    VEYE-MIPI-IMX327S no image
    24 Posts 2 Posters 9.1k Views 1 Watching
      veye_xumm @Dan_LionKing
      @dan_lionking
      We have two main control chips on our camera, and we can use the following methods to confirm whether the programs on both chips are working properly:
      1. Read the device ID. The default value is 0x06, which can determine whether the FPGA is working.
      . / veye_mipi_i2c.sh-r-f devid.
      1. If the FPGA is OK, try the following cmd to check the other one.
      ./veye_mipi_i2c.sh -r -f agc
      The value should be 0xC if you have not changed it.
      If the 2 chips are both working.
      The only advice I can give you is to remove the two protection devices, as I wrote in the last post.
      • D Offline
        Dan_LionKing @veye_xumm
        • D Offline
          Dan_LionKing @Dan_LionKing
          @dan_lionking
          After remove the two protection devices the image appeared
          Thanks
            @dan_lionking
            You are welcome.
