    OpenCV. Crop and change resolution to increase FPS
    9 Posts 5 Posters 3.2k Views 1 Watching
    • V Offline
      vladislav
      Hello! The example on OpenCV is very slow on RPI4 and RPI3B+ according to allocate memory. Not important which relolution I choose, because example copy full hd resolution. It's a big problem, I think.
        veye_xumm @vladislav
        @vladislav
        You're right. The demo does have this problem.
        We now provide the v4l2 driver mode.
        http://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi
        Whether it is helpful to the application of opencv, please refer to it.
        In addition, the camera output is now in UYVY format by default. Will it be helpful to the application of opencv if I YUYV format ?
        T J 2 Replies Last reply Reply Quote 0
        • T Offline
          tj @veye_xumm
          @veye_xumm Changing to YUYV may be helpful for some programs that expect a grayscale image first. I noticed a new firmware version has an option for changing to YUYV. Is it already possible to enable this with an i2c command?
            veye_xumm @tj
            @tj
            http://wiki.veye.cc/index.php/CS-MIPI-IMX307_version_log
            firmwarever >=2.38 will support yuyv mode.
            Please upgrade the cs_mipi_i2c.sh from github.
            http://wiki.veye.cc/index.php/CS-MIPI-X_i2c#yuvseq
            • T Offline
              tj @veye_xumm
              @veye_xumm Thanks, I forgot to update the script from Github 🤦
              • J Offline
                jk @veye_xumm
                @veye_xumm Is it possible to switch to YUYV on VEYE-MIPI-327 ?
                  veye_xumm @jk
                  @jk
                  hi,VEYE-MIPI-327 do not support this feature.
                  VEYE-MIPI-327S support and it is our recommended model for the future.
                  http://wiki.veye.cc/index.php/VEYE-MIPI-327S_STARVIS_Module_index
                  • M Offline
                    MK @veye_xumm
                    Are there plans to implement resolution at 720p and higher framerates (60fps) as with the imx307?
                      veye_xumm @MK
                      @mk No such plan, this cannot be supported. Sorry.
