<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Veye MIPI imx462  Defaults]]></title><description><![CDATA[<p dir="auto">Hi,<br />
What is the default config of veye mipi 462 ?</p>
<p dir="auto">UYVU or YUYV ?<br />
25 fps or 30 fps ?</p>
<p dir="auto">HS mode and LP mode?</p>
<p dir="auto">Thanks.</p>
]]></description><link>http://forum.veye.cc/topic/703/veye-mipi-imx462-defaults</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 15:44:47 GMT</lastBuildDate><atom:link href="http://forum.veye.cc/topic/703.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 14 Oct 2025 07:44:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Veye MIPI imx462  Defaults on Sun, 19 Oct 2025 14:00:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a></p>
<p dir="auto">Hello my friend.<br />
We are sending I2C commands via a FPGA.</p>
<p dir="auto">1_ Writing 0xff to 0x000b solved our problem. Thank you. Please give us a command to save this change.</p>
<p dir="auto">2_ We are trying to change video frame rate (now is 30fps and we need 25fps).<br />
by these commands we cannot do this :<br />
0x10 0xDE<br />
0x11 0xC2<br />
0x12 0x00<br />
0x13 0x00<br />
(sending Two byte, then sending next two byte and ... ).</p>
<p dir="auto">Please guide me. Thanks a lot.</p>
]]></description><link>http://forum.veye.cc/post/4924</link><guid isPermaLink="true">http://forum.veye.cc/post/4924</guid><dc:creator><![CDATA[nimadibaj]]></dc:creator><pubDate>Sun, 19 Oct 2025 14:00:53 GMT</pubDate></item><item><title><![CDATA[Reply to Veye MIPI imx462  Defaults on Sat, 18 Oct 2025 09:33:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nimadibaj" aria-label="Profile: nimadibaj">@<bdi>nimadibaj</bdi></a><br />
I don't know which platform your motherboard is using, but if you have used the veye_mipi_i2c.sh script, there is an i2c_write file in that directory. You can use this file to modify the aforementioned registers.</p>
]]></description><link>http://forum.veye.cc/post/4923</link><guid isPermaLink="true">http://forum.veye.cc/post/4923</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Sat, 18 Oct 2025 09:33:10 GMT</pubDate></item><item><title><![CDATA[Reply to Veye MIPI imx462  Defaults on Sat, 18 Oct 2025 07:13:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> said in <a href="/post/4921">Veye MIPI imx462 Defaults</a>:</p>
<p dir="auto">Use the i2c_write command to change 0x000b to 0xff.</p>
<p dir="auto">Sorry, I don't understand. I should write 0xff to this address : 0x000b.</p>
<p dir="auto">True ?</p>
]]></description><link>http://forum.veye.cc/post/4922</link><guid isPermaLink="true">http://forum.veye.cc/post/4922</guid><dc:creator><![CDATA[nimadibaj]]></dc:creator><pubDate>Sat, 18 Oct 2025 07:13:39 GMT</pubDate></item><item><title><![CDATA[Reply to Veye MIPI imx462  Defaults on Sat, 18 Oct 2025 06:50:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nimadibaj" aria-label="Profile: nimadibaj">@<bdi>nimadibaj</bdi></a><br />
]]></description><link>http://forum.veye.cc/post/4921</link><guid isPermaLink="true">http://forum.veye.cc/post/4921</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Sat, 18 Oct 2025 06:50:15 GMT</pubDate></item><item><title><![CDATA[Reply to Veye MIPI imx462  Defaults on Sat, 18 Oct 2025 05:31:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> said in <a href="/post/4910">Veye MIPI imx462 Defaults</a>:</p>
<p dir="auto">This complies with the MIPI CSI-2 standard.</p>
<p dir="auto">Yes, you are right. The output of this module is MIPI standard. But we want to change its output mode. The ISP chip used in this module is currently working in LP mode (discontinuous clock mode). We want to change its mode to HS (continuous clock mode). Just give us the corresponding I2C command.</p>
]]></description><link>http://forum.veye.cc/post/4920</link><guid isPermaLink="true">http://forum.veye.cc/post/4920</guid><dc:creator><![CDATA[nimadibaj]]></dc:creator><pubDate>Sat, 18 Oct 2025 05:31:29 GMT</pubDate></item><item><title><![CDATA[Reply to Veye MIPI imx462  Defaults on Thu, 16 Oct 2025 00:54:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nimadibaj" aria-label="Profile: nimadibaj">@<bdi>nimadibaj</bdi></a><br />
UYVY  30fps</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nimadibaj" aria-label="Profile: nimadibaj">@<bdi>nimadibaj</bdi></a> said in <a href="/post/4908">Veye MIPI imx462 Defaults</a>:</p>
<p dir="auto">It seems that between each video line, the CSI-2 output from your module enters Low-Power (LP) mode, which causes the video stream to continuously drop in and out.</p>
]]></description><link>http://forum.veye.cc/post/4910</link><guid isPermaLink="true">http://forum.veye.cc/post/4910</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Thu, 16 Oct 2025 00:54:59 GMT</pubDate></item><item><title><![CDATA[Reply to Veye MIPI imx462  Defaults on Tue, 14 Oct 2025 08:02:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nimadibaj" aria-label="Profile: nimadibaj">@<bdi>nimadibaj</bdi></a></p>
<p dir="auto">We are analyzing the output signal. It seems that between each video line, the CSI-2 output from your module enters Low-Power (LP) mode, which causes the video stream to continuously drop in and out. The module is completely new, and we have not sent any I²C commands to it. It appears that the module should operate in High-Speed (HS) mode, but it does not.</p>
]]></description><link>http://forum.veye.cc/post/4908</link><guid isPermaLink="true">http://forum.veye.cc/post/4908</guid><dc:creator><![CDATA[nimadibaj]]></dc:creator><pubDate>Tue, 14 Oct 2025 08:02:18 GMT</pubDate></item></channel></rss>
