    SOLVED IMX287 FPS
    General Discussion
      mca312 last edited by
      https://www.veye.cc/en/product/mv-mipi-imx287m/#tab-id-1
      The FPS is listed at 319 but the sensor supports 523. Can I set the ADC bit to 8 to achieve this? 319 is for 12 bit.
      https://www.vision-dimension.com/media/pdf/f2/9b/a2/The-Imaging-Source-DMK-37AUX287_Sensor-Information-Sheet_imx287llr_1-0-en_US.pdf
      I would also like to mount a CS lens or an M12 lens. What is the dimension needed for the lens mount?
      Thank you, we are looking forward to purchasing 4 of these cameras from you.
        veye_xumm @mca312 last edited by
        @mca312 said in IMX287 FPS:
        We have achieved a frame rate of 720×544 @ 530fps RAW8 in our new firmware version.
        https://wiki.veye.cc/index.php/MV-MIPI-IMX287M_Data_Sheet
        Feel free to provide a note when placing your order, and we'd be happy to gift you an M12 holder.
        Regarding CS lenses, unfortunately, they are not supported at the moment. We have a C-MOUNT01 which is compatible with C-mount lenses. You will need to purchase it separately.
        1 Reply Last reply Reply Quote 1
