<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MV-MIPI-SC130M autoexposure problem]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I am using MV-MIPI-SC130M camera with RK3588S basic image from VEYE.<br />
Camera is configured used to hardware trigger mode on rising edge, aemaxexposure time is 5000 mks.<br />
Sometimes after restarts autoexposure mode does not work, current exposure time is near 4600 - 4800 ms and does not changes, even if I change aemaxexposure value.<br />
After restart autoexposure works normally.</p>
]]></description><link>http://forum.veye.cc/topic/702/mv-mipi-sc130m-autoexposure-problem</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 15:35:35 GMT</lastBuildDate><atom:link href="http://forum.veye.cc/topic/702.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 08 Oct 2025 09:55:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MV-MIPI-SC130M autoexposure problem on Fri, 24 Oct 2025 08:15:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> Hi,<br />
Firmware update does not solve the problem, after software reset auto exposure mode works normal</p>
]]></description><link>http://forum.veye.cc/post/4931</link><guid isPermaLink="true">http://forum.veye.cc/post/4931</guid><dc:creator><![CDATA[Dan]]></dc:creator><pubDate>Fri, 24 Oct 2025 08:15:14 GMT</pubDate></item><item><title><![CDATA[Reply to MV-MIPI-SC130M autoexposure problem on Thu, 09 Oct 2025 11:10:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a><br />
Thank you, I take a some time for tests</p>
]]></description><link>http://forum.veye.cc/post/4904</link><guid isPermaLink="true">http://forum.veye.cc/post/4904</guid><dc:creator><![CDATA[Dan]]></dc:creator><pubDate>Thu, 09 Oct 2025 11:10:05 GMT</pubDate></item><item><title><![CDATA[Reply to MV-MIPI-SC130M autoexposure problem on Thu, 09 Oct 2025 09:59:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dan" aria-label="Profile: dan">@<bdi>dan</bdi></a><br />
Please refer to the two links below to upgrade the firmware of your camera. Then test it again.<br />
<a href="https://wiki.veye.cc/index.php/Mvcam_firmware_update_manual" rel="nofollow ugc">https://wiki.veye.cc/index.php/Mvcam_firmware_update_manual</a><br />
<a href="https://wiki.veye.cc/index.php/MV-MIPI-SC130M_Version_Log" rel="nofollow ugc">https://wiki.veye.cc/index.php/MV-MIPI-SC130M_Version_Log</a></p>
]]></description><link>http://forum.veye.cc/post/4903</link><guid isPermaLink="true">http://forum.veye.cc/post/4903</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Thu, 09 Oct 2025 09:59:48 GMT</pubDate></item><item><title><![CDATA[Reply to MV-MIPI-SC130M autoexposure problem on Thu, 09 Oct 2025 09:17:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a><br />
version is C 01.35 and L 02.01</p>
]]></description><link>http://forum.veye.cc/post/4902</link><guid isPermaLink="true">http://forum.veye.cc/post/4902</guid><dc:creator><![CDATA[Dan]]></dc:creator><pubDate>Thu, 09 Oct 2025 09:17:42 GMT</pubDate></item><item><title><![CDATA[Reply to MV-MIPI-SC130M autoexposure problem on Thu, 09 Oct 2025 08:39:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dan" aria-label="Profile: dan">@<bdi>dan</bdi></a> Please read the version number of the camera you are using and send it to me.</p>
]]></description><link>http://forum.veye.cc/post/4901</link><guid isPermaLink="true">http://forum.veye.cc/post/4901</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Thu, 09 Oct 2025 08:39:27 GMT</pubDate></item><item><title><![CDATA[Reply to MV-MIPI-SC130M autoexposure problem on Thu, 09 Oct 2025 08:22:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a><br />
We use regular external trigger, target framerate is 20 fps. Ambient lighting not stable, so we have to use autoexposure mode.</p>
]]></description><link>http://forum.veye.cc/post/4900</link><guid isPermaLink="true">http://forum.veye.cc/post/4900</guid><dc:creator><![CDATA[Dan]]></dc:creator><pubDate>Thu, 09 Oct 2025 08:22:51 GMT</pubDate></item><item><title><![CDATA[Reply to MV-MIPI-SC130M autoexposure problem on Thu, 09 Oct 2025 07:17:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dan" aria-label="Profile: dan">@<bdi>dan</bdi></a><br />
Generally, in external trigger mode, manual exposure is recommended.<br />
This is because the algorithm of the automatic exposure mode relies on regular image input, whereas the trigger intervals in external trigger mode may be random or even very long.<br />
If the ambient lighting in your application scenario is stable, it is still advisable to use manual exposure mode.</p>
]]></description><link>http://forum.veye.cc/post/4895</link><guid isPermaLink="true">http://forum.veye.cc/post/4895</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Thu, 09 Oct 2025 07:17:44 GMT</pubDate></item></channel></rss>
