<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[IMX327S IR-Cut Heat]]></title><description><![CDATA[<p dir="auto">Currently testing the IMX327S with a reComputer Jetson Xavier. Everything works perfectly, including the I2C tool to control the IR-cut filter. However, I am noticing that that the IR-cut filter device seems to generate a good amount of heat. To the point you can't touch it for too long. I am using the recommended wiring as documented on the Wiki, where 5V is also provided to the module in addition to the CSI connection. Is this normal? Thx!</p>
]]></description><link>http://forum.veye.cc/topic/556/imx327s-ir-cut-heat</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 16:23:05 GMT</lastBuildDate><atom:link href="http://forum.veye.cc/topic/556.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 08 Feb 2024 21:53:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to IMX327S IR-Cut Heat on Wed, 14 Feb 2024 05:47:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> Thank you. And agreed, it's heat transfer. Everything is stable and works great. Good to know it's normal.</p>
]]></description><link>http://forum.veye.cc/post/3795</link><guid isPermaLink="true">http://forum.veye.cc/post/3795</guid><dc:creator><![CDATA[newleaf]]></dc:creator><pubDate>Wed, 14 Feb 2024 05:47:51 GMT</pubDate></item><item><title><![CDATA[Reply to IMX327S IR-Cut Heat on Wed, 14 Feb 2024 02:30:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/newleaf" aria-label="Profile: newleaf">@<bdi>newleaf</bdi></a><br />
Based on my experience, this heat is not generated by IRCUT, but by the camera module itself.<br />
Indeed, many customers have reported that this camera module is hotter than expected, but there is no need to worry, as it does not affect stability.</p>
]]></description><link>http://forum.veye.cc/post/3794</link><guid isPermaLink="true">http://forum.veye.cc/post/3794</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Wed, 14 Feb 2024 02:30:44 GMT</pubDate></item><item><title><![CDATA[Reply to IMX327S IR-Cut Heat on Fri, 09 Feb 2024 00:03:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/newleaf" aria-label="Profile: newleaf">@<bdi>newleaf</bdi></a> Actually, this could be residual heat from when the sensor was streaming some video. I had video off for 30 minutes and its cooled down a bit. I was a little surprise how much the IR-cut filter heated up however. I will keep testing.</p>
]]></description><link>http://forum.veye.cc/post/3793</link><guid isPermaLink="true">http://forum.veye.cc/post/3793</guid><dc:creator><![CDATA[newleaf]]></dc:creator><pubDate>Fri, 09 Feb 2024 00:03:06 GMT</pubDate></item></channel></rss>
