    UNSOLVED MV-MIPI-SC130M抓图报错
    • 乔
      乔康 last edited by
      同样的板卡和摄像头,之前使用rk3588旧的sdk编译的镜像,推流正常。
      rk3588瑞芯微官方sdk升级,内核成为5.10.226.在veye官网的git网站中下载了最新的设备树和驱动。
      root@ema:/home/ema# dmesg | grep mvcam
      [ 1.245944] Machine model: WF RK3588 lai002-f mvcam 2026-04-01 10:30
      [ 3.837270] mvcam 1-003b: veye mv series camera driver version: 01.01.08
      [ 3.837288] mvcam 1-003b: Failed to get reset-gpios, maybe no use
      [ 4.840804] mvcam 1-003b: camera is: MV-MIPI-SC130M
      [ 4.841718] mvcam 1-003b: firmware version: 0x1350200
      [ 4.847956] mvcam 1-003b: mvcam_get_mipifeature:lanecap 0x2 lane num 2, datarate 1500000000 bps
      [ 4.847976] mvcam 1-003b: Success to get mvcam endpoint data lanes, dts uses 4 lanes,will set to camera
      [ 4.858259] mvcam 1-003b: mvcam_enum_controls success
      [ 4.909381] rockchip-csi2-dphy csi2-dphy0: dphy0 matches m00_b_mvcam 1-003b:bus type 5
      驱动正常加载。虽然设备树是4lane的。
      使用下面指令抓图时,3个报错刷屏。
      v4l2-ctl --device=/dev/video0 --stream-mmap --stream-count=1 --stream-to=test.raw
      [ 965.570282] rockchip-mipi-csi2 mipi2-csi2: stream on, src_sd: 00000000b3c95298, sd_name:rockchip-csi2-dphy0
      [ 965.570307] rockchip-mipi-csi2 mipi2-csi2: stream ON
      [ 965.590697] (0xfdd30000)MIPI_CSI2 ERR1:0x1000000 (crc,vc: 0)
      [ 965.590726] (0xfdd30000)MIPI_CSI2 ERR2:0x100 (ecc,vc: 0)
      [ 968.450710] (0xfdd30000)MIPI_CSI2 ERR1:0x100 (f_seq,vc: 0)
        veye_xumm @乔康 last edited by
        @乔康
        @乔康 said in MV-MIPI-SC130M抓图报错:
        问题就在这里,MV-MIPI-SC130M不支持4lane模式配置。 你需要更换设备树为2lane模式。
