<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[IMX327在樹梅派Zero W上驅動問題]]></title><description><![CDATA[<p dir="auto">你好，在樹梅派 Zero W上使用IMX327，</p>
<p dir="auto">依照:<a href="https://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi" rel="nofollow ugc">https://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi</a>)步驟安裝驅動，顯示下面錯誤：<br />
Installing the veyecam2m.ko driver</p>
<p dir="auto">install: cannot stat './driver_bin/6.6.20+rpt-rpi-v6/veyecam2m.ko': No such file or directory<br />
install: cannot stat './driver_bin/6.6.20+rpt-rpi-v6/veyecam2m.dtbo': No such file or directory</p>
<p dir="auto">依照:<a href="https://wiki.veye.cc/index.php/Build_drivers_from_source_for_rpi/zh" rel="nofollow ugc">https://wiki.veye.cc/index.php/Build_drivers_from_source_for_rpi/zh</a><br />
自行編譯驅動，出現以下警告<br />
<img src="/assets/uploads/files/1718257099555-ced55c71-9df2-42cd-a009-8bb21fb03b4f-image.png" alt="ced55c71-9df2-42cd-a009-8bb21fb03b4f-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1718257899641-737b16f5-4703-406c-b5ff-b99f0cc40be1-image.png" alt="737b16f5-4703-406c-b5ff-b99f0cc40be1-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1718257936243-0096b590-d91e-45ab-ab4f-e1376403547a-image.png" alt="0096b590-d91e-45ab-ab4f-e1376403547a-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">可以安裝驅動：<br />
<img src="/assets/uploads/files/1718257990805-d55f0a8e-edec-4481-b5cb-96a786baedcb-image.png" alt="d55f0a8e-edec-4481-b5cb-96a786baedcb-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1718258078906-2ee3d434-fce5-4c77-a698-7181b3948ab0-image.png" alt="2ee3d434-fce5-4c77-a698-7181b3948ab0-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">不過使用:<a href="https://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi" rel="nofollow ugc">https://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi</a> 的Gstreamer 範例，會出現錯誤：<br />
<img src="/assets/uploads/files/1718258125537-63b8c84c-9a62-45d6-a597-15c0ee3ad289-image.png" alt="63b8c84c-9a62-45d6-a597-15c0ee3ad289-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">請問如何解決這個問題？謝謝。</p>
]]></description><link>http://forum.veye.cc/topic/610/imx327在樹梅派zero-w上驅動問題</link><generator>RSS for Node</generator><lastBuildDate>Fri, 04 Sep 2026 22:50:08 GMT</lastBuildDate><atom:link href="http://forum.veye.cc/topic/610.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 13 Jun 2024 03:54:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to IMX327在樹梅派Zero W上驅動問題 on Fri, 14 Jun 2024 06:11:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/leo12757" aria-label="Profile: leo12757">@<bdi>leo12757</bdi></a><br />
你好，抱歉这两天比较忙，我给一个大体的思路您可以试一下。<br />
<code>install_driver.sh</code>在安装驱动的时候，做了如下两处更改，您可以手动去掉，然后重启系统后再测试一下。</p>
<ol>
<li>
<p dir="auto">Add gpu=256M to ${CONFIG_FILE}，CONFIG_FILE="/boot/firmware/config.txt" or CONFIG_FILE="/boot/config.txt"</p>
</li>
<li>
<p dir="auto">echo "Add cma=128M to /boot/cmdline.txt "</p>
</li>
</ol>
]]></description><link>http://forum.veye.cc/post/4196</link><guid isPermaLink="true">http://forum.veye.cc/post/4196</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Fri, 14 Jun 2024 06:11:17 GMT</pubDate></item><item><title><![CDATA[Reply to IMX327在樹梅派Zero W上驅動問題 on Fri, 14 Jun 2024 03:42:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a><br />
安裝全新PiOS，更新系統至最新，重新開機有畫面（系統）<br />
安裝IMX327驅動後沒有畫面顯示，但SSH仍可以登入，<br />
所以無法測試qv4l2、VLC。</p>
<p dir="auto">開機顯示該錯誤<br />
<img src="/assets/uploads/files/1718336542551-15dd9f7d-626c-4d98-aace-56c260e822f9-image.png" alt="15dd9f7d-626c-4d98-aace-56c260e822f9-image.png" class=" img-fluid img-markdown" /><br />
[    0.000000] 0F: reserved men: failed to allocate menory for node 'linux, cma': size 256 MiB<br />
[  15.5268043] [drm:uc4_bo_create [vc4]] *ERROR» Failed to allocate fron GEM DMA helper:</p>
]]></description><link>http://forum.veye.cc/post/4195</link><guid isPermaLink="true">http://forum.veye.cc/post/4195</guid><dc:creator><![CDATA[leo12757]]></dc:creator><pubDate>Fri, 14 Jun 2024 03:42:53 GMT</pubDate></item><item><title><![CDATA[Reply to IMX327在樹梅派Zero W上驅動問題 on Thu, 13 Jun 2024 11:13:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a></p>
<p dir="auto">顯示錯誤<br />
<img src="/assets/uploads/files/1718277203450-437a3f1e-c74e-4c24-8c4b-38d58fab9485-image.png" alt="437a3f1e-c74e-4c24-8c4b-38d58fab9485-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>http://forum.veye.cc/post/4191</link><guid isPermaLink="true">http://forum.veye.cc/post/4191</guid><dc:creator><![CDATA[leo12757]]></dc:creator><pubDate>Thu, 13 Jun 2024 11:13:47 GMT</pubDate></item><item><title><![CDATA[Reply to IMX327在樹梅派Zero W上驅動問題 on Thu, 13 Jun 2024 07:52:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/leo12757" aria-label="Profile: leo12757">@<bdi>leo12757</bdi></a> 麻烦你先直接用如下命令取一下图看看</p>
<pre><code>v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=UYVY --stream-mmap --stream-count=10 --stream-to=uyvy-1920x1080_stream.yuv
]]></description><link>http://forum.veye.cc/post/4187</link><guid isPermaLink="true">http://forum.veye.cc/post/4187</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Thu, 13 Jun 2024 07:52:18 GMT</pubDate></item><item><title><![CDATA[Reply to IMX327在樹梅派Zero W上驅動問題 on Thu, 13 Jun 2024 07:21:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a><br />
因為我安裝的是Lite版本PiOS，因此沒有VLC可以撥放...但我會試試看</p>
<p dir="auto">使用:<a href="https://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi" rel="nofollow ugc">https://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi</a> 的Gstreamer測試指令，Gstreamer看起來是正常的（?）。<br />
<img src="/assets/uploads/files/1718262307418-2550c331-b9bc-494d-9d81-663154712ec9-image.png" alt="2550c331-b9bc-494d-9d81-663154712ec9-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">另外，依照:<a href="https://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi" rel="nofollow ugc">https://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi</a> 的拍照和存成mp4檔的範例，也都會失敗：</p>
<p dir="auto">拍照：<br />
<img src="/assets/uploads/files/1718262721479-5375ebff-b83c-4017-b7c4-6c2fa558ec48-image.png" alt="5375ebff-b83c-4017-b7c4-6c2fa558ec48-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">mp4：<br />
<img src="/assets/uploads/files/1718262757621-d3bd9fdd-aff1-4903-a7e7-d939a67597ae-image.png" alt="d3bd9fdd-aff1-4903-a7e7-d939a67597ae-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">麻煩了，謝謝。</p>
]]></description><link>http://forum.veye.cc/post/4185</link><guid isPermaLink="true">http://forum.veye.cc/post/4185</guid><dc:creator><![CDATA[leo12757]]></dc:creator><pubDate>Thu, 13 Jun 2024 07:21:12 GMT</pubDate></item><item><title><![CDATA[Reply to IMX327在樹梅派Zero W上驅動問題 on Thu, 13 Jun 2024 06:30:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/leo12757" aria-label="Profile: leo12757">@<bdi>leo12757</bdi></a><br />
驱动编译中的warning不用理会。<br />
你可以先试试简单预览是否成功，比如用qv4l2，然后试试gstreamer预览。</p>
]]></description><link>http://forum.veye.cc/post/4180</link><guid isPermaLink="true">http://forum.veye.cc/post/4180</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Thu, 13 Jun 2024 06:30:31 GMT</pubDate></item></channel></rss>
