<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[3588修改行对齐]]></title><description><![CDATA[<p dir="auto">roc-rk3588s-pc中支持修改ar0234m相机的bytes per line 参数吗？</p>
]]></description><link>http://forum.veye.cc/topic/544/3588修改行对齐</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 18:16:37 GMT</lastBuildDate><atom:link href="http://forum.veye.cc/topic/544.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 16 Jan 2024 07:24:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 3588修改行对齐 on Thu, 18 Jan 2024 00:10:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> 好的，谢谢</p>
]]></description><link>http://forum.veye.cc/post/3680</link><guid isPermaLink="true">http://forum.veye.cc/post/3680</guid><dc:creator><![CDATA[lin]]></dc:creator><pubDate>Thu, 18 Jan 2024 00:10:49 GMT</pubDate></item><item><title><![CDATA[Reply to 3588修改行对齐 on Wed, 17 Jan 2024 09:51:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lin" aria-label="Profile: lin">@<bdi>lin</bdi></a> 我理解这个Bytes per Line是rkcif驱动里面，自动根据camera的分辨率计算的，没有留v4l-ctl进行配置的接口。如果要改动，需要修改一下rockchip的rkcif源码。rk这么做的目的应该是出于整个系统一些硬件模块操作的方便性。<br />
暂时建议你保留这个状况，你的程序处理的时候忽略掉多余的部分。</p>
]]></description><link>http://forum.veye.cc/post/3679</link><guid isPermaLink="true">http://forum.veye.cc/post/3679</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Wed, 17 Jan 2024 09:51:30 GMT</pubDate></item><item><title><![CDATA[Reply to 3588修改行对齐 on Wed, 17 Jan 2024 09:13:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lin" aria-label="Profile: lin">@<bdi>lin</bdi></a> 确实有这个现象。回头我研究一下是怎么回事。</p>
]]></description><link>http://forum.veye.cc/post/3678</link><guid isPermaLink="true">http://forum.veye.cc/post/3678</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Wed, 17 Jan 2024 09:13:59 GMT</pubDate></item><item><title><![CDATA[Reply to 3588修改行对齐 on Wed, 17 Jan 2024 08:03:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> 2457600字节，我算过1200行，每行是2048</p>
]]></description><link>http://forum.veye.cc/post/3677</link><guid isPermaLink="true">http://forum.veye.cc/post/3677</guid><dc:creator><![CDATA[lin]]></dc:creator><pubDate>Wed, 17 Jan 2024 08:03:09 GMT</pubDate></item><item><title><![CDATA[Reply to 3588修改行对齐 on Wed, 17 Jan 2024 07:59:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lin" aria-label="Profile: lin">@<bdi>lin</bdi></a> 你可以看看具体的大小，精确到字节。 1920*1200=2304000bytes</p>
]]></description><link>http://forum.veye.cc/post/3676</link><guid isPermaLink="true">http://forum.veye.cc/post/3676</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Wed, 17 Jan 2024 07:59:14 GMT</pubDate></item><item><title><![CDATA[Reply to 3588修改行对齐 on Wed, 17 Jan 2024 07:58:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> 2.34M</p>
]]></description><link>http://forum.veye.cc/post/3675</link><guid isPermaLink="true">http://forum.veye.cc/post/3675</guid><dc:creator><![CDATA[lin]]></dc:creator><pubDate>Wed, 17 Jan 2024 07:58:25 GMT</pubDate></item><item><title><![CDATA[Reply to 3588修改行对齐 on Wed, 17 Jan 2024 07:53:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lin" aria-label="Profile: lin">@<bdi>lin</bdi></a> 文件大小是多少？</p>
]]></description><link>http://forum.veye.cc/post/3674</link><guid isPermaLink="true">http://forum.veye.cc/post/3674</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Wed, 17 Jan 2024 07:53:25 GMT</pubDate></item><item><title><![CDATA[Reply to 3588修改行对齐 on Wed, 17 Jan 2024 07:52:38 GMT]]></title><description><![CDATA[<p dir="auto">@veye_xumm还是有黑边呀？</p>
]]></description><link>http://forum.veye.cc/post/3673</link><guid isPermaLink="true">http://forum.veye.cc/post/3673</guid><dc:creator><![CDATA[lin]]></dc:creator><pubDate>Wed, 17 Jan 2024 07:52:38 GMT</pubDate></item><item><title><![CDATA[Reply to 3588修改行对齐 on Wed, 17 Jan 2024 01:19:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lin" aria-label="Profile: lin">@<bdi>lin</bdi></a><br />
试试下面这个脚本</p>
<pre><code>export WIDTH=1920
export HEIGHT=1200
export FPS=60
v4l2-ctl -d /dev/v4l-subdev2 --set-ctrl roi_x=0
v4l2-ctl -d /dev/v4l-subdev2 --set-ctrl roi_y=0
media-ctl -d /dev/media0 --set-v4l2 '"m00_b_mvcam 7-003b":0[fmt:Y8_1X8/'"$WIDTH"'x'"$HEIGHT"'@1/'"$FPS"']'
v4l2-ctl -d /dev/video0 --set-fmt-video=width=$WIDTH,height=$HEIGHT,pixelformat=GREY --stream-mmap --stream-count=1 --stream-to=y8-${WIDTH}x${HEIGHT}.raw
]]></description><link>http://forum.veye.cc/post/3663</link><guid isPermaLink="true">http://forum.veye.cc/post/3663</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Wed, 17 Jan 2024 01:19:23 GMT</pubDate></item><item><title><![CDATA[Reply to 3588修改行对齐 on Wed, 17 Jan 2024 01:16:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> 为什么用python预览图像就没有黑边，自己采集保存出来图像就有黑边了，我的图像分辨率为1920*1200,v4l2-ctl -all查看bytes per line 参数是2048，有办法去掉黑边吗？</p>
]]></description><link>http://forum.veye.cc/post/3662</link><guid isPermaLink="true">http://forum.veye.cc/post/3662</guid><dc:creator><![CDATA[lin]]></dc:creator><pubDate>Wed, 17 Jan 2024 01:16:40 GMT</pubDate></item><item><title><![CDATA[Reply to 3588修改行对齐 on Wed, 17 Jan 2024 00:55:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lin" aria-label="Profile: lin">@<bdi>lin</bdi></a> 这个我们没有试过。正常来说bytes per line应该是跟随相机的roi自适应的吧？</p>
]]></description><link>http://forum.veye.cc/post/3661</link><guid isPermaLink="true">http://forum.veye.cc/post/3661</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Wed, 17 Jan 2024 00:55:17 GMT</pubDate></item></channel></rss>
