    SOLVED rk3588开发板接RAW-MIPI-SC132M无法获取图片
    Rockchip App camera
    mipi raw-mipi-sc132m rk3588
    6285
    • J
      jihua last edited by
      模块上电后,查看触发模式是流模式,配置imgacq为1后,读取图片阻塞不动一直读取不到图片,用示波器测量lane clk pin无信号。
        veye_xumm @jihua last edited by
        @jihua
        请执行一下uname -r,把结果发上来。
        另外请检查一下你移植到的板子的mipi接口的原理图,用的哪个mipi接口,几lane的。 dts需要跟原理图对应起来才行。
        • J
          jihua @veye_xumm last edited by
          硬件接口如下:
          设备树配置如下:
          // SPDX-License-Identifier: (GPL-2.0+ OR MIT)
           * Copyright (c) 2020 Rockchip Electronics Co., Ltd.
          	vdd_cam2_5v: vdd-cam2-5v-regulator {
          		compatible = "regulator-fixed";
          		regulator-name = "vdd_cam_5v";
          		regulator-always-on;
          		regulator-boot-on;
          		regulator-min-microvolt = <3300000>;
          		regulator-max-microvolt = <3300000>;
          	cam2_dovdd: cam2-dovdd {
          		regulator-name = "cam_dovdd";
          		regulator-boot-on;
          		regulator-min-microvolt = <1800000>;
          		regulator-max-microvolt = <1800000>;
          		vin-supply = <&vdd_cam2_5v>;
          	cam2_avdd: cam2-avdd {
          		regulator-name = "cam_avdd";
          		regulator-boot-on;
          		regulator-min-microvolt = <2800000>;
          		regulator-max-microvolt = <2800000>;
          	cam2_dvdd: cam2-dvdd {
          		regulator-name = "cam_dvdd";
          		regulator-boot-on;
          		regulator-min-microvolt = <1200000>;
          		regulator-max-microvolt = <1200000>;
          /* Link path: sensor->csi2_dphy0->mipi2_csi2->rkcif_mipi_lvds2--->rkcif_mipi_lvds2_sditf->rkisp0_vir2 */
          &i2c6 {
          	status = "okay";
          	pinctrl-names = "default";
          	pinctrl-0 = <&i2c6m3_xfer>;
              mvcam: mvcam@3b{
                     compatible = "veye,mvcam";
                     reg = <0x3b>;
                     //clocks = <&cru CLK_MIPI_CAMARAOUT_M1>;
                     //clock-names = "xvclk";
                     //pinctrl-names = "default";
                     //pinctrl-0 = <&mipim1_camera1_clk>;
                     power-domains = <&power RK3588_PD_VI>;
                     //power-gpios = <&gpio4 RK_PB5 GPIO_ACTIVE_LOW>;
                     reset-gpios = <&gpio4 RK_PB2 GPIO_ACTIVE_HIGH>;
                     pwdn-gpios = <&gpio4 RK_PA7 GPIO_ACTIVE_HIGH>;
                     //avdd-supply = <&vcc_mipidcphy0>;
                     //firefly,clkout-enabled-index = <0>;
                     port {
                              mvcam_out0: endpoint {
                                     remote-endpoint = <&mipidphy0_in_ucam0>;
                                     data-lanes = <1 2>;
          &csi2_dphy0_hw {
          	status = "okay";
          &csi2_dphy0 {
          	status = "okay";
          	ports {
          		#address-cells = <1>;
          		#size-cells = <0>;
          		port@0 {
          			reg = <0>;
          			#size-cells = <0>;
          			mipidphy0_in_ucam0: endpoint@1 {
          				reg = <1>;
          				remote-endpoint = <&mvcam_out0>;
          				data-lanes = <1 2>;
          		port@1 {
          			reg = <1>;
          			#size-cells = <0>;
          			csidphy0_out: endpoint@0 {
          				reg = <0>;
          				remote-endpoint = <&mipi2_csi2_input>;
          &mipi2_csi2 {
          	status = "okay";
          	ports {
          		#size-cells = <0>;
          		port@0 {
          			reg = <0>;
          			#size-cells = <0>;
          			mipi2_csi2_input: endpoint@1 {
          				reg = <1>;
          				remote-endpoint = <&csidphy0_out>;
          		port@1 {
          			reg = <1>;
          			#size-cells = <0>;
          			mipi2_csi2_output: endpoint@0 {
          				reg = <0>;
          				remote-endpoint = <&cif_mipi2_in0>;
          &rkcif {
          	status = "okay";
          &rkcif_mipi_lvds2 {
          	status = "okay";
          	port {
          		cif_mipi2_in0: endpoint {
          			remote-endpoint = <&mipi2_csi2_output>;
          &rkcif_mipi_lvds2_sditf {
          	status = "disabled";
          	port {
          		mipi_lvds2_sditf: endpoint {
          			remote-endpoint = <&isp1_vir0>;
          &rkcif_mmu {
          	status = "okay";
          &rkisp1 {
          &isp1_mmu {
          &rkisp1_vir0 {
          	port {
          		#size-cells = <0>;
          		isp1_vir0: endpoint@0 {
          			reg = <0>;
          			remote-endpoint = <&mipi_lvds2_sditf>;
            @jihua 按照我们之前在飞凌板子上的经验,你第一个帖子上的错误提示无关的。
            dts和原理图的对应关系的问题,你用的那个板子上有没有自带的支持的sensor?可作为参考。或者把之前系统自带的dts发个我对比看看。
            一个终端取图,另一个终端运行一下dmesg,看看报什么错误吗?
            • J
              取图时的信息和dmesg信息如下:
              下面是原来系统里的设备树,接imx415是通的:
              	ext_cam2_37m_clk: external-camera-37m-clock {
              		compatible = "fixed-clock";
              		clock-frequency = <37125000>;
              		clock-output-names = "ext_cam_37m_clk";
              		#clock-cells = <0>;
              	ext_cam2_25m_clk: external-camera-25m-clock {
              		clock-frequency = <25000000>;
              		clock-output-names = "ext_cam_25m_clk";
              		#clock-cells = <0>;
              	ext_cam2_24m_clk: external-camera-24m-clock {
              		#clock-cells = <0>;
              		clock-frequency = <24000000>;
              		clock-output-names = "ext_cam_24m_clk";
              		regulator-boot-on;
              		regulator-boot-on;
              		regulator-boot-on;
              		regulator-boot-on;
              &i2c6 {
              	status = "okay";
              	dw9714: dw9714@c {
              		status = "okay";
              		compatible = "dongwoon,dw9714";
              		reg = <0xc>;
              		rockchip,vcm-max-current = <100>;
              		rockchip,vcm-start-current = <0>;
              		rockchip,vcm-rated-current = <100>;
              		rockchip,vcm-step-mode = <0xd>;
              		rockchip,vcm-dlc-enable = <0>;
              		rockchip,vcm-mclk = <0>;
              		rockchip,vcm-t-src = <0>;
              	ov5647: ov5647@36 {
              		compatible = "ovti,ov5647";
              		reg = <0x36>;
              		clocks = <&ext_cam2_25m_clk>;
              		clock-names = "ext_cam_25m_clk";
              		pwdn-gpios = <&gpio4 RK_PA7 GPIO_ACTIVE_LOW>;
              		lens-focus = <&dw9714>;
              		port {
              			ov5647_out: endpoint {
              				remote-endpoint = <&dphy0_in_ov5647>;
              				data-lanes = <1 2>;
              	ov5648: camera@36 {
              		compatible = "ovti,ov5648";
              		reg = <0x36>;
              		clocks = <&ext_cam2_24m_clk>;
              		dovdd-supply= <&cam2_dovdd>; /* 1.8v */
              		avdd-supply = <&cam2_avdd>;  /* 2.8v */
              		dvdd-supply = <&cam2_dvdd>;  /* 1.2v */
              		reset-gpios = <&gpio4 RK_PB2 GPIO_ACTIVE_LOW>;
              		rotation = <180>;
              		rockchip,camera-module-index = <2>;
              		rockchip,camera-module-name = "THDS11073";
              		rockchip,camera-module-lens-name = "Largan-40122a1";
              		port {
              			/* MIPI CSI-2 bus endpoint */
              			ov5648_out: endpoint {
              				remote-endpoint = <&dphy0_in_ov5648>;
              				clock-lanes = <0>;
              				data-lanes = <1 2>;
              	ov8858: ov8858@36 {
              		compatible = "ovti,ov8858";
              		reg = <0x36>;
              		rotation = <180>;
              		rockchip,camera-module-name = "HS5885-BNSM1018-V01";
              		rockchip,camera-module-lens-name = "default";
              		port {
              			ov8858_out: endpoint {
              				remote-endpoint = <&dphy0_in_ov8858>;
              				clock-lanes = <0>;
              				data-lanes = <1 2>;
              	ov13850: ov13850@10 {
              		compatible = "ovti,ov13850";
              		reg = <0x10>;
              		rotation = <180>;
              		rockchip,camera-module-name = "ZC-OV13850R2A-V1";
              		rockchip,camera-module-lens-name = "Largan-50064B31";
              		port {
              			ov13850_out: endpoint {
              				remote-endpoint = <&dphy0_in_ov13850>;
              				clock-lanes = <0>;
              				data-lanes = <1 2>;
              	imx415_2: imx415-2@1a {
              		compatible = "sony,imx415";
              		status = "okay";
              		reg = <0x1a>;
              		clocks = <&ext_cam2_37m_clk>;
              		dovdd-supply = <&cam2_dovdd>;
              		reset-gpios = <&gpio1 RK_PB2 GPIO_ACTIVE_LOW>;
              		rockchip,camera-module-name = "CMK-OT2022-PX1";
              		rockchip,camera-module-lens-name = "IR0147-50IRC-8M-F20";
              		port {
              			imx415_out2: endpoint {
              				remote-endpoint = <&dphy0_in_imx415>;
              				data-lanes = <1 2 3 4>;
              &csi2_dphy0_hw {
              	status = "okay";
              &csi2_dphy0 {
              	status = "okay";
              	ports {
              		#size-cells = <0>;
              		port@0 {
              			reg = <0>;
              			#size-cells = <0>;
              			dphy0_in_ov5648: endpoint@1 {
              				reg = <1>;
              				remote-endpoint = <&ov5648_out>;
              				data-lanes = <1 2>;
              			dphy0_in_ov8858: endpoint@2 {
              				reg = <2>;
              				remote-endpoint = <&ov8858_out>;
              				data-lanes = <1 2>;
              			dphy0_in_ov13850: endpoint@3 {
              				reg = <3>;
              				remote-endpoint = <&ov13850_out>;
              				data-lanes = <1 2>;
              			dphy0_in_ov5647: endpoint@4 {
              				reg = <4>;
              				remote-endpoint = <&ov5647_out>;
              				data-lanes = <1 2>;
              			dphy0_in_imx415: endpoint@5 {
              				reg = <5>;
              				remote-endpoint = <&imx415_out2>;
              		port@1 {
              			reg = <1>;
              			#size-cells = <0>;
              				reg = <0>;
              &mipi2_csi2 {
              	status = "okay";
              	ports {
              		#size-cells = <0>;
              		port@0 {
              			reg = <0>;
              			#size-cells = <0>;
              				reg = <1>;
              		port@1 {
              			reg = <1>;
              			#size-cells = <0>;
              				reg = <0>;
              &rkcif {
              	status = "okay";
              &rkcif_mipi_lvds2 {
              	status = "okay";
              	port {
              	status = "okay";
              	port {
              &rkcif_mmu {
              	status = "okay";
              &rkisp1 {
              	status = "okay";
              &isp1_mmu {
              	status = "okay";
              &rkisp1_vir0 {
              	status = "okay";
              	port {
              		#size-cells = <0>;
              			reg = <0>;
                veye_xumm @jihua last edited by veye_xumm
                @jihua dts这么看,看不出啥问题。
                你是不是有一个转接板,这个板子原理应该没问题的吧?
                另外你现在接我们sc132,启动之后
                dmesg | grep mvcam
                dmesg | grep rkcif
                发给我看一下
                • J
                  执行指令结果如下:
                  硬件是有转接板的,量过了线序是对应的上的:
                  e879d659-7b46-4beb-96cd-039196f1506c-e764d81e-9d1c-4ba5-b1ca-151e0dcfba18.jpg [图片]
                    @jihua
                    1处排线插歪了。
                    2处的排线没有用处建议去掉,保证mipi信号的质量。
                    • J
                      读取相机的datarate返回是-1代表什么意思。
                        @jihua 应该是这个版本的固件还没有支持这个寄存器。不影响正常出图和对接的。
                        • J
                          内核打印的信息显示datarate是1.5G,用示波器测量不到时钟波形,只能测到数据波形,这个模块的实际datarate是多少的?现在抓图的时候,内核驱动报crc错误,怀疑是排线太长或者datarate对不上。
                            @jihua
                            按照1.5G配置是没问题的,我们在多个rk3588上面都调通的。
                            你用的排线是多长的?可否拍个照片我看看。
                            • J
                              排线长度有26厘米长
                              d573eebf-ed60-4955-872c-b7609ef8ecc0-ad04fd8f-6c28-4da6-a785-2304d7f0e416.jpg [图片]
                                @jihua 线长也没有很夸张。你测测摄像头这端,入口地方的3.3V供电,实际电压是多少?
                                • J
                                  VCC3V3 测量到是3.3V,MIPI_CK_N 时钟是固定的吗?时钟是多少的?设置帧率后这个时钟会变吗?
                                    @jihua 相机是固定的1188M,3588那头设置为1500M是没问题的。
                                    你把现在报的错发给我看看。
                                    • J
                                      获取一张图片报错
                                        @jihua 我们在rk平台没有遇到过这个问题。看ecc2这个错误提示的话,像是mipi信号劣化了。
