<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to set exposure for IMX-287M?]]></title><description><![CDATA[<p dir="auto">How do I set the exposure for the IMX-287M?</p>
<p dir="auto">I don't find anything about exposure here: <a href="https://wiki.veye.cc/index.php/Mv_series_camera_appnotes_4_rpi" rel="nofollow ugc">https://wiki.veye.cc/index.php/Mv_series_camera_appnotes_4_rpi</a></p>
<p dir="auto">I also tried:</p>
<p dir="auto">v4l2-ctl  --set-ctrl exposure=10000  -d /dev/v4l-subdev2</p>
<p dir="auto">but it says:</p>
<p dir="auto">unknown control 'exposure'</p>
<p dir="auto">Maybe there's a media-ctl command?</p>
<p dir="auto">I'm on the Raspberry Pi 5 on Bookworm with kernel 6.1.0-rpi7-rpi-2712</p>
]]></description><link>http://forum.veye.cc/topic/550/how-to-set-exposure-for-imx-287m</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 22:28:06 GMT</lastBuildDate><atom:link href="http://forum.veye.cc/topic/550.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 24 Jan 2024 23:38:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to set exposure for IMX-287M? on Thu, 25 Jan 2024 06:03:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/etale_cohomology" aria-label="Profile: etale_cohomology">@<bdi>etale_cohomology</bdi></a> said in <a href="/post/3765">How to set exposure for IMX-287M?</a>:</p>
<p dir="auto">It turns out you must manually select the I2C bus number (I also enabled I2C on raspi-config). Since I'm using CAM0 on RPI5, the bus is 6. Example:<br />
./mv_mipi_i2c.sh -r -f manufacturer -b 6<br />
This works.</p>
<p dir="auto">Yes</p>
]]></description><link>http://forum.veye.cc/post/3770</link><guid isPermaLink="true">http://forum.veye.cc/post/3770</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Thu, 25 Jan 2024 06:03:34 GMT</pubDate></item><item><title><![CDATA[Reply to How to set exposure for IMX-287M? on Thu, 25 Jan 2024 05:14:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/etale_cohomology" aria-label="Profile: etale_cohomology">@<bdi>etale_cohomology</bdi></a></p>
<p dir="auto">I think something is still missing, because I still can't run ./mv_mipi_i2c.sh successfully.</p>
<p dir="auto">For example,</p>
<p dir="auto">./mv_mipi_i2c.sh -r -f manufacturer</p>
<p dir="auto">returns</p>
<p dir="auto">Manufacturer        0 not recognized</p>
<p dir="auto">./mv_mipi_i2c.sh -r -f model</p>
<p dir="auto">model        0 not recognized</p>
<hr />
<p dir="auto">EDIT</p>
<p dir="auto">It turns out you must manually select the I2C bus number (I also enabled I2C on raspi-config). Since I'm using CAM0 on RPI5, the bus is 6. Example:</p>
<p dir="auto">./mv_mipi_i2c.sh -r -f manufacturer -b 6</p>
<p dir="auto">This works.</p>
]]></description><link>http://forum.veye.cc/post/3765</link><guid isPermaLink="true">http://forum.veye.cc/post/3765</guid><dc:creator><![CDATA[etale_cohomology]]></dc:creator><pubDate>Thu, 25 Jan 2024 05:14:12 GMT</pubDate></item><item><title><![CDATA[Reply to How to set exposure for IMX-287M? on Thu, 25 Jan 2024 03:25:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/etale_cohomology" aria-label="Profile: etale_cohomology">@<bdi>etale_cohomology</bdi></a><br />
Sorry for not being clear, v4l2 mode does not need to execute camera_i2c_config</p>
]]></description><link>http://forum.veye.cc/post/3764</link><guid isPermaLink="true">http://forum.veye.cc/post/3764</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Thu, 25 Jan 2024 03:25:15 GMT</pubDate></item><item><title><![CDATA[Reply to How to set exposure for IMX-287M? on Thu, 25 Jan 2024 02:24:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a></p>
<p dir="auto">Thank you for your reply.</p>
<p dir="auto">I'm using the files here:</p>
<p dir="auto"><a href="https://github.com/veyeimaging/mvcam_raspberrypi/tree/392451009cc93cfd56bd3c0096c329e7a429f6f8/mv_tools_rpi" rel="nofollow ugc">https://github.com/veyeimaging/mvcam_raspberrypi/tree/392451009cc93cfd56bd3c0096c329e7a429f6f8/mv_tools_rpi</a></p>
<p dir="auto">and, according to the docs, before running mv_mipi_i2c.sh I must run</p>
<p dir="auto">./enable_i2c_vc.sh<br />
./camera_i2c_config</p>
<p dir="auto">but ./camera_i2c_config is failing with:</p>
<p dir="auto">setting GPIO for board revsion: d04170<br />
Failed: don't know how to set GPIO for this board! Type is 17<br />
Use i2c-10 for the sensor (-y 10)</p>
<p dir="auto">(I'm running a Raspberry Pi 5.)</p>
<p dir="auto">I also tried the files here: <a href="https://github.com/veyeimaging/raspberrypi_v4l2/tree/c782fc464d76c5ed2a7f8f31df72eaaa51e0dceb/mv_tools_rpi" rel="nofollow ugc">https://github.com/veyeimaging/raspberrypi_v4l2/tree/c782fc464d76c5ed2a7f8f31df72eaaa51e0dceb/mv_tools_rpi</a><br />
but same error.</p>
]]></description><link>http://forum.veye.cc/post/3763</link><guid isPermaLink="true">http://forum.veye.cc/post/3763</guid><dc:creator><![CDATA[etale_cohomology]]></dc:creator><pubDate>Thu, 25 Jan 2024 02:24:32 GMT</pubDate></item><item><title><![CDATA[Reply to How to set exposure for IMX-287M? on Thu, 25 Jan 2024 00:58:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/etale_cohomology" aria-label="Profile: etale_cohomology">@<bdi>etale_cohomology</bdi></a><br />
We use an i2c script to configure the camera parameters, including exposure mode and settings. Please refer to the following link:<br />
<a href="https://wiki.veye.cc/index.php/Mv_mipi_i2c.sh_user_guide" rel="nofollow ugc">https://wiki.veye.cc/index.php/Mv_mipi_i2c.sh_user_guide</a></p>
]]></description><link>http://forum.veye.cc/post/3757</link><guid isPermaLink="true">http://forum.veye.cc/post/3757</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Thu, 25 Jan 2024 00:58:09 GMT</pubDate></item></channel></rss>
