SOLVED New Raspberry pi 5 support
Also after every RPi restart have to run script: ./media_setting_rpi5.sh veyecam2m@veye_xumm any chances use configuration script ./veye_mipi_i2c.sh on RPi5?
Are you going to improve your driver's compatibility?
@vaa
Here is a receipt how can I achived this:-
./veye_mipi_i2c.sh -b 6 -w -f yuvseq -p1 YUYV
./veye_mipi_i2c.sh -b 6 -w -f videoformat -p1 PAL
In my app open device /dev/video0 with following parameters:
width 1920;
height 1080;
field_format V4L2_FIELD_NONE
Some other applications like gstreamer only set pixel_format if you directly point to do this, this is why it works, but many others (e.g. trying to set default pixel_format) are not. -
@veye_xumm said in New Raspberry pi 5 support:
I think answer was "yes" but with parameter -b. I could not execute from bin dir because it compiled to another OS, so compile i2c_read, i2c_write from source code fixed my issue.
@veye_xumm thank you for help and support! -
@alex_ai You are welcome.
Some other applications like gstreamer only set pixel_format if you directly point to do this, this is why it works, but many others (e.g. trying to set default pixel_format) are not.Will you going to fix the issue?
