    VEYE-MIPI-IMX385 with Raspberry 4 no pictures
    10 Posts 3 Posters 2.3k Views 1 Watching
    • S Offline
      StefanosMX
      Raspberry 4 2GB, 5.15.56-v71+
      camera connected with type B cable and extra power,
      enabled legacy mode, reboot
      ./enable_i2c_vc.sh, reboot
      ./camera_i2c_config
      but I cant make pictures:
      ~/r/v/bin (master)> ./veye_raspistill -o test.jpg
      Hardare version: b03115
      before create camera com sensor mode 0
      mmal: mmal_component_enable w 1920 h 1080 fps 30
      raspipreview_create com
      mmal: Splitter has 4 output port,you could use num 2,3 for extend
      HOW CAN I RESOLVE THIS?
      • S Offline
        salva
        Same problem on a zero w and imx462.
        SO is buster
        The camera is connected with the cable inside the box and power cables connected.
        Is possible to prepare a working image for the zero and the 462 to download for dummys?
          veye_xumm @StefanosMX
          @stefanosmx @salva
          Is there a preview image?
          I want to run this command first to see if the i2c channel was successfully established.
          i2cdetect -y 10
          Normally, there should be 3b present.
          S 3 Replies Last reply Reply Quote 0
          • S Offline
            StefanosMX @veye_xumm
            @veye_xumm Thank you for the fast answer. Will take some time to connect to a monitor, will try it out.
            Now the interesting thing: the sensorid was IMXffff. I investigated the thing with the protection devices, because maybe I made a wrong connection: I used an extension connector for the CSI cable. And how I understand it, when using two type B cables, what I did, then the order of the pins is reversed. With the AUX power this results in a short, if I am right. Now, after removing the protection devices the sensorid is IMX 385, after installing everything new. but the above problem with the error persists.
            • S Offline
              @veye_xumm there is no preview image.
              i2c:(master)> sudo i2cdetect -y 10
              0 1 2 3 4 5 6 7 8 9 a b c d e f
              00: -- -- -- -- -- -- -- --
              10: -- -- -- -- -- -- -- -- -- -- UU -- -- -- -- --
              20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
              30: -- -- -- -- -- -- -- -- -- -- -- 3b -- -- -- --
              40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
              50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
              60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
              70: -- -- -- -- -- -- -- --
              • S Offline
                The camera makes excellent pictures now, everything OK. I installed the 4mm M16 lens in the metal full glass lenses variant, very nice.
                2 errors were the cause:
                1. two CSI type B cables in series, dangerous!
                2. in the boot/config.txt there was an artefact from the Inno-maker IMX327 module: dtoverlay=imx290,clock-frequency=74250000, after it was inactivated (#dtoverlay=imx290,clock-frequency=74250000) the veye raspicam commands function flawlessly.
                  My problem is solved, lets see what we can do for the other guy SALVA with his IMX462 module.
                  @stefanosmx Glad to know it.
                  • S Offline
                    salva
                    When I test i2cdetect -y 10 get an empty result
                    Then it hangs until I do control-c
                    • S Offline
                      salva
                      Is working now!
                      I am sorry , I had connected the camera wire in the reverse way. Now is taking photos and video.
                        veye_xumm @salva
                        @salva OK
