    SOLVED RaspberryPi OS 64-bit
    Raspberry Pi App Software
    • N
      natzguk last edited by
      Hi I am on 64-bit Raspberry Pi 4B
      Operating System: Debian GNU/Linux 12 (bookworm)
      Kernel: Linux 6.1.0-rpi6-rpi-v8
      Architecture: arm64
      Unfortunately I can not use VEYE-MIPI-X I2C.sh since i2c_read and i2c_write are only for 32bit. Is there any support for 64-bit planned?
        veye_xumm @natzguk last edited by
        @natzguk Hello, these two programs are written in C language, and the source code is provided in the directory. You just need to recompile them.
        • N
          newleaf @veye_xumm last edited by newleaf
          @veye_xumm For anyone else. This works perfectly. Note that when recompiling on 64-bit Pi, the following warning is produced. It still builds. Just copy the outputs to bin and the scripts work fine.
          ./make.sh
          i2c_read.c: In function ‘main’:
          i2c_read.c:112:35: warning: passing argument 4 of ‘i2c_rd’ from incompatible pointer type [-Wincompatible-pointer-types]
            112 |  i2c_rd(fd, device_addr,reg_addr, &value, num);
                |                                   unsigned char (*)[512]
          i2c_read.c:20:68: note: expected ‘unsigned char *’ but argument is of type ‘unsigned char (*)[512]’
             20 | static int i2c_rd(int fd, uint8_t i2c_addr, uint16_t reg, uint8_t *values, uint32_t n)
