imx462 driver update for raspberrypi 6.1.21-v8+
hello.
i am trying install driver on raspbian bullseye:
6.1.21-v8+following the steps -
https://wiki.veye.cc/index.php/Build_drivers_from_source_for_rpii did:
sudo apt update sudo apt full-upgrade sudo apt install raspberrypi-kernel-headers cd ~/rasp/driver_source/cam_drv_src/rpi-6.1.y makeafter that :
cd raspberrypi_v4l2/release/ sudo ./install_driver.sh veyecam2m rebootbut camera doesnt work:
dmesg | grep veye [ 0.068867] platform fe801000.csi: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/veyecam2m@3b [ 10.519453] veyecam2m: loading out-of-tree module taints kernel. [ 10.645721] veyecam2m 10-003b: probe failedwhat should be done in addition ?
ok, fixed that - i use cm4 so need to add to /boot/config.txt:
dtoverlay=veyecam2m dtoverlay=veyecam2m,cam0 -
@zoldaten Approve
