bitrate CS-MIPI-IMX307 module
Hi. The datasheet states that CS-MIPI-IMX307 outputs a format of 1920*1080, 1 pixel = RAW-10 or RAW-12 bits. bitrate for full-HD 1080p and 60 fps is 891Mbps/line (CSI-2).
Your module with this sensor outputs YUV422-8bit. 1 pixel = 16 bit. what output frequency does the pin for mipi_clk have? -
@pavel_fpga
mipi clk :297Mhz
data speed: 594Mbps/lan
CS-MIPI-IMX307 support 1080p@30fps -
@veye_xumm does the frequency change depending on the selected format? 1080p and 30 fps, 720p and 60 fps, or 640x480 and 130 fps
@pavel_fpga It does not change.
