    UNSOLVED rasp pi3 + SC132 - capture only works once
    • J
      jean_vid last edited by
      I am trying to get the SC132 to work with the rasp pi 3B+, I couldn't get it to work on Buster but I managed to get it working on Bullseye.
      I did enable legacy video mode in both cases.
      The problem is that it works once on Bullseye (2-3 times if I'm lucky), then it stops working, I tried to send a reset command through the i2c interface but once it stops working I can't get it to work again, I have to reboot the Raspberry Pi.
      Here are the logs:
      BUSTER
      `pi@raspberrypi:~uname -a
      Linux raspberrypi 5.15.43-v7+ #1558 SMP Thu May 26 16:10:12 BST 2022 armv7l GNU/Linux
      pi@raspberrypi:~/veye/i2c_cmd/bin $ cat /etc/os-release
      PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="10"
      VERSION="10 (buster)"
      VERSION_CODENAME=buster
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      pi@raspberrypi:~/veye/i2c_cmd/bin $ ./cs_mipi_i2c.sh -r -f devid
      hardwareid is 0x 2
      pi@raspberrypi:~/veye/i2c_cmd/bin $ ./cs_mipi_i2c.sh -r -f hwver
      NOT SUPPORTED!
      pi@raspberrypi:~/veye/i2c_cmd/bin $ ./cs_mipi_i2c.sh -r -f hdver
      hardware logic version is 0x34
      pi@raspberrypi:~/veye/i2c_cmd/bin $ ./cs_mipi_i2c.sh -r -f productmodel
      PRODUCT MODEL is CS-MIPI-SC132
      pi@raspberrypi:~/veye/i2c_cmd/bin $ ./cs_mipi_i2c.sh -r -f firmwarever
      r firmware version is  2.38
      pi@raspberrypi:~/veye/i2c_cmd/bin $ ./cs_mipi_i2c.sh -r -f mipistatus
      r mipi count 8272, mipi state 1
      pi@raspberrypi:~/veye/veye_raspcam/bin $ ./veye_raspipreview
      before create camera com time out 5000
      Hardare version: a02082
      mmal: mmal_component_enable w 1920 h 1080 fps 30
       raspipreview_create  com
      ^Cmmal: Aborting program
      BULLSEYE
      user@raspberrypi:~ $cat /etc/os-release
      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=raspbian
      ID_LIKE=debian
      user@raspberrypi:~ $ uname -a
      user@raspberrypi:~ $ cat veye-rec-120.sh
      #! /bin/sh
      ./veye/i2c_cmd/bin/camera_i2c_config
      rm /dev/shm/test.h264
      ./veye/veye_raspcam/bin/veye_raspivid -w 640 -h 480 -fps 120 -o /dev/shm/test.h264
      ls -l /dev/shm/test.h264
      user@raspberrypi:~ $ ./veye-rec-120.sh   # ->works
      setting GPIO for board revsion: a02082
      Raspberry Pi3B / Pi3B+ / 3A
      Set state of 133 to 1
      Use i2c-10 for the sensor (-y 10)
      camera num -1
      mmal: mmal_component_enable w 640 h 480 fps 120
      mmal: Splitter has 4 output port,you could use num 2,3 for extend
      mmal: running now!!
      mmal: running stop!! 0
      -rw-r--r-- 1 user user 1401681  1 juin  22:15 /dev/shm/test.h264
      user@raspberrypi:~ $ ./veye-rec-120.sh  # ->does not work
      camera num -1
      I recently did a apt upgrade and a rpi-update.
      I downloaded the veye software from the github repo last week, so I think I'm pretty up to date.
      Any idea where the problem comes from?
      it's ok if it onlye works on bullseye but I need to be able to launch it several times reliably without any problems.
      Regards
        veye_xumm @jean_vid last edited by
        @jean_vid
        The veye_raspicam series software itself does not call the i2c command to configure the camera working mode.
        So you need to use the following command first to configure the videofmt of the camera and then call veye_raspicam series software to get the image.
        http://wiki.veye.cc/index.php/CS-MIPI-X_i2c
