    SOLVED VEYE-MIPI-IMX462 WDR MODE GHOST PROBLEM
    • S
      SkySplitter last edited by
      When I enable wdrmode, ghost objects appear on the image. Is there any way to prevent this?
      Thanks,
        veye_xumm @SkySplitter last edited by
        @skysplitter said in VEYE-MIPI-IMX462 WDR MODE GHOST PROBLEM:
        wdrmode
        Can you take a picture to show me?
        • S
          SkySplitter @veye_xumm last edited by
          At the first one, WDR is enabled(wdrmode 0x03)
          and disabled at the second one(wdrmode 0x00)
          All other parameters are same. I think, the processor on board, can't process overlapping two frames for moving objects fast enough.
          What do you rhink ?
            @skysplitter
            Suggest you turn off the 3d noise reduction and do the test again.
            • S
              denoise is 0x00 so both 2D and 3D turned off. I turned them off because of the same problem, ghosts. Denoise uses overlapping for reducing noices. It is some kind of long exposure. Any suggestion but denoise ?
                @skysplitter It is recommended that you turn off the 3D denoise and wdr features if you have a relatively fast moving vehicle in your usage scenario. This is because these two features essentially use two frames of data to calculate.
                2d denoise can be turned on.
