树莓派5b & 2个sc132 相机,拍照问题
HZCU@raspberrypi:~ $ v4l2-ctl -L -d /dev/v4l-subdev2
User Controls
trigger_mode 0x00981901 (int) : min=0 max=2 step=1 default=1 value=0 flags=volatile, execute-on-write trigger_src 0x00981902 (int) : min=0 max=1 step=1 default=1 value=0 flags=volatile, execute-on-write soft_trgone 0x00981903 (button) : value=0 flags=write-only, execute-on-write frame_rate 0x00981904 (int) : min=0 max=120 step=1 default=120 value=120 flags=volatile, execute-on-write roi_x 0x00981905 (int) : min=0 max=1016 step=8 default=0 value=0 roi_y 0x00981906 (int) : min=0 max=1216 step=4 default=0 value=0Camera Controls
camera_orientation 0x009a0922 (menu) : min=0 max=2 default=2 value=2 (External) flags=read-only 0: Front 1: Back 2: External camera_sensor_rotation 0x009a0923 (int) : min=0 max=0 step=1 default=0 value=0 flags=read-onlyImage Processing Controls
link_frequency 0x009f0901 (intmenu): min=0 max=0 default=0 value=0 (1500000000 0x59682f00) 0: 1500000000 (0x59682f00) pixel_rate 0x009f0902 (int64) : min=750000000 max=750000000 step=1 default=750000000 value=750000000 flags=read-onlyHZCU@raspberrypi:~ $ v4l2-ctl -d /dev/video0 --set-fmt-video=width=1024,height=1280,pixelformat=GREY --stream-mmap --stream-count=1 --stream-to=y8-1024x1280.raw
VIDIOC_STREAMON returned -1 (Invalid argument) -
- 请问
./media_setting_rpi5.sh你是带着哪些参数执行的? - 执行以下
./find_entity.sh发一下结果。 - 执行完
./media_setting_rpi5.sh之后,用media-ctl -
p -d /dev/mediaX (其中X是上一步打印出来的值),然后把结果贴上来看看。
- 请问
您好
1、./media_setting_rpi5.sh文件我没有更改
#!/bin/bashI2CBUS_CAM1=4
I2CBUS_CAM0=6#default params of YUV_type cameras
WIDTH_YUV=1920
HEIGHT_YUV=1080
MEDIA_FMT_YUV=UYVY8_1X16
PIXEL_FMT_YUV=UYVY#default params of MV_type cameras
WIDTH_MV=1280
HEIGHT_MV=1024
MEDIA_FMT_MV=Y8_1X8
PIXEL_FMT_MV=GREY
2、执行./find_entity.sh
HZCU@raspberrypi:~/Desktop/raspberrypi_v4l2/rpi5_scripts $ ./find_entity.sh
Found mvcam @ i2c-4 entity on /dev/media2
Plese get frame from /dev/video0 and use /dev/v4l-subdev2 for camera setting.
3、执行完./media_setting_rpi5.sh,
HZCU@raspberrypi:~/Desktop/raspberrypi_v4l2/rpi5_scripts $ ./media_setting_rpi5.sh
This is a Raspberry Pi 5.
Usage: ./media_setting_rpi5.sh veyecam2m/csimx307/cssc132/mvcam -fmt [UYVY/RAW8/RAW10/RAW12] -w [width] -h [height]
This shell script is designed to detect the connection of a camera on Raspberry Pi 5.
It utilizes media-ctl and v4l2-ctl commands to configure the linking relationships and data formats of the media pad.
Once completed, you can directly use /dev/video0 or /dev/video8 to obtain image data.
4、media-ctl -p -d /dev/media2
HZCU@raspberrypi:~/Desktop/raspberrypi_v4l2/rpi5_scripts $ media-ctl -p -d /dev/media2
Media controller API version 6.1.63Media device information
driver rp1-cfe
model rp1-cfe
serial
bus info platform:1f00128000.csi
hw revision 0x114666
driver version 6.1.63Device topology
entity 1: csi2 (8 pads, 8 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
pad0: Sink
[fmt:SRGGB10_1X10/640x480 field:none colorspace:raw xfer:none ycbcr:601 quantization:full-range]
<- "mvcam 4-003b":0 [ENABLED,IMMUTABLE]
pad1: Sink
[fmt:unknown/8192x1 field:none]
pad2: Sink
pad3: Sink
pad4: Source
-> "rp1-cfe-csi2_ch0":0 []
-> "pisp-fe":0 []
pad5: Source
-> "rp1-cfe-embedded":0 []
pad6: Source
-> "rp1-cfe-csi2_ch2":0 []
-> "pisp-fe":0 []
pad7: Source
-> "rp1-cfe-csi2_ch3":0 []
-> "pisp-fe":0 [] -
entity 10: pisp-fe (5 pads, 7 links)
device node name /dev/v4l-subdev1
pad0: Sink
[fmt:SRGGB16_1X16/640x480 field:none colorspace:raw xfer:none ycbcr:601 quantization:full-range]
<- "csi2":4 []
<- "csi2":6 []
<- "csi2":7 []
pad1: Sink
[fmt:FIXED/8192x1 field:none]
<- "rp1-cfe-fe_config":0 []
pad2: Source
-> "rp1-cfe-fe_image0":0 []
pad3: Source
-> "rp1-cfe-fe_image1":0 []
pad4: Source
-> "rp1-cfe-fe_stats":0 [] -
entity 16: mvcam 4-003b (1 pad, 1 link)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev2
pad0: Source
[fmt:Y8_1X8/1024x1280 field:none colorspace:rec709
crop.bounds:(0,0)/1080x1280
crop:(0,0)/1024x1280]
-> "csi2":0 [ENABLED,IMMUTABLE] -
entity 18: rp1-cfe-csi2_ch0 (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
<- "csi2":4 [] -
entity 22: rp1-cfe-embedded (1 pad, 1 link)
device node name /dev/video1
pad0: Sink
<- "csi2":5 [] -
entity 26: rp1-cfe-csi2_ch2 (1 pad, 1 link)
device node name /dev/video2
pad0: Sink
<- "csi2":6 [] -
entity 30: rp1-cfe-csi2_ch3 (1 pad, 1 link)
device node name /dev/video3
pad0: Sink
<- "csi2":7 [] -
entity 34: rp1-cfe-fe_image0 (1 pad, 1 link)
type Node subtype V4L flags 1
device node name /dev/video4
pad0: Sink
<- "pisp-fe":2 [] -
entity 38: rp1-cfe-fe_image1 (1 pad, 1 link)
device node name /dev/video5
pad0: Sink
<- "pisp-fe":3 [] -
entity 42: rp1-cfe-fe_stats (1 pad, 1 link)
device node name /dev/video6
pad0: Sink
<- "pisp-fe":4 [] -
entity 46: rp1-cfe-fe_config (1 pad, 1 link)
device node name /dev/video7
pad0: Source
-> "pisp-fe":1 []
其余的一些信息
VIDIOC_STREAMON returned -1 (Invalid argument)HZCU@raspberrypi:~ $ dmesg | grep mvcam
[ 3.077392] rp1-cfe 1f00110000.csi: found subdevice /axi/pcie@120000/rp1/i2c@88000/veyemvcam@3b
[ 3.081206] rp1-cfe 1f00128000.csi: found subdevice /axi/pcie@120000/rp1/i2c@80000/veyemvcam@3b
[ 3.145470] veye_mvcam: loading out-of-tree module taints kernel.
[ 3.148379] mvcam 4-003b: veye mv series camera driver version: 01.01.04
[ 3.153600] mvcam 4-003b: Unable to load veye_vbyone driver,will go on
[ 3.665752] mvcam 4-003b: camera is: RAW-MIPI-SC132M
[ 3.666514] mvcam 4-003b: firmware version: 0x1040000
[ 3.680173] mvcam 4-003b: mvcam_enum_controls success
[ 3.680855] rp1-cfe 1f00128000.csi: Using sensor mvcam 4-003b for capture
[ 3.692868] mvcam 6-003b: veye mv series camera driver version: 01.01.04
[ 3.705052] mvcam 6-003b: Unable to load veye_vbyone driver,will go on
[ 4.207041] mvcam: mvcam_read: Reading register 0x04 failed
[ 4.207052] mvcam 6-003b: failed to read chip id
[ 673.554515] Modules linked in: rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device algif_hash algif_skcipher af_alg bnep binfmt_misc hci_uart aes_ce_blk btbcm aes_ce_cipher brcmfmac ghash_ce gf128mul bluetooth sha2_ce sha256_arm64 sha1_ce brcmutil ecdh_generic ecc veye_mvcam(O) cfg80211 libaes raspberrypi_hwmon rfkill rpivid_hevc(C) rp1_cfe pisp_be v4l2_mem2mem v4l2_fwnode videobuf2_dma_contig v4l2_async videobuf2_memops videobuf2_v4l2 videobuf2_common videodev rp1_adc mc raspberrypi_gpiomem nvmem_rmem uio_pdrv_genirq uio i2c_dev fuse dm_mod ip_tables x_tables ipv6 spidev vc4 snd_soc_hdmi_codec drm_display_helper cec drm_dma_helper drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops i2c_brcmstb spi_bcm2835 snd_soc_core v3d gpu_sched snd_compress drm_shmem_helper snd_pcm_dmaengine snd_pcm snd_timer drm gpio_keys snd drm_panel_orientation_quirks backlight i2c_designware_platform i2c_designware_core
粗体字 -
./media_setting_rpi5.sh mvcam -fmt RAW8 -w 1024 -h 1280 -
好像可以了,给您添麻烦了 -
@mjyc 好的。
亲,目前两个相机都能拍照了,但是sudo reboot,重启后,又都不能拍照了了,需要重新./find_entity.sh,./media_setting_rpi5.sh XXX。 -
@mjyc
./media_setting_rpi5.sh XXX只有这个是必须要执行的。
上电之后,执行一次。
