<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[cssc132 driver for Raspberry pi 5]]></title><description><![CDATA[<p dir="auto">Hi<br />
Is there a cssc132 driver update coming for raspberry pi 5?</p>
]]></description><link>http://forum.veye.cc/topic/651/cssc132-driver-for-raspberry-pi-5</link><generator>RSS for Node</generator><lastBuildDate>Fri, 04 Sep 2026 13:49:59 GMT</lastBuildDate><atom:link href="http://forum.veye.cc/topic/651.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 10 Nov 2024 12:10:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to cssc132 driver for Raspberry pi 5 on Tue, 12 Nov 2024 01:35:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reinbb" aria-label="Profile: reinbb">@<bdi>reinbb</bdi></a> OK</p>
]]></description><link>http://forum.veye.cc/post/4576</link><guid isPermaLink="true">http://forum.veye.cc/post/4576</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Tue, 12 Nov 2024 01:35:38 GMT</pubDate></item><item><title><![CDATA[Reply to cssc132 driver for Raspberry pi 5 on Mon, 11 Nov 2024 15:16:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> Sorry. Driver works. Testing and reading should be by v4l2.</p>
]]></description><link>http://forum.veye.cc/post/4575</link><guid isPermaLink="true">http://forum.veye.cc/post/4575</guid><dc:creator><![CDATA[reinbb]]></dc:creator><pubDate>Mon, 11 Nov 2024 15:16:30 GMT</pubDate></item><item><title><![CDATA[Reply to cssc132 driver for Raspberry pi 5 on Mon, 11 Nov 2024 10:54:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> Thanks for the quick reply!  Looks like I'm missing something. Can you help me with it?<br />
I followed the documentation <a href="https://github.com/veyeimaging/raspberrypi_v4l2" rel="nofollow ugc">raspberrypi_v4l2</a>. Unsuccessfully.<br />
Env:</p>
<ul>
<li>
<p dir="auto">Raspberry Pi 5</p>
</li>
<li>
<p dir="auto">OS: Linux raspberrypi 6.6.51+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.6.51-1+rpt3 (2024-10-08) aarch64 GNU/Linux</p>
</li>
<li>
<p dir="auto">I compiled  cssc132.ko and cssc132.dtbo (from rpi-6.6.y dirs).</p>
</li>
<li>
<p dir="auto">then    raspberrypi_v4l2/release/driver_bin/6.6.51+rpt-rpi-2712 was created</p>
</li>
<li>
<p dir="auto">after that I executed  raspberrypi_v4l2/release/install_driver_rpi5.sh</p>
</li>
<li>
<p dir="auto">reboot</p>
</li>
<li>
<p dir="auto">then I tested /boot/firmware/config.txt:<br />
[all]<br />
dtparam=i2c_vc=on<br />
dtoverlay=cssc132<br />
dtoverlay=cssc132,cam0</p>
</li>
</ul>
<p dir="auto">After that video0 and video1 appeared.</p>
<p dir="auto">Then I configured driver by executing following scripts:<br />
./find_entity.sh<br />
Found cssc132 @ i2c-4 entity on /dev/media1<br />
Plese get frame from /dev/video0 and use /dev/v4l-subdev2 for camera setting.<br />
./media_setting_rpi5.sh cssc132 -fmt UYVY -w 1280 -h 1080<br />
This is a Raspberry Pi 5.<br />
camera is YUV type<br />
camera name cssc132; width 1280; height 1080; media_fmt UYVY8_1X16; pixel_fmt UYVY<br />
CAM1 probed: media device is /dev/media1<br />
set CAM1 finish, plese get frame from /dev/video0 and use /dev/v4l-subdev2 for camera setting<br />
cssc132 6 NOT FOUND</p>
<p dir="auto">After all I tried to test cam by ffprobe /dev/video0  or /dev/video1. But I see the following errors:<br />
libswresample   4.  7.100 /  4.  7.100<br />
libpostproc    56.  6.100 / 56.  6.100<br />
[video4linux2,v4l2 @ 0x5555c17f7b00] ioctl(VIDIOC_G_FMT): Invalid argument<br />
/dev/video1: Invalid argument</p>
]]></description><link>http://forum.veye.cc/post/4574</link><guid isPermaLink="true">http://forum.veye.cc/post/4574</guid><dc:creator><![CDATA[reinbb]]></dc:creator><pubDate>Mon, 11 Nov 2024 10:54:05 GMT</pubDate></item><item><title><![CDATA[Reply to cssc132 driver for Raspberry pi 5 on Mon, 11 Nov 2024 03:48:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reinbb" aria-label="Profile: reinbb">@<bdi>reinbb</bdi></a> cssc132.ko<br />
This driver has always been available and open source.</p>
]]></description><link>http://forum.veye.cc/post/4573</link><guid isPermaLink="true">http://forum.veye.cc/post/4573</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Mon, 11 Nov 2024 03:48:31 GMT</pubDate></item></channel></rss>
