    Install camera to rpi4
    14 Posts 3 Posters 5.1k Views 1 Watching
    • V Offline
      Viktor
      Hi Meng,
      I am trying to test veye imx327 with rpi4.
      What OS version does it support? Ubuntu Desktop/Server 64bit is ok or i should install rpi os 32bit?
      And then if Ubuntu supports, how to install drivers?
      Can you explain main steps? It is building from source?
      That manual only for Rpi OS? http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_for_Raspberry_Pi
      Best regards, Viktor.
        veye_xumm @Viktor
        @viktor
        Hi Viktor,
        We use Pi OS32 bit for now. We support two application scenarios:
        1. veye_raspcam toolkit:
          Do not need any driver. It's raspcam like toolkit.
        2. v4l2 driver:
          v4l2 driver is provided. We test it on piOS 32bit.
        Here is the application index.
        http://wiki.veye.cc/index.php/Raspberry_Pi_Application_Note_Index
        If you want to use this camera on ubuntu OS or piOS 64bit, please try to build from sources, I will help you if necessary.
        V 2 Replies Last reply Reply Quote 0
        • V Offline
          Viktor @veye_xumm
          I have tried:
          crosscompile kinux image veye327 driver for Ubuntu Desktop 21.04 Rpi4
          on rpi4
          uname -r
          5.11.0-1008-raspi
          uname -a
          Linux number 5.11.0-1008-raspi #8-Ubuntu SMP PREEMPT Thu May 6 17:46:38 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux
          on host
          sudo apt install git bc bison flex libssl-dev make libc6-dev libncurses5-dev crossbuild-essential-arm64
          mkdir rpi_ubuntu_source
          cd rpi_ubuntu_source
          git clone --depth=1 git://git.launchpad.net/~ubuntu-kernel/ubuntu/+source/linux-raspi/+git/hirsute
          git clone https://github.com/veyeimaging/raspberrypi_v4l2.git
          cp raspberrypi_v4l2/driver_source/cam_drv_src/rpi-5.x_all/veye327.c hirsute/drivers/media/i2c
          edit hirsute/drivers/media/i2c/Kconfig
          find section imx219 and after it add:
          config VIDEO_VEYE327
          	tristate "VEYE VEYE327 sensor support"
          	depends on I2C && VIDEO_V4L2
          	select MEDIA_CONTROLLER
          	select VIDEO_V4L2_SUBDEV_API
          	select V4L2_FWNODE
          	help
          	  This is a Video4Linux2 sensor driver for the VEYE
          	  IMX327 camera.
          	  To compile this driver as a module, choose M here: the
          	  module will be called veye327.
          edit hirsute/drivers/media/i2c/Makefile
          find line imx219 and after it add:
          obj-$(CONFIG_VIDEO_VEYE327)	+= veye327.o
          cp raspberrypi_v4l2/driver_source/dts/rpi-5.10.y/veye327-overlay.dts hirsute/arch/arm64/boot/dts/overlays
          edit hirsute/arch/arm64/boot/dts/overlays/Makefile
          veye327.dtbo \
          build
          cd hirsute
          KERNEL=kernel8
          make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- bcm2711_defconfig
          make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- menuconfig
          got to Device Drivers --> Multimedia Support --> Media ancillary drivers --> Camera sensor devices
          select veye327 and save
          make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- Image modules dtbs -j4
          copy image and dtb
          on rpi4 replace vmlinuz-* with compiled hirsute/arch/arm64/boot/Image
          on rpi4 copy to /boot/firmware/overlays dtb file hirsute/arch/arm64/boot/dst/overlays/veye327.dtbo
          Before was imx219 connected and it works on Ubuntu Desktop 21.04 rpi4 as /dev/video0
          Was replaced imx219 to veye327E.
          After reboot rpi4 loaded but /dev/video0 gone.
          Can you help me to understand what files i need to copy?
          May be config, system.map, initrd or other dtb files?
          • V Offline
            Viktor @veye_xumm
            • V Offline
              Viktor @Viktor
              Here is rpi boot contents:
              number@number:/boot$ ls
              config-5.11.0-1008-raspi  dtb-5.11.0-1008-raspi  grub
              System.map-5.11.0-1008-raspi
              config.txt
              dtbs
              initrd.img
              vmlinuz-5.11.0-1008-raspi
              dtb
              firmware
              initrd.img-5.11.0-1008-raspi
              • V Offline
                Viktor @Viktor
                I tried installing veye327 to rpiOs.
                I have 5.10.36 firmware. veye drivers don't have this version.
                I tried build from source, but failed.
                Copied built zImage and veye327.dtbo to rpi and got load kernel modules failed on startup.
                Updated: i did modules_install and veye327 works on rpiOs now.
                Can you help build kernel for Ubuntu Desktop Rpi?
                • V Offline
                  Viktor @Viktor
                  I did it.
                  on rpi4
                  uname -r
                  5.11.0-1008-raspi
                  uname -a
                  on host
                  git clone --depth=1 git://git.launchpad.net/~ubuntu-kernel/ubuntu/+source/linux-raspi/+git/hirsute linux
                  cp raspberrypi_v4l2/driver_source/cam_drv_src/rpi-5.x_all/veye327.c linux/drivers/media/i2c
                  edit linux/drivers/media/i2c/Kconfig
                  	select V4L2_FWNODE
                  	help
                  	  IMX327 camera.
                  edit linux/drivers/media/i2c/Makefile
                  cp raspberrypi_v4l2/driver_source/dts/rpi-5.10.y/veye327-overlay.dts linux/arch/arm64/boot/dts/overlays
                  edit linux/arch/arm64/boot/dts/overlays/Makefile
                  veye327.dtbo \
                  build kernel
                  cd linux
                  KERNEL=kernel8
                  go to Device Drivers --> Multimedia Support --> Media ancillary drivers --> Camera sensor devices
                  mount sd to host
                  mkdir mnt
                  mkdir mnt/fat32
                  mkdir mnt/ext4
                  sudo mount /dev/sdd1 mnt/fat32
                  sudo mount /dev/sdd2 mnt/ext4
                  copy modules
                  sudo env PATH=$PATH make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- INSTALL_MOD_PATH=mnt/ext4 modules_install
                  copy kernel and dtb
                  sudo cp mnt/fat32/vmlinuz mnt/fat32/vmlinuz.old
                  sudo cp arch/arm64/boot/Image mnt/fat32/vmlinuz
                  sudo cp arch/arm64/boot/dts/broadcom/*.dtb mnt/fat32/
                  sudo cp arch/arm64/boot/dts/overlays/*.dtb* mnt/fat32/overlays/
                  sudo cp arch/arm64/boot/dts/overlays/README mnt/fat32/overlays/
                  sudo umount mnt/fat32
                  sudo umount mnt/ext4
                  on rpi4
                  edit /boot/firmware/config.txt
                  add lines
                  gpu_mem=400
                  dtparam=i2c_vc=on
                  cma=128M
                  dtoverlay=veye327.dtbo
                  start_x=1
                  sudo reboot
                  dmesg | grep veye
                  veye327 probed
                  preview
                  gst-launch-1.0 v4l2src device=/dev/video0 ! "video/x-raw,format=(string)UYVY, width=(int)1920, height=(int)1080,framerate=(fraction)30/1" ! videoconvert ! autovideosink sync=false text-overlay=false -v
                  success
                  V F 2 Replies Last reply Reply Quote 0
                  • V Offline
                    Viktor @Viktor
                    Add to /etc/modules
                    i2c-dev
                    i2c bus 10,11 for sensor control
                      veye_xumm @Viktor
                      @viktor
                      Great! Thank you for trying and sharing.
                      • V Offline
                        Viktor @veye_xumm
                        • F Offline
                          fire @Viktor
                          @viktor
                          Thanks very much.
                          I wonder how did you set camera parameters, I found that the cs_mipi_i2c.sh not working.
                          • V Offline
                            Viktor @fire
                            @fire Veye327 i2c fully works.
                            • F Offline
                              fire @Viktor
                              @viktor
                              Can you use the original pi commands (e.g. raspistill raspivid), instead of using gst-launch?
                              • V Offline
                                Viktor @fire
                                @fire Yes, raspivid and raspistill works too on Ubuntu.
