    SOLVED 在Xavier-NX定制载板上使用sc132
    • J
      jianping last edited by
      您好,
      我在NX的定制载板上使用sc132。之前已经在改载板上配置了RPI Camera V2 相机,可以正常使用。我根据sc132的配置信息,修改了dts文件,但是没有识别sc132相机。以下是log信息。帮我看看是哪里有问题。
      nvidia@nvidia-desktop:~$ dmesg | grep cssc132
      [ 2.030830] cssc132 1-0010: probing v4l2 sensor
      [ 2.031136] cssc132 1-0010: tegracam sensor driver:cssc132_v2.0.6
      [ 2.031649] cssc132 1-0010: cs_sc132_board_setup: error during i2c read probe (-121)
      [ 2.031653] cssc132 1-0010: board setup failed
      [ 2.031733] cssc132: probe of 1-0010 failed with error -121
      [ 3.348546] cssc132 8-0010: probing v4l2 sensor
      [ 3.348763] cssc132 8-0010: tegracam sensor driver:cssc132_v2.0.6
      [ 3.348991] cssc132 8-0010: cs_sc132_board_setup: error during i2c read probe (-121)
      [ 3.348994] cssc132 8-0010: board setup failed
      [ 3.349084] cssc132: probe of 8-0010 failed with error -121
        veye_xumm @jianping last edited by
        @jianping
        还是i2c不通。
        按照log,您修改的dts文件,应该是按照
        1. i2c总线1和8访问摄像头,这个需要您确认跟硬件的设计一致。
        2. 摄像头的device address,您配置为0x10,这个跟我们模组不一致。我们模组的i2c地址是0x3b。
        • J
          jianping @veye_xumm last edited by
          安装您说的,我修改成0x3b,现在正常了。用什么命令打开相机呢,是用nvgstcapture1.0打开相机吗?
          [ 1.958535] cssc132 1-003b: probing v4l2 sensor
          [ 1.958895] cssc132 1-003b: tegracam sensor driver:cssc132_v2.0.6
          [ 1.960410] cssc132 1-003b: read sensor id 0132
          [ 1.960415] cssc132 1-003b: camera id is cs-mipi-sc132
          [ 1.960455] cssc132 1-003b: Detected CS_MIPI_SC132 camera
          [ 3.246782] cssc132 8-003b: probing v4l2 sensor
          [ 3.247026] cssc132 8-003b: tegracam sensor driver:cssc132_v2.0.6
          [ 3.247278] cssc132 8-003b: cs_sc132_board_setup: error during i2c read probe (-121)
          [ 3.247280] cssc132 8-003b: board setup failed
          [ 3.247341] cssc132: probe of 8-003b failed with error -121
          [ 3.263053] tegra194-vi5 15c10000.vi: subdev cssc132 1-003b bound
            @jianping
            http://wiki.veye.cc/index.php/VEYE_CS_Camera_for_Jetson_TX2#Gstreamer_Usage
            可以先试试这个。其他的参考上面的这个链接。
            gst-launch-1.0 v4l2src ! "video/x-raw,format=(string)UYVY, width=(int)1280, height=(int)1080, framerate=(fraction)45/1" ! nvvidconv ! "video/x-raw(memory:NVMM),format=(string)I420" ! nvoverlaysink sync=false
