<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[硬触发设置Trigger Delay  没有起作用]]></title><description><![CDATA[<p dir="auto">./mv_mipi_i2c.sh -w -f outio1_mode -p1 0 -b 7<br />
sleep 1<br />
./mv_mipi_i2c.sh -w -f trgmode -p1 1 -b 7<br />
sleep 1<br />
./mv_mipi_i2c.sh -w -f trgsrc -p1 1 -b 7<br />
sleep 1<br />
./mv_mipi_i2c.sh -w -f trgdelay -p1 10000 -b 7<br />
sleep 1<br />
./set.sh 1   //设置控制TriggerN_I0  的引脚为高电平输出。</p>
<p dir="auto">我们按照上述设置硬触发，每次拉高一次硬件触发的IO， 闪光灯会闪一次,但是并没有拍到有效的RAW图像，raw图像的数据大小是0，  麻烦帮我们看下</p>
]]></description><link>http://forum.veye.cc/topic/571/硬触发设置trigger-delay-没有起作用</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 14:35:08 GMT</lastBuildDate><atom:link href="http://forum.veye.cc/topic/571.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 20 Mar 2024 07:20:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 硬触发设置Trigger Delay  没有起作用 on Fri, 22 Mar 2024 07:04:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nb" aria-label="Profile: nb">@<bdi>nb</bdi></a><br />
<a href="https://wiki.veye.cc/index.php/Mv_mipi_camera_manual/zh#Sony.27s_Global_shutter.EF.BC.88.E5.85.A8.E5.B1.80.E6.9B.9D.E5.85.89.EF.BC.89" rel="nofollow ugc">https://wiki.veye.cc/index.php/Mv_mipi_camera_manual/zh#Sony.27s_Global_shutter.EF.BC.88.E5.85.A8.E5.B1.80.E6.9B.9D.E5.85.89.EF.BC.89</a><br />
2.4.3</p>
]]></description><link>http://forum.veye.cc/post/3929</link><guid isPermaLink="true">http://forum.veye.cc/post/3929</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Fri, 22 Mar 2024 07:04:28 GMT</pubDate></item><item><title><![CDATA[Reply to 硬触发设置Trigger Delay  没有起作用 on Fri, 22 Mar 2024 06:26:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> said in <a href="/post/3927">硬触发设置Trigger Delay 没有起作用</a>:</p>
<p dir="auto">你可以用软触发，或者硬触发做触发源。你可以自己去控制触发源，<br />
目前的状态是 拉高一次IO，一次触发就结束了，不能接着触发。<br />
下次再想触发的话，要再执行./yavta -c1 -Fy8-${WIDTH}x${HEIGHT}.raw --skip 0 -f Y8 -s ${WIDTH}x${HEIGHT} /dev/video0这个命令等待采集图像，然后再去拉高硬触发IO</p>
<p dir="auto">怎么设置多次硬触发，然后根据多次的硬触发 ，输出对应硬触发次数的图像呢，不需要说 还要再手动再去执行 ./yavta -c1 -Fy8-${WIDTH}x${HEIGHT}.raw --skip 0 -f Y8 -s ${WIDTH}x${HEIGHT} /dev/video0等待采集，然后等待再次拉高IO</p>
]]></description><link>http://forum.veye.cc/post/3928</link><guid isPermaLink="true">http://forum.veye.cc/post/3928</guid><dc:creator><![CDATA[nb]]></dc:creator><pubDate>Fri, 22 Mar 2024 06:26:26 GMT</pubDate></item><item><title><![CDATA[Reply to 硬触发设置Trigger Delay  没有起作用 on Fri, 22 Mar 2024 06:05:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nb" aria-label="Profile: nb">@<bdi>nb</bdi></a></p>
<p dir="auto">yavta 是开源的，其-c参数指明需要抓取多少张。</p>
<p dir="auto">如果我想要设置固定的比如1s连续触发30次， 就是连续抓拍30张照片，应该怎么实现这个逻辑呢？</p>
<p dir="auto">你可以用软触发，或者硬触发做触发源。你可以自己去控制触发源，每次触发一张。 也可以将配置相机的触发间隔和trgnum,实现一次触发，输出多张。</p>
]]></description><link>http://forum.veye.cc/post/3927</link><guid isPermaLink="true">http://forum.veye.cc/post/3927</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Fri, 22 Mar 2024 06:05:22 GMT</pubDate></item><item><title><![CDATA[Reply to 硬触发设置Trigger Delay  没有起作用 on Fri, 22 Mar 2024 05:53:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> 好的，感谢，</p>
<p dir="auto">顺便再麻烦问下，  现在用这个 yavta  ，每次要先开启yavta    再拉高硬触发IO， 然后抓拍一张，就结束了，  如果我想要设置固定的比如1s连续触发30次，  就是连续抓拍30张照片，应该怎么实现这个逻辑呢？</p>
]]></description><link>http://forum.veye.cc/post/3926</link><guid isPermaLink="true">http://forum.veye.cc/post/3926</guid><dc:creator><![CDATA[nb]]></dc:creator><pubDate>Fri, 22 Mar 2024 05:53:41 GMT</pubDate></item><item><title><![CDATA[Reply to 硬触发设置Trigger Delay  没有起作用 on Thu, 21 Mar 2024 06:08:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nb" aria-label="Profile: nb">@<bdi>nb</bdi></a></p>
<p dir="auto">设置这个trgnum的作用是啥？<br />
trgnum的意思是，希望一个触发信号可以触发多张图片，默认就是1的。</p>
<p dir="auto">./yavta -c1 -Fy8-${WIDTH}x${HEIGHT}.raw --skip 0 -f Y8 -s ${WIDTH}x${HEIGHT} /dev/video0 用这个命令 就可以，每次拉高一次硬件触发的IO， 闪光灯会闪一次,并且可以拍到图像， 为什么v4l2-ctl -d /dev/video0 --set-fmt-video=width=$WIDTH,height=$HEIGHT,pixelformat=GREY --stream-mmap --stream-count=20 --stream-to=y8-${WIDTH}x${HEIGHT}.raw这个命令不行呢？</p>
<p dir="auto">这个问题我遇到过，在飞凌的RK3588平台，的确有这个问题，原因我们没有多做追究。Firefly平台没有问题。<br />
建议你先用yavta命令进行抓拍。</p>
]]></description><link>http://forum.veye.cc/post/3924</link><guid isPermaLink="true">http://forum.veye.cc/post/3924</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Thu, 21 Mar 2024 06:08:27 GMT</pubDate></item><item><title><![CDATA[Reply to 硬触发设置Trigger Delay  没有起作用 on Wed, 20 Mar 2024 09:30:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> ./yavta -c1 -Fy8-${WIDTH}x${HEIGHT}.raw --skip 0 -f Y8 -s ${WIDTH}x${HEIGHT} /dev/video0   用这个命令 就可以，每次拉高一次硬件触发的IO， 闪光灯会闪一次,并且可以拍到图像，  为什么v4l2-ctl -d /dev/video0 --set-fmt-video=width=$WIDTH,height=$HEIGHT,pixelformat=GREY --stream-mmap --stream-count=20 --stream-to=y8-${WIDTH}x${HEIGHT}.raw这个命令不行呢？</p>
]]></description><link>http://forum.veye.cc/post/3919</link><guid isPermaLink="true">http://forum.veye.cc/post/3919</guid><dc:creator><![CDATA[nb]]></dc:creator><pubDate>Wed, 20 Mar 2024 09:30:03 GMT</pubDate></item><item><title><![CDATA[Reply to 硬触发设置Trigger Delay  没有起作用 on Wed, 20 Mar 2024 08:52:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> trgnum  设置成1 了，   但是获取的raw图像数据字节数是0</p>
<p dir="auto"><img src="/assets/uploads/files/1710924740989-c42c6ab3-8bbf-4220-86ec-fe097bc48581-image.png" alt="c42c6ab3-8bbf-4220-86ec-fe097bc48581-image.png" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1710924701420-b6ea98ba-791e-41a5-b052-a8f3a8c58f9f-image.png" alt="b6ea98ba-791e-41a5-b052-a8f3a8c58f9f-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>http://forum.veye.cc/post/3918</link><guid isPermaLink="true">http://forum.veye.cc/post/3918</guid><dc:creator><![CDATA[nb]]></dc:creator><pubDate>Wed, 20 Mar 2024 08:52:25 GMT</pubDate></item><item><title><![CDATA[Reply to 硬触发设置Trigger Delay  没有起作用 on Wed, 20 Mar 2024 08:23:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> 相机： imx296  主控rk35888<br />
trgnum没有设置，  设置这个trgnum的作用是啥？<br />
每次拉高一次硬件触发的IO， 闪光灯会闪一次，</p>
<p dir="auto">但是 这个命令并没有抓到图像 v4l2-ctl -d /dev/video0 --set-fmt-video=width=$WIDTH,height=$HEIGHT,pixelformat=GREY --stream-mmap --stream-count=20 --stream-to=y8-${WIDTH}x${HEIGHT}.raw</p>
]]></description><link>http://forum.veye.cc/post/3916</link><guid isPermaLink="true">http://forum.veye.cc/post/3916</guid><dc:creator><![CDATA[nb]]></dc:creator><pubDate>Wed, 20 Mar 2024 08:23:18 GMT</pubDate></item><item><title><![CDATA[Reply to 硬触发设置Trigger Delay  没有起作用 on Wed, 20 Mar 2024 07:56:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nb" aria-label="Profile: nb">@<bdi>nb</bdi></a> 请问你用的相机型号，主板类型是什么？trgnum设置的多少？除了闪光灯之外，有没有触发出多张图片？ 怎么进行触发操作的？</p>
]]></description><link>http://forum.veye.cc/post/3915</link><guid isPermaLink="true">http://forum.veye.cc/post/3915</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Wed, 20 Mar 2024 07:56:04 GMT</pubDate></item></channel></rss>
