    New Raspberry pi 5 support
    25 Posts 4 Posters 13.3k Views 1 Watching
      veye_xumm @Vaa
      @vaa
      In addition to this, the -b parameter needs to be added:
      -b [i2c bus num] i2c bus number
      • V Offline
        Vaa @veye_xumm
        @veye_xumm Thank you for your support!
        I got my application working good.
        Here is a receipt how can I achived this:
        1. ./media_setting_rpi5.sh veyecam2m
        2. ./veye_mipi_i2c.sh -b 6 -w -f yuvseq -p1 YUYV
        3. ./veye_mipi_i2c.sh -b 6 -w -f videoformat -p1 PAL
        4. In my app open device /dev/video0 with following parameters:
          width 1920;
          height 1080;
          pixel_format V4L2_PIX_FMT_UYVY (only this is working!!!)
          field_format V4L2_FIELD_NONE
        In case I try to set pixel_format to any other value is cause VIDIOC_STREAMON fail. I suppose this is a bug in the driver.
        Some other applications like gstreamer only set pixel_format if you directly point to do this, this is why it works, but many others (e.g. trying to set default pixel_format) are not.
        V 1 Reply Last reply Reply Quote 1
        • A Offline
          alex_ai @veye_xumm
          @veye_xumm said in New Raspberry pi 5 support:
          @alex_ai
          @alex_ai said in New Raspberry pi 5 support:
          any chances use configuration script ./veye_mipi_i2c.sh on RPi5?
          No. Just pay attention to i2c bus number.
          I think answer was "yes" but with parameter -b. I could not execute from bin dir because it compiled to another OS, so compile i2c_read, i2c_write from source code fixed my issue.
          @veye_xumm thank you for help and support!
            veye_xumm @alex_ai
            @alex_ai You are welcome.
            • V Offline
              Vaa @Vaa
              @vaa said in New Raspberry pi 5 support:
              Will you going to fix the issue?
