    SOLVED JETSON NANO编译IMX307 driver和dts报错问题
    • J
      jdx-jdx last edited by
      NANO软件版本: r32.6.1
      原生SDK环境编译正常
      按照指导的以下步骤加入imx307的driver和dts后,编译报错
      1. 加载驱动
        cp $RELEASE_PACK_DIR/drivers_source/cam_drv_src/* $NVIDIA_PATH/drivers/media/i2c/
        cp $RELEASE_PACK_DIR/drivers_source/kernel_veyecam_config_<l4t_version> $L4T_DIR/sources/kernel/kernel-4.9/arch/arm64/configs/tegra_veyecam_defconfig
      2. 加载dts
      #for Nano
      cp $RELEASE_PACK_DIR/Nano/JetPack_<ver>_Linux_JETSON_NANO_DEVKIT/dts\ dtb/common/t210/* -r $NANO_DTS_PATH/
      cp $RELEASE_PACK_DIR/Nano/JetPack_<ver>_Linux_JETSON_NANO_DEVKIT/dts\ dtb/<camera model>/tegra210-porg-plugin-manager.dtsi -r $NANO_DTS_PATH/porg/kernel-dts/porg-plugin-manager
      1. 编译
      2. 错误信息如下
      nano编译imx307 dts报错.txt
        veye_xumm last edited by veye_xumm
        @jdx-jdx
        你好,我们这边编译是没问题的。
        根据你这个错误,感觉是少了什么东西。
        上面几个命令里面的变量,你都正确替换了吗
          DTC     arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a00.dtb
        ERROR (phandle_references): Reference to non-existent node or label "cam_module1"
        ERROR (phandle_references): Reference to non-existent node or label "csimx307_cam0"
        ERROR (phandle_references): Reference to non-existent node or label "csimx307_cam1"
        ERROR (phandle_references): Reference to non-existent node or label "cam_module1_drivernode0"
        • J
          jdx-jdx @veye_xumm last edited by
          替换过的
          加载dts
          cp $RELEASE_PACK_DIR/Nano/JetPack_4.6_Linux_JETSON_NANO_DEVKIT/dts\ dtb/common/t210/* -r $NANO_DTS_PATH/
          cp $RELEASE_PACK_DIR/Nano/JetPack_4.6_Linux_JETSON_NANO_DEVKIT/dts\ dtb/CS-MIPI-IMX307/tegra210-porg-plugin-manager.dtsi -r $NANO_DTS_PATH/porg/kernel-dts/porg-plugin-manager
          编译方法不太一样, 我是使用如下方法:
          #将kernel_src压缩包解压到此目录下Linux_for_Tegra/source
          export CROSS_COMPILE_AARCH64_PATH=/home/wen/workspace/project/gcc/gcc-linaro-6.4.1-2017.08-x86_64_aarch64-linux-gnu
          编译
          cd Linux_for_Tegra/source
          source nvbuild.sh
          【这样方式,编译原生的sdk环境是正常的; 但是加载你们的dts后报错了】
          • J
            jdx-jdx @jdx-jdx last edited by
            @jdx-jdx
            已经解决了
            不好意思
              veye_xumm @jdx-jdx last edited by
              @jdx-jdx 恭喜,没关系!
