    SOLVED New Raspberry pi 5 support
    10681
    • A
      • A
        • A
          Also after every RPi restart have to run script: ./media_setting_rpi5.sh veyecam2m
          @veye_xumm any chances use configuration script ./veye_mipi_i2c.sh on RPi5?
            veye_xumm @Vaa last edited by
            @vaa
            Are you going to improve your driver's compatibility?
              @alex_ai
              V A 2 Replies Last reply Reply Quote 0
              • V
                Vaa @veye_xumm last edited by
                  @vaa
                  • V
                    Vaa @veye_xumm last edited by Vaa
                    Here is a receipt how can I achived this:
                    1. ./media_setting_rpi5.sh veyecam2m
                    2. ./veye_mipi_i2c.sh -b 6 -w -f yuvseq -p1 YUYV
                    3. ./veye_mipi_i2c.sh -b 6 -w -f videoformat -p1 PAL
                    4. In my app open device /dev/video0 with following parameters:
                      width 1920;
                      height 1080;
                      field_format V4L2_FIELD_NONE
                    Some other applications like gstreamer only set pixel_format if you directly point to do this, this is why it works, but many others (e.g. trying to set default pixel_format) are not.
                    V 1 Reply Last reply Reply Quote 1
                    • A
                      @veye_xumm said in New Raspberry pi 5 support:
                      @alex_ai
                      I think answer was "yes" but with parameter -b. I could not execute from bin dir because it compiled to another OS, so compile i2c_read, i2c_write from source code fixed my issue.
                      @veye_xumm thank you for help and support!
                        @alex_ai You are welcome.
                        • V
                          Vaa @Vaa last edited by
                          Will you going to fix the issue?
