<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CS-MIPI-IMX307 hardware trigger]]></title><description><![CDATA[<p dir="auto">Hello.</p>
<p dir="auto">We recently purchased the <a href="https://www.veye.cc/en/product/cs-tx2-xavier-ncam-imx307/" rel="nofollow ugc">cs-tx2-xavier-ncam-imx307</a> set. I want to synchronize it with LiDAR using the Lidar XVS output. Our base board is Jetson AGX Xavier, L4T 35.1.</p>
<p dir="auto">Is hardware trigger supported on the CS-MIPI-IMX307 module?</p>
<p dir="auto">What I have tried:</p>
<ul>
<li>disable vi timeout<br />
v4l2-ctl -c vi_time_out_disable=1 -d /dev/video0 (and video1, video2)</li>
<li>put camera in hardware trigger mode, then push the SW1 button on the ADP-N1-V2.0 board<br />
./cs_mipi_i2c.sh -w -f streammode -p1 2 -b 30 (and 31, 32)<br />
(it doesn't work. Frames are captured even when i didn't push the capture button)</li>
<li>put camera in sync mode, all slave<br />
./cs_mipi_i2c.sh -w -f streammode -p1 1 -p2 1 -b 30<br />
./cs_mipi_i2c.sh -w -f streammode -p1 1 -p2 1 -b 31<br />
./cs_mipi_i2c.sh -w -f streammode -p1 1 -p2 1 -b 32<br />
(Also doesn't work. Frames are captured without button push and they are all blue)</li>
</ul>
<p dir="auto">Please confirm whether hardware trigger is possible or not. I am open to workaround suggestion if any.</p>
<p dir="auto">Thank you.</p>
]]></description><link>http://forum.veye.cc/topic/619/cs-mipi-imx307-hardware-trigger</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 12:04:50 GMT</lastBuildDate><atom:link href="http://forum.veye.cc/topic/619.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Jul 2024 05:03:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CS-MIPI-IMX307 hardware trigger on Tue, 09 Jul 2024 06:29:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lnlinh" aria-label="Profile: lnlinh">@<bdi>lnlinh</bdi></a> said in <a href="/post/4291">CS-MIPI-IMX307 hardware trigger</a>:</p>
<p dir="auto">streammode</p>
<p dir="auto">Sorry, CS-MIPI-IMX307 does not support external trigger mode, only free running and sync mode.</p>
]]></description><link>http://forum.veye.cc/post/4292</link><guid isPermaLink="true">http://forum.veye.cc/post/4292</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Tue, 09 Jul 2024 06:29:26 GMT</pubDate></item></channel></rss>
