<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RAW-MIPI-IMX462M 在 RK3566(RADXA ZERO 3W)平台上尝试设置 fps_ex &lt; 1时读回异常，想确认是否支持 1fps以下长曝光]]></title><description><![CDATA[<p dir="auto">设备环境：</p>
<ul>
<li>模组型号：RAW-MIPI-IMX462M</li>
<li>平台：Radxa Zero 3E / RK35xx Debian</li>
<li>I2C bus：2</li>
<li>当前抓图链路：/dev/video0 + v4l2-ctl，RAW10(Y10)</li>
<li>使用脚本：mv_mipi_i2c_new.sh</li>
</ul>
<p dir="auto">需求：</p>
<p dir="auto">我现在在做夜空拍摄测试，希望把帧率降到 1 fps 以下，以获得更长曝光时间。<br />
文档中看到 <code>fps_ex</code> 支持更高精度帧率，并且主要用于长曝光模式，所以想尝试设置为 <code>0.5 fps</code>。</p>
<p dir="auto">我参考文档中的长曝光思路，做了如下操作：</p>
<ol>
<li>停止采集</li>
<li>设置手动曝光 / 手动增益</li>
<li>设置 <code>fps_ex=0.5</code></li>
<li>再开始采集</li>
</ol>
<p dir="auto">我的测试脚本大致如下：</p>
<pre><code class="language-bash">#!/bin/bash
BUS=2
WIDTH=1920
HEIGHT=1080
FPS_EX=${1:-0.5}
echo "stop capture"
sudo ./mv_mipi_i2c_new.sh -w imgacq 0 -b $BUS
sudo ./mv_mipi_i2c_new.sh -w imgdir 3 -b $BUS
echo "set roi"
v4l2-ctl -d /dev/v4l-subdev2 --set-ctrl roi_x=0
v4l2-ctl -d /dev/v4l-subdev2 --set-ctrl roi_y=0
echo "set stream mode"
v4l2-ctl -d /dev/v4l-subdev2 --set-ctrl trigger_mode=0
echo "set long exposure fps_ex"
sudo ./mv_mipi_i2c_new.sh -w fps_ex $FPS_EX -b $BUS
sudo ./mv_mipi_i2c_new.sh -r fps_ex -b $BUS
echo "set format"
media-ctl -d /dev/media0 --set-v4l2 "\"m00_b_mvcam ${BUS}-003b\":0[fmt:Y10_1X10/${WIDTH}x${HEIGHT}]"
echo "start capture"
sudo ./mv_mipi_i2c_new.sh -w imgacq 1 -b $BUS
echo "warmup stream..."
sleep 2
echo "done, fps_ex=$FPS_EX"
<p dir="auto">实际输出如下：</p>
<pre><code class="language-text">./init_camera_longexp.sh 0.5
stop capture
w image acq is 00
w image direction is 3
set roi
set stream mode
w fps 0.5000
r fps is -0.0001 fps
set format
start capture
w image acq is 01
warmup stream...
done, fps_ex=0.5
<p dir="auto">另外我再单独读取参数：</p>
<pre><code class="language-bash">sudo ./mv_mipi_i2c_new.sh -r fps -b 2
<p dir="auto">返回：</p>
<pre><code class="language-text">r fps is 1.00 fps
<p dir="auto">再读取：</p>
<pre><code class="language-bash">sudo ./mv_mipi_i2c_new.sh -r minfps -b 2
<pre><code class="language-text">r minfps @ current setting is -0.0001 fps
<p dir="auto">我目前的疑问：</p>
<ol>
<li>
<p dir="auto">RAW-MIPI-IMX462M 是否真正支持 <code>fps_ex &lt; 1</code> 的长曝光模式？</p>
</li>
<li>
<p dir="auto">当前 <code>r fps is -0.0001 fps</code> / <code>minfps = -0.0001 fps</code> 这种返回值，是否说明：</p>
<ul>
<li>当前模式下不支持低于 1 fps</li>
<li>或者读回接口存在异常</li>
<li>或者我的配置顺序不对</li>
</ul>
</li>
<li>
<p dir="auto">如果 IMX462 支持低于 1 fps，正确的配置流程应该是什么？</p>
</li>
<li>
<p dir="auto">是否还需要额外设置某些参数，例如：</p>
<ul>
<li>特定 readmode</li>
<li>特定 ROI</li>
<li>先查询某个 capability</li>
<li>或者必须使用 <code>fps_ex</code> 之外的方式</li>
</ul>
</li>
</ol>
<p dir="auto">补充说明：</p>
<ul>
<li>当前 <code>fps=1</code> 时，长曝光拍摄已经可以正常工作，并且通过增加曝光时间能采到更多星点。</li>
<li>现在只是希望进一步确认：IMX462 在当前固件/驱动下，是否能稳定工作在 <code>0.5 fps</code> 或更低帧率。</li>
</ul>
<p dir="auto">如果需要，我可以继续补充：</p>
<ul>
<li><code>version</code></li>
<li><code>model</code></li>
<li><code>fmtcap</code></li>
<li><code>readmodecap</code></li>
<li><code>exptime_range</code></li>
<li>以及实际抓图测试结果。</li>
</ul>
]]></description><link>http://forum.veye.cc/topic/721/raw-mipi-imx462m-在-rk3566-radxa-zero-3w-平台上尝试设置-fps_ex-1时读回异常-想确认是否支持-1fps以下长曝光</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 05:59:27 GMT</lastBuildDate><atom:link href="http://forum.veye.cc/topic/721.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 09 May 2026 15:22:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RAW-MIPI-IMX462M 在 RK3566(RADXA ZERO 3W)平台上尝试设置 fps_ex &lt; 1时读回异常，想确认是否支持 1fps以下长曝光 on Thu, 14 May 2026 02:24:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://forum.veye.cc/uid/2181">@jossen</a> 不客气。</p>
]]></description><link>http://forum.veye.cc/post/5090</link><guid isPermaLink="true">http://forum.veye.cc/post/5090</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Thu, 14 May 2026 02:24:48 GMT</pubDate></item><item><title><![CDATA[Reply to RAW-MIPI-IMX462M 在 RK3566(RADXA ZERO 3W)平台上尝试设置 fps_ex &lt; 1时读回异常，想确认是否支持 1fps以下长曝光 on Tue, 12 May 2026 12:02:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://forum.veye.cc/uid/1">@veye_xumm</a><br />
感谢您的答复，根据您的提示和命令，我成功将fps设置到1以下，使曝光时间设置变得更高了<img src="http://forum.veye.cc/plugins/nodebb-plugin-emoji/emoji/android/1f60a.png?v=fdtrinohgki" class="not-responsive emoji emoji-android emoji--blush" title=":blush:" alt="😊" /></p>
]]></description><link>http://forum.veye.cc/post/5089</link><guid isPermaLink="true">http://forum.veye.cc/post/5089</guid><dc:creator><![CDATA[jossen]]></dc:creator><pubDate>Tue, 12 May 2026 12:02:43 GMT</pubDate></item><item><title><![CDATA[Reply to RAW-MIPI-IMX462M 在 RK3566(RADXA ZERO 3W)平台上尝试设置 fps_ex &lt; 1时读回异常，想确认是否支持 1fps以下长曝光 on Mon, 11 May 2026 04:01:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="http://forum.veye.cc/uid/2181">@jossen</a><br />
这个版本，由于硬件设计的限制，下面是极限值。</p>
<table class="table table-bordered table-striped">
<thead>
<tr>
<th>Camera Model</th>
<th>Min Framerate</th>
<th>Max Exptime</th>
</tr>
</thead>
<tbody>
<tr>
<td>RAW-MIPI-IMX462M</td>
<td>0.12fps</td>
<td>8s</td>
</tr>
</tbody>
</table>
<p dir="auto">另外，这个型号，需要用fps来进行配置，不要用fps_ex功能。<br />
fps命令，支持到0.01的精度。<br />
因此，你使用</p>
<pre><code>sudo ./mv_mipi_i2c_new.sh -w fps 0.12 -b 2
<p dir="auto">进行参数配置。</p>
]]></description><link>http://forum.veye.cc/post/5088</link><guid isPermaLink="true">http://forum.veye.cc/post/5088</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Mon, 11 May 2026 04:01:42 GMT</pubDate></item></channel></rss>
