    GX-MIPI-IMX662 can't save fps parameter
    25 Posts 2 Posters 6.2k Views 1 Watching
      veye_xumm @alex_ai
      @alex_ai
      I'd like to first confirm your firmware version with you. As shown below, everything is working fine on my end.
      pi@raspberrypi:~/gx_product_tool $ ./gx_mipi_i2c.sh -r snsreg 0x3070
      Read Sensor Reg 0x3070, val=0x0
      pi@raspberrypi:~/gx_product_tool $ ./gx_mipi_i2c.sh -r snsreg 0x3071
      Read Sensor Reg 0x3071, val=0x0
      pi@raspberrypi:~/gx_product_tool $ ./gx_mipi_i2c.sh -r version
      Read version is C 01.32 and L 01.19
      Regarding the image quality during IR-cut switching, may I ask whether you are using the same IR-cut filter for both the IMX662 and the IMX462? Also, could you share some sample images with me?
      A 1 Reply Last reply Reply Quote 0
      • A Offline
        alex_ai @veye_xumm
        the version is same :
        rms@raspberrypi10:~/source/raspberrypi_v4l2/gx_i2c_tools $  ./gx_mipi_i2c.sh -r version
        Also updated and rebuilt source code - same result (only one difference I see : you are using gx_product_tool folder, for me it is gx_i2c_tools)
        We use F0.95 lenses on our cameras and remove the IR-cut filter to capture more starlight. The downside is that we can only achieve perfect focus for either visible or infrared light, though sharp focus is still possible for each individually. In our setup, we compromise by focusing somewhere in between.
        We see this exact behavior on our IMX462, IMX462 mono (VEYE), and IMX662 mono (another vendor ) sensors. However, on the color IMX662 sensor, I am unable to get a sharp focus at all. It feels as if the visible light and infrared light from the star interfere with each other simultaneously, making the image constantly blurry.
        I thought I could at least use this camera with an IR-cut filter, but for some reason, the stars became extremely dim. I am not sure if this is a software issue, or if the color Starvis 2 sensor simply handles light differently.
        See the sample photos below (please note - it is stack of 8 seconds) :
        imx662 without IR filter and no focus
        imx662 with IR filter and stars extremely dim
        and my imx662 mono sensor, without IR filter
          veye_xumm @alex_ai
          @alex_ai
          For your use case, I'd suggest giving it a try — reduce the denoise2d and denoise3d values, or even set them to 0. At the same time, you can also try lowering the sharpen value.
          • A Offline
            alex_ai @veye_xumm
            Hi @veye_xumm ,
            All my tests for parameters denoise2d, denoise3d and sharppen already have 0 value.
            Also played with all parameters in veye_viewer (very useful app) - no luck
              veye_xumm @alex_ai
              @alex_ai Sure, I'll keep an eye on this issue going forward. Thanks for your feedback.
