    CS-USB-IMX307 OpenCV 連續採集影像造成 USB disconnct
    Scheduled Pinned Locked Moved USB camera
    53 Posts 2 Posters 29.1k Views 1 Watching
    • C Offline
      coolmitch @coolmitch
      @coolmitch 我用另一個別的廠牌的 uvc camera 可以這樣設定。
      v4l2-ctl -d /dev/video1 --all
      Driver Info (not using libv4l2):
      Driver name : uvcvideo
      Card type : USB Camera
      Bus info : usb-70090000.xusb-2.1
      Driver version: 4.9.201
      Capabilities : 0x84200001
      Video Capture
      Streaming
      Extended Pix Format
      Device Capabilities
      Device Caps : 0x04200001
      Video Capture
      Streaming
      Extended Pix Format
      Priority: 2
      Video input : 0 (Camera 1: ok)
      Format Video Capture:
      Width/Height : 1280/720
      Pixel Format : 'MJPG'
      Field : None
      Bytes per Line : 0
      Size Image : 1843200
      Colorspace : sRGB
      Transfer Function : Default (maps to sRGB)
      YCbCr/HSV Encoding: Default (maps to ITU-R 601)
      Quantization : Default (maps to Full Range)
      Flags :
      Crop Capability Video Capture:
      Bounds : Left 0, Top 0, Width 1280, Height 720
      Default : Left 0, Top 0, Width 1280, Height 720
      Pixel Aspect: 1/1
      Selection: crop_default, Left 0, Top 0, Width 1280, Height 720
      Selection: crop_bounds, Left 0, Top 0, Width 1280, Height 720
      Streaming Parameters Video Capture:
      Capabilities : timeperframe
      Frames per second: 30.000 (30/1)
      Read buffers : 0
      brightness 0x00980900 (int) : min=-64 max=64 step=1 default=0 value=0
      contrast 0x00980901 (int) : min=0 max=100 step=1 default=38 value=38
      saturation 0x00980902 (int) : min=0 max=100 step=1 default=60 value=60
      hue 0x00980903 (int) : min=-180 max=180 step=1 default=0 value=%(#ff0000)[50]
      white_balance_temperature_auto 0x0098090c (bool) : default=1 value=1
      gamma 0x00980910 (int) : min=100 max=500 step=1 default=440 value=440
      gain 0x00980913 (int) : min=0 max=128 step=1 default=40 value=40
      power_line_frequency 0x00980918 (menu) : min=0 max=2 default=1 value=2
      white_balance_temperature 0x0098091a (int) : min=2800 max=6500 step=10 default=4600 value=4600 flags=inactive
      sharpness 0x0098091b (int) : min=0 max=100 step=1 default=80 value=80
      backlight_compensation 0x0098091c (int) : min=0 max=2 step=1 default=0 value=1
      exposure_auto 0x009a0901 (menu) : min=0 max=3 default=3 value=3
      exposure_absolute 0x009a0902 (int) : min=50 max=10000 step=1 default=166 value=50 flags=inactive
      exposure_auto_priority 0x009a0903 (bool) : default=0 value=1
      focus_absolute 0x009a090a (int) : min=0 max=1023 step=1 default=68 value=68 flags=inactive
      focus_auto 0x009a090c (bool) : default=1 value=1
      aaeon@aaeon2-desktop:/var/log$ v4l2-ctl -d /dev/video1 --set-ctrl=hue=0
      aaeon@aaeon2-desktop:/var/log$ v4l2-ctl -d /dev/video1 --all
      Video Capture
      Streaming
      Extended Pix Format
      Device Capabilities
      Video Capture
      Streaming
      Extended Pix Format
      Priority: 2
      Field : None
      Bytes per Line : 0
      Colorspace : sRGB
      Flags :
      Pixel Aspect: 1/1
      Read buffers : 0
      hue 0x00980903 (int) : min=-180 max=180 step=1 default=0 %(#ff0000)[value=0]
        veye_xumm @coolmitch
        @coolmitch
        我的意思是,冒用这个协议。 这个需要单独给你做一个版本的固件升级包,现在的版本当然是不支持了。
        • C Offline
          coolmitch @veye_xumm
          @veye_xumm 我的意思是,就目前的版本,我也無法去設定他的值(但在其他的攝像頭可以設定)。所以是否改的冒用的版本也不能用?
            @coolmitch
            当然,会可以。
            • C Offline
              @veye_xumm 那是否也能把 power_line_frequency 也放進去支援 60hz ? 或是如果是特製版,那能直接把預設做成 60hz 嗎?
              veye_xummV 3 Replies Last reply Reply Quote 0
              • C Offline
                @veye_xumm 另一個想法,如果仿照這作法,camera 收到 USB 0x5514 做 reset (reboot) 可行嗎?
                  @coolmitch
                  可以默认支持60hz。回头我们做个定制版本你试试。
                  • C Offline
                    @veye_xumm 好地,感謝。
                      @coolmitch 现在默认值就是60hz.
                        @coolmitch
                        https://app.mediafire.com/tdaitlbvew6cu
                        v4l2-ctl -d /dev/video0 --set-ctrl=hue=0
                        可以实现重启。
                        • C Offline
                            @coolmitch
                            这个条纹是稳定不动的吧? 那么就是跟你的60Hz匹配的。
                            这个问题我找了一个资料给你看一下。
                            现在的问题是,你的灯光强度不仅随交流电变化,而且本身的强度又比较强。
                            这种情况下,如果还是维持曝光时间大于1/120s,那么就可能产生过曝的问题。
                            所以这种现象一定环境下属于没办法解决的正常现象。 你可以换更小的光圈的镜头来解决。
                            • C Offline
                              @veye_xumm 好的,我再觀察比較ㄧ下不同環境跟不同攝像頭看看。
