<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RAW-MIPI-SC132M驱动编译后无法正常播放]]></title><description><![CDATA[<p dir="auto">按照官方手册移植RAM-MIPI-SC132M驱动到rk35xx_radxa驱动radxa 3w，程序启动正常：</p>
<p dir="auto"><img src="/assets/uploads/files/1718584311153-eeb0158c-11e4-4f05-8e70-db5d86bba855-image.png" alt="eeb0158c-11e4-4f05-8e70-db5d86bba855-image.png" class=" img-fluid img-markdown" /><br />
抓帧也正常：<br />
<img src="/assets/uploads/files/1718584674370-bd89d6e8-4dfa-4529-b489-5ce26ad0166f-image.png" alt="bd89d6e8-4dfa-4529-b489-5ce26ad0166f-image.png" class=" img-fluid img-markdown" /><br />
但是用v4l2dev_2_opencv_show_grey.py运行时会卡死，无图像输出。<br />
单独运行gst-launch-1.0 v4l2src io-mode=dmabuf device=/dev/video0 ! video/x-raw, format=GRAY8, width=1024, height=1280 ! videoconvert ! autovideosink命令时也会卡死在2s左右。请问下这个是什么原因造成的，如何去排查？</p>
]]></description><link>http://forum.veye.cc/topic/612/raw-mipi-sc132m驱动编译后无法正常播放</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 14:57:40 GMT</lastBuildDate><atom:link href="http://forum.veye.cc/topic/612.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 17 Jun 2024 00:38:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RAW-MIPI-SC132M驱动编译后无法正常播放 on Fri, 21 Jun 2024 03:20:33 GMT]]></title><description><![CDATA[<p dir="auto">客户已解决。是kernel配置中关于rkcif的配置原因。</p>
]]></description><link>http://forum.veye.cc/post/4236</link><guid isPermaLink="true">http://forum.veye.cc/post/4236</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Fri, 21 Jun 2024 03:20:33 GMT</pubDate></item><item><title><![CDATA[Reply to RAW-MIPI-SC132M驱动编译后无法正常播放 on Wed, 19 Jun 2024 05:59:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a><br />
<img src="/assets/uploads/files/1718776760245-692724e7-2e5a-4ce8-ab0a-40fcaf83daa7-image.png" alt="692724e7-2e5a-4ce8-ab0a-40fcaf83daa7-image.png" class=" img-fluid img-markdown" /><br />
系统启动时好像有报错，不知道和这个是否有关？</p>
]]></description><link>http://forum.veye.cc/post/4223</link><guid isPermaLink="true">http://forum.veye.cc/post/4223</guid><dc:creator><![CDATA[ashengzi]]></dc:creator><pubDate>Wed, 19 Jun 2024 05:59:46 GMT</pubDate></item><item><title><![CDATA[Reply to RAW-MIPI-SC132M驱动编译后无法正常播放 on Wed, 19 Jun 2024 02:10:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> said in <a href="/post/4221">RAW-MIPI-SC132M驱动编译后无法正常播放</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ashengzi" aria-label="Profile: ashengzi">@<bdi>ashengzi</bdi></a> said in <a href="/post/4220">RAW-MIPI-SC132M驱动编译后无法正常播放</a>:</p>
<p dir="auto">我这边发现我编译的radxa官方固件是5.10.160-1,而veye官网上用的是Linux radxa-zero3 5.10.160-26,这个有影响吗</p>
<p dir="auto">这个没有关系。</p>
<p dir="auto">我这边测试了一下没问题啊。<br />
<img src="/assets/uploads/files/1718762057937-61ef29e4-85bf-4e4b-b83b-dd99735b2c2c-567b481a95a3fe4153d7f03b37fc8ac.jpg" alt="61ef29e4-85bf-4e4b-b83b-dd99735b2c2c-567b481a95a3fe4153d7f03b37fc8ac.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">另外提一下，我这边OS用的是radxa发布的debain系统，不是ubuntu系统。 不知你这用的什么系统？<br />
<img src="/assets/uploads/files/1718762902633-804b8cbd-60cb-466a-b3b9-1061d13a5dd2-image.png" alt="804b8cbd-60cb-466a-b3b9-1061d13a5dd2-image.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1718762992426-3d8552a7-301d-4051-84b0-86076d65c310-image.png" alt="3d8552a7-301d-4051-84b0-86076d65c310-image.png" class=" img-fluid img-markdown" /><br />
我这个也是deban系统，驱动运行正应该是正常的，但就是无法正常播放，好像卡在哪个地方了</p>
]]></description><link>http://forum.veye.cc/post/4222</link><guid isPermaLink="true">http://forum.veye.cc/post/4222</guid><dc:creator><![CDATA[ashengzi]]></dc:creator><pubDate>Wed, 19 Jun 2024 02:10:55 GMT</pubDate></item><item><title><![CDATA[Reply to RAW-MIPI-SC132M驱动编译后无法正常播放 on Wed, 19 Jun 2024 01:55:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ashengzi" aria-label="Profile: ashengzi">@<bdi>ashengzi</bdi></a> said in <a href="/post/4220">RAW-MIPI-SC132M驱动编译后无法正常播放</a>:</p>
<p dir="auto">另外提一下，我这边OS用的是radxa发布的debain系统，不是ubuntu系统。 不知你这用的什么系统？</p>
]]></description><link>http://forum.veye.cc/post/4221</link><guid isPermaLink="true">http://forum.veye.cc/post/4221</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Wed, 19 Jun 2024 01:55:47 GMT</pubDate></item><item><title><![CDATA[Reply to RAW-MIPI-SC132M驱动编译后无法正常播放 on Tue, 18 Jun 2024 10:30:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ashengzi" aria-label="Profile: ashengzi">@<bdi>ashengzi</bdi></a> said in <a href="/post/4215">RAW-MIPI-SC132M驱动编译后无法正常播放</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> said in <a href="/post/4214">RAW-MIPI-SC132M驱动编译后无法正常播放</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ashengzi" aria-label="Profile: ashengzi">@<bdi>ashengzi</bdi></a> 比较奇怪，按理说v4l2-ctl取图成功，用python预览也就可以成功的。因为其底层都是v4l2驱动接口。</p>
<p dir="auto"><img src="/assets/uploads/files/1718670039590-0b919c66-4b5a-4dcc-b00c-7500d7cdd436-image.png" alt="0b919c66-4b5a-4dcc-b00c-7500d7cdd436-image.png" class=" img-fluid img-markdown" /><br />
v4l2-ctl   -D --verbose  -d /dev/video0 --set-fmt-video=width=$WIDTH,height=$HEIGHT,pixelformat=GREY --stream-mmap --stream-count=1 --stream-to=y8-${WIDTH}x${HEIGHT}.raw<br />
VIDIOC_QUERYCAP: ok<br />
Driver Info:<br />
Driver name      : rkcif<br />
Card type        : rkcif<br />
Bus info         : platform:rkcif_mipi_lvds<br />
Driver version   : 5.10.160<br />
Capabilities     : 0x84201000<br />
Video Capture Multiplanar<br />
Streaming<br />
Extended Pix Format<br />
Device Capabilities<br />
Device Caps      : 0x04201000<br />
Streaming<br />
Media Driver Info:<br />
Model            : rkcif_mipi_lvds<br />
Serial           :<br />
Bus info         :<br />
Media version    : 5.10.160<br />
Hardware revision: 0x00000000 (0)<br />
Interface Info:<br />
Type             : V4L Video<br />
Entity Info:<br />
ID               : 0x00000001 (1)<br />
Function         : V4L2 I/O<br />
Pad 0x01000004   : 0: Sink<br />
Link 0x0200002f: from remote pad 0x1000022 of entity 'rockchip-mipi-csi2': Data, Enabled<br />
Link 0x0200003d: from remote pad 0x1000023 of entity 'rockchip-mipi-csi2': Data<br />
Link 0x0200004b: from remote pad 0x1000024 of entity 'rockchip-mipi-csi2': Data<br />
Link 0x02000059: from remote pad 0x1000025 of entity 'rockchip-mipi-csi2': Data<br />
VIDIOC_G_FMT: ok<br />
VIDIOC_S_FMT: ok<br />
Format Video Capture Multiplanar:<br />
Width/Height      : 1024/1280<br />
Pixel Format      : 'GREY' (8-bit Greyscale)<br />
Field             : None<br />
Number of planes  : 1<br />
Flags             :<br />
Colorspace        : Default<br />
Transfer Function : Default<br />
YCbCr/HSV Encoding: Default<br />
Quantization      : Default<br />
Plane 0           :<br />
Bytes per Line : 1024<br />
Size Image     : 1310720<br />
VIDIOC_REQBUFS returned 0 (Success)<br />
VIDIOC_QUERYBUF returned 0 (Success)<br />
VIDIOC_QBUF returned 0 (Success)<br />
VIDIOC_STREAMON returned 0 (Success)<br />
cap dqbuf: 0 seq:      0 bytesused: 1310720 ts: 1211.810033 delta: 1211810.033 ms (ts-monotonic, ts-src-eof)<br />
gstreamer版本没有问题，单张抓图也没有问题，抓帧也没问题，搞不明白问题出在哪里了？</p>
<p dir="auto"><img src="/assets/uploads/files/1718706470294-1bc5c0a1-1bc8-4539-9451-8171b5a7a215-image.png" alt="1bc5c0a1-1bc8-4539-9451-8171b5a7a215-image.png" class=" img-fluid img-markdown" /><br />
]]></description><link>http://forum.veye.cc/post/4220</link><guid isPermaLink="true">http://forum.veye.cc/post/4220</guid><dc:creator><![CDATA[ashengzi]]></dc:creator><pubDate>Tue, 18 Jun 2024 10:30:21 GMT</pubDate></item><item><title><![CDATA[Reply to RAW-MIPI-SC132M驱动编译后无法正常播放 on Tue, 18 Jun 2024 00:24:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> said in <a href="/post/4214">RAW-MIPI-SC132M驱动编译后无法正常播放</a>:</p>
Driver Info:<br />
Streaming<br />
Streaming<br />
Serial           :<br />
Bus info         :<br />
Entity Info:<br />
Field             : None<br />
Flags             :<br />
Plane 0           :<br />
]]></description><link>http://forum.veye.cc/post/4215</link><guid isPermaLink="true">http://forum.veye.cc/post/4215</guid><dc:creator><![CDATA[ashengzi]]></dc:creator><pubDate>Tue, 18 Jun 2024 00:24:46 GMT</pubDate></item><item><title><![CDATA[Reply to RAW-MIPI-SC132M驱动编译后无法正常播放 on Mon, 17 Jun 2024 12:05:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ashengzi" aria-label="Profile: ashengzi">@<bdi>ashengzi</bdi></a> 比较奇怪，按理说v4l2-ctl取图成功，用python预览也就可以成功的。因为其底层都是v4l2驱动接口。</p>
]]></description><link>http://forum.veye.cc/post/4214</link><guid isPermaLink="true">http://forum.veye.cc/post/4214</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Mon, 17 Jun 2024 12:05:54 GMT</pubDate></item><item><title><![CDATA[Reply to RAW-MIPI-SC132M驱动编译后无法正常播放 on Mon, 17 Jun 2024 10:22:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> said in <a href="/post/4208">RAW-MIPI-SC132M驱动编译后无法正常播放</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ashengzi" aria-label="Profile: ashengzi">@<bdi>ashengzi</bdi></a><br />
你调用</p>
<pre><code>python3 ./v4l2dev_2_opencv_show_grey.py --width 1024--height 1280--fps 60 --i2c 2
<p dir="auto">试一下<br />
试过了，也不行<br />
<img src="/assets/uploads/files/1718619722695-dfffcc0f-4336-40d3-97ca-ac5ee9eeadb5-image.png" alt="dfffcc0f-4336-40d3-97ca-ac5ee9eeadb5-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>http://forum.veye.cc/post/4213</link><guid isPermaLink="true">http://forum.veye.cc/post/4213</guid><dc:creator><![CDATA[ashengzi]]></dc:creator><pubDate>Mon, 17 Jun 2024 10:22:15 GMT</pubDate></item><item><title><![CDATA[Reply to RAW-MIPI-SC132M驱动编译后无法正常播放 on Mon, 17 Jun 2024 07:26:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ashengzi" aria-label="Profile: ashengzi">@<bdi>ashengzi</bdi></a><br />
你调用</p>
<p dir="auto">试一下</p>
]]></description><link>http://forum.veye.cc/post/4208</link><guid isPermaLink="true">http://forum.veye.cc/post/4208</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Mon, 17 Jun 2024 07:26:06 GMT</pubDate></item><item><title><![CDATA[Reply to RAW-MIPI-SC132M驱动编译后无法正常播放 on Mon, 17 Jun 2024 06:06:33 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1718604378428-8f9c1cbf-f04f-4ee2-b525-3c96ae3a0f83-image.png" alt="8f9c1cbf-f04f-4ee2-b525-3c96ae3a0f83-image.png" class=" img-fluid img-markdown" /> 报了这个错误</p>
]]></description><link>http://forum.veye.cc/post/4206</link><guid isPermaLink="true">http://forum.veye.cc/post/4206</guid><dc:creator><![CDATA[ashengzi]]></dc:creator><pubDate>Mon, 17 Jun 2024 06:06:33 GMT</pubDate></item></channel></rss>
