    Is there any plan to support libcamera?
    25 Posts 2 Posters 11.4k Views 1 Watching
    • T Offline
      thn @veye_xumm
      A cable question, I want to test out the Raspberry Pi IO board with a CM4, but this IO board come with a 22 pins header connection instead of the 15 pin as in your camera.
      Could you advise a way to connect the 22 pin header into your camera? Which converter or cable should we use?
      Thanks,
        veye_xumm @thn
        @thn
        FFC22P-0.5MM-15CM-T
        http://wiki.veye.cc/index.php/FFC_Cable
        Generally, for retail cameras, we provide a yellow ffc cable, which is the one you need.
        • T Offline
          thn @veye_xumm
          I tried the cable that came in the retail package we purchased from Amazon. When I plugged the camera into the Raspberry Pi IO board with a CM4, the camera did not show up at /dev/video0 at all. This is using the very same MicroSD card to boot the Raspberry Pi 4.
          I must be missing something.
          • T Offline
            thn
            What should I do with these dmesg output?
            [ 8.850954] veyecam2m: loading out-of-tree module taints kernel.
            [ 9.228770] veyecam2m 10-003b: camera id is veyecam2m
            [ 9.230589] veyecam2m 10-003b: sensor is IMX385
            [ 9.230616] veyecam2m 10-003b: board type is ONE board
            [ 9.231135] veyecam2m 10-003b: Consider updating driver veyecam2m to match on endpoints
            [ 9.231782] veyecam2m 10-003b: veyecam2m camera probed
              veye_xumm @thn
              @thn Never mind, this can be ignored.
