PC4 GPIO_ACTIVE_LOW&gt;;
        reset-gpios = &lt;&amp;gpio3 RK_PA6 GPIO_ACTIVE_HIGH&gt;;//用原来的19和20引脚，SC132M似乎不需要考虑这两个引脚
        //avdd-supply = &lt;&amp;vcc_mipidcphy0&gt;;
        //firefly,clkout-enabled-index = &lt;0&gt;;
        port {
            mvcam_out0: endpoint {
&amp;i2c3 {//cam1
	status = "okay";
	pinctrl-0 = &lt;&amp;i2c3m0_xfer&gt;;
	dw9714f: dw9714f@c {
		status = "okay";
		reg = &lt;0x0c&gt;;
		pinctrl-names = "focusf_gpios";
		pinctrl-0 = &lt;&amp;focusf_gpio&gt;;
		focus-gpios = &lt;&amp;gpio1 RK_PA1 GPIO_ACTIVE_HIGH&gt;;
		rockchip,camera-module-index = &lt;1&gt;;
		rockchip,camera-module-facing = "front";
	imx415f: imx415f@1a {
		status = "okay";
		reg = &lt;0x1a&gt;;
		clocks = &lt;&amp;cru CLK_MIPI_CAMARAOUT_M2&gt;;
		pinctrl-names = "default", "camf_gpios";
		pinctrl-0 = &lt;&amp;mipim1_camera2_clk&gt;, &lt;&amp;camf_gpio&gt;;
		reset-gpios = &lt;&amp;gpio3 RK_PC6 GPIO_ACTIVE_LOW&gt;;
		pwdn-gpios = &lt;&amp;gpio3 RK_PC5 GPIO_ACTIVE_HIGH&gt;;
		lens-focus = &lt;&amp;dw9714f&gt;;
		port {
			imx415f_out1: endpoint {
				remote-endpoint = &lt;&amp;mipi_in_dcphy1&gt;;
&amp;i2c8 {//cam3
	status = "okay";
	pinctrl-0 = &lt;&amp;i2c8m2_xfer&gt;;
	dw9714c: dw9714c@c {
		status = "okay";
		reg = &lt;0x0c&gt;;
		pinctrl-names = "focusc_gpios";
		pinctrl-0 = &lt;&amp;focusc_gpio&gt;;
		focus-gpios = &lt;&amp;gpio1 RK_PA6 GPIO_ACTIVE_HIGH&gt;;
	imx415: imx415@1a {
		reg = &lt;0x1a&gt;;
		clocks = &lt;&amp;cru CLK_MIPI_CAMARAOUT_M3&gt;;
		pinctrl-names = "default", "camc_gpios";
		pinctrl-0 = &lt;&amp;mipim1_camera3_clk&gt;, &lt;&amp;camc_gpio&gt;;
		reset-gpios = &lt;&amp;gpio3 RK_PB4 GPIO_ACTIVE_LOW&gt;;
		pwdn-gpios = &lt;&amp;gpio1 RK_PA4 GPIO_ACTIVE_HIGH&gt;;
		lens-focus = &lt;&amp;dw9714c&gt;;
		port {
			imx415c_out0: endpoint {
				remote-endpoint = &lt;&amp;mipidphy0_in_ucam0&gt;;
&amp;pinctrl {
	cam {
		mipidphy0_pwr: mipidphy0-pwr {
			rockchip,pins =
				/* camera power en */
				&lt;1 RK_PB2 RK_FUNC_GPIO &amp;pcfg_output_high&gt;;
		camf_gpio: camf-gpio {//imx415
			rockchip,pins =
				&lt;3 RK_PC6 RK_FUNC_GPIO &amp;pcfg_pull_none&gt;,
				&lt;3 RK_PC5 RK_FUNC_GPIO &amp;pcfg_pull_none&gt;;
		camb_gpio: camb-gpio {//imx415
			rockchip,pins =
				&lt;1 RK_PB2 RK_FUNC_GPIO &amp;pcfg_pull_none&gt;,
				&lt;1 RK_PB3 RK_FUNC_GPIO &amp;pcfg_pull_none&gt;;
		camc_gpio: camc-gpio {//imx415
			rockchip,pins =
				&lt;3 RK_PB4 RK_FUNC_GPIO &amp;pcfg_pull_none&gt;,
				&lt;1 RK_PA4 RK_FUNC_GPIO &amp;pcfg_pull_none&gt;;
		focusb_gpio: focusb-gpio {//dw9714
			rockchip,pins =
				&lt;1 RK_PA0 RK_FUNC_GPIO &amp;pcfg_pull_none&gt;;
		focusf_gpio: focusf-gpio {//dw9714
			rockchip,pins =
				&lt;1 RK_PA1 RK_FUNC_GPIO &amp;pcfg_pull_none&gt;;
		focusc_gpio: focusc-gpio {//dw9714
			rockchip,pins =
				&lt;1 RK_PA6 RK_FUNC_GPIO &amp;pcfg_pull_none&gt;;
&amp;mipi0_csi2 {//cam2
	status = "okay";
	ports {
		port@0 {
			reg = &lt;0&gt;;
			mipi0_csi2_input: endpoint@1 {
				reg = &lt;1&gt;;
				remote-endpoint = &lt;&amp;csidcphy0_out&gt;;
		port@1 {
			reg = &lt;1&gt;;
			mipi0_csi2_output: endpoint@0 {
				reg = &lt;0&gt;;
				remote-endpoint = &lt;&amp;cif_mipi_in0&gt;;
&amp;mipi1_csi2 {//cam1
	status = "okay";
	ports {
		port@0 {
			reg = &lt;0&gt;;
			mipi1_csi2_input: endpoint@1 {
				reg = &lt;1&gt;;
				remote-endpoint = &lt;&amp;csidcphy1_out&gt;;
		port@1 {
			reg = &lt;1&gt;;
			mipi1_csi2_output: endpoint@0 {
				reg = &lt;0&gt;;
				remote-endpoint = &lt;&amp;cif_mipi_in1&gt;;
&amp;mipi2_csi2 {//cam3
	status = "okay";
	ports {
		port@0 {
			reg = &lt;0&gt;;
			mipi2_csi2_input: endpoint@1 {
				reg = &lt;1&gt;;
				remote-endpoint = &lt;&amp;csidphy0_out&gt;;
		port@1 {
			reg = &lt;1&gt;;
			mipi2_csi2_output: endpoint@0 {
				reg = &lt;0&gt;;
				remote-endpoint = &lt;&amp;cif_mipi2_in0&gt;;
&amp;rkcif {
	status = "okay";
&amp;rkcif_mipi_lvds {
	status = "okay";
	port {
		cif_mipi_in0: endpoint {
			remote-endpoint = &lt;&amp;mipi0_csi2_output&gt;;
&amp;rkcif_mipi_lvds_sditf {
	status = "okay";
	port {
		mipi_lvds_sditf: endpoint {
			remote-endpoint = &lt;&amp;isp0_vir0&gt;;
&amp;rkcif_mipi_lvds1 {
	status = "okay";
	port {
		cif_mipi_in1: endpoint {
			remote-endpoint = &lt;&amp;mipi1_csi2_output&gt;;
&amp;rkcif_mipi_lvds1_sditf {
	status = "okay";
	port {
		mipi1_lvds_sditf: endpoint {
			remote-endpoint = &lt;&amp;isp0_vir1&gt;;
&amp;rkcif_mipi_lvds2 {
	status = "okay";
	port {
		cif_mipi2_in0: endpoint {
			remote-endpoint = &lt;&amp;mipi2_csi2_output&gt;;
&amp;rkcif_mipi_lvds2_sditf {
	status = "okay";
	port {
		mipi_lvds2_sditf: endpoint {
			remote-endpoint = &lt;&amp;isp1_vir0&gt;;
&amp;rkcif_mmu {
	status = "okay";
&amp;rkisp0 {
	status = "okay";
&amp;isp0_mmu {
	status = "okay";
&amp;rkisp0_vir0 {
	status = "okay";
	port {
		isp0_vir0: endpoint@0 {
			reg = &lt;0&gt;;
			remote-endpoint = &lt;&amp;mipi_lvds_sditf&gt;;
&amp;rkisp0_vir1 {
	status = "okay";
	port {
		isp0_vir1: endpoint@0 {
			reg = &lt;0&gt;;
			remote-endpoint = &lt;&amp;mipi1_lvds_sditf&gt;;
&amp;rkisp1 {
	status = "okay";
&amp;isp1_mmu {
	status = "okay";
&amp;rkisp1_vir0 {
	status = "okay";
	port {
		isp1_vir0: endpoint@0 {
			reg = &lt;0&gt;;
			remote-endpoint = &lt;&amp;mipi_lvds2_sditf&gt;;
<p dir="auto">开发板能够识别到相机：</p>
<pre><code>[   10.868932] mvcam 4-003b: veye mv series camera driver version: 01.01.04
[   11.872574] mvcam 4-003b: camera is: RAW-MIPI-SC132M
[   11.873598] mvcam 4-003b: firmware version: 0x1040000
[   11.877481] mvcam 4-003b: mvcam_get_mipifeature: lane num 2, datarate 1500000000 bps
[   11.877588] mvcam 4-003b: Success to get mvcam endpoint data lanes, dts uses 2 lanes
[   11.891182] mvcam 4-003b: mvcam_enum_controls success
<p dir="auto">但是使用命令</p>
<pre><code>v4l2-ctl -d /dev/video0 --set-fmt-video=width=1080,height=1280,pixelformat=GREY --stream-mmap --stream-count=1 --stream-to=y8-1088x1280.raw
<p dir="auto">会报错：</p>
<pre><code>[ 2912.107051] rkcif-mipi-lvds: ERROR: csi size err, intstat:0x1000000, lastline:0!!
<p dir="auto">之后我通过v4l2-ctl -L命令发现：</p>
<pre><code>[ 3120.790050] rockchip-csi2-dphy csi2-dcphy0: csi2_dphy_update_sensor_mbus fail to get dphy param, used default value
<p dir="auto">我不知道哪里出现了问题，请问我该如何排查？</p>
]]></description><link>http://forum.veye.cc/topic/465/相机抓图相关问题</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 14:53:42 GMT</lastBuildDate><atom:link href="http://forum.veye.cc/topic/465.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 25 Oct 2023 06:56:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 相机抓图相关问题 on Fri, 27 Oct 2023 08:23:51 GMT]]></title><description><![CDATA[<p dir="auto">已私信。已私信。</p>
]]></description><link>http://forum.veye.cc/post/3093</link><guid isPermaLink="true">http://forum.veye.cc/post/3093</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Fri, 27 Oct 2023 08:23:51 GMT</pubDate></item><item><title><![CDATA[Reply to 相机抓图相关问题 on Thu, 26 Oct 2023 08:39:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> 地址是什么？</p>
]]></description><link>http://forum.veye.cc/post/3091</link><guid isPermaLink="true">http://forum.veye.cc/post/3091</guid><dc:creator><![CDATA[潘阳刚]]></dc:creator><pubDate>Thu, 26 Oct 2023 08:39:09 GMT</pubDate></item><item><title><![CDATA[Reply to 相机抓图相关问题 on Thu, 26 Oct 2023 08:37:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/%E6%BD%98%E9%98%B3%E5%88%9A" aria-label="Profile: 潘阳刚">@<bdi>潘阳刚</bdi></a> 整体上我看你的操作没有太大问题。 现在不出图，不太清楚是咋回事。 要不你把板子寄过来，我们给看一下吧。</p>
]]></description><link>http://forum.veye.cc/post/3089</link><guid isPermaLink="true">http://forum.veye.cc/post/3089</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Thu, 26 Oct 2023 08:37:59 GMT</pubDate></item><item><title><![CDATA[Reply to 相机抓图相关问题 on Thu, 26 Oct 2023 06:08:00 GMT]]></title><description><![CDATA[<p dir="auto"><a href="/assets/uploads/files/1698300416071-capture.txt">capture.txt</a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> 我没有直接替换，原始文件和您给我的文件只有如下几处不一样，我进行了修改：<br />
<img src="/assets/uploads/files/1698291300792-a2.png" alt="A2.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1698291300750-a1.png" alt="A1.png" class=" img-fluid img-markdown" /><br />
绿色的几行本不在原始文件中。<br />
其他有区别但是我未作改动的：<br />
<img src="/assets/uploads/files/1698300215754-a4.png" alt="A4.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1698300215713-a3.png" alt="A3.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">其他的都一致。现在的问题有没有可能是转接板PCB设计不恰当导致的？<br />
<a href="/assets/uploads/files/1698300463398-capture.txt">capture.txt</a></p>
]]></description><link>http://forum.veye.cc/post/3087</link><guid isPermaLink="true">http://forum.veye.cc/post/3087</guid><dc:creator><![CDATA[潘阳刚]]></dc:creator><pubDate>Thu, 26 Oct 2023 06:08:00 GMT</pubDate></item><item><title><![CDATA[Reply to 相机抓图相关问题 on Thu, 26 Oct 2023 02:23:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/%E6%BD%98%E9%98%B3%E5%88%9A" aria-label="Profile: 潘阳刚">@<bdi>潘阳刚</bdi></a> 感觉你现在问题更麻烦了。 上次给你的文件，不能直接替换掉，你从中把关于数据类型的几个地方修改到原来edge2的源码中即可。</p>
]]></description><link>http://forum.veye.cc/post/3086</link><guid isPermaLink="true">http://forum.veye.cc/post/3086</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Thu, 26 Oct 2023 02:23:28 GMT</pubDate></item><item><title><![CDATA[Reply to 相机抓图相关问题 on Thu, 26 Oct 2023 02:07:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a>  确实缺少支持，我修改了这个文件。重新烧录镜像之后再次尝试，现在的log是这样的：</p>
[ 1189.005947] rockchip-csi2-dphy csi2-dcphy0: csi2_dphy_update_sensor_mbus fail to get dphy param, used default value
[ 1189.009415] rockchip-csi2-dphy csi2-dcphy0: csi2_dphy_update_sensor_mbus fail to get dphy param, used default value
[ 1189.009978] rockchip-mipi-csi2 fdd10000.mipi0-csi2: stream on, src_sd: 000000002ff232b9, sd_name:rockchip-csi2-dphy0
[ 1189.010005] rockchip-mipi-csi2 fdd10000.mipi0-csi2: stream ON
[ 1189.010037] rockchip-csi2-dphy csi2-dcphy0: csi2_dphy_update_sensor_mbus fail to get dphy param, used default value
[ 1189.010057] rockchip-csi2-dphy csi2-dcphy0: csi2_dphy_update_sensor_mbus fail to get dphy param, used default value
[ 1189.010084] rockchip-csi2-dphy csi2-dcphy0: csi2_dphy_update_sensor_mbus fail to get dphy param, used default value
&lt;[ 1189.032767] rockchip-mipi-csi2 fdd10000.mipi0-csi2: stream off, src_sd: 000000002ff232b9, sd_name:rockchip-csi2-dphy0
[ 1189.032803] rockchip-mipi-csi2 fdd10000.mipi0-csi2: stream OFF
<p dir="auto">还是没能获取到图像数据。</p>
]]></description><link>http://forum.veye.cc/post/3085</link><guid isPermaLink="true">http://forum.veye.cc/post/3085</guid><dc:creator><![CDATA[潘阳刚]]></dc:creator><pubDate>Thu, 26 Oct 2023 02:07:59 GMT</pubDate></item><item><title><![CDATA[Reply to 相机抓图相关问题 on Wed, 25 Oct 2023 08:40:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/%E6%BD%98%E9%98%B3%E5%88%9A" aria-label="Profile: 潘阳刚">@<bdi>潘阳刚</bdi></a> 这个问题有可能是edge2的linux kernel 源码缺少一些对数据格式的支持。<br />
kernel\drivers\media\platform\rockchip\cif\capture.c<br />
附件这份代码，你聊做参考。<br />
<a href="/assets/uploads/files/1698223203778-capture.c.txt">capture.c.txt</a></p>
]]></description><link>http://forum.veye.cc/post/3083</link><guid isPermaLink="true">http://forum.veye.cc/post/3083</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Wed, 25 Oct 2023 08:40:05 GMT</pubDate></item></channel></rss>
