    FPS change at midnight?
    5 Posts 2 Posters 2.1k Views 1 Watching
    • T Offline
      tj
      Another curiosity: I'm trying to record meteors at 720p@60fps, and somehow the system changed from 60fps to 30fps at exactly midnight. I didn't change anything during the capture since I was asleep. I also checked that the script on the raspberry kept running, also the raspberry did not reboot.
      Could this be due to a nightly reboot of the camera? I did not specify it to reboot.
        veye_xumm @tj
        @tj
        (⊙﹏⊙),The camera will not change mode or reboot itself. Please check your script first.
        • T Offline
          tj @veye_xumm
          I'll try to reproduce first. Unfortunately my disk was full just before midnight tonight (Murphy's law). Longer frames here are probably due to high CPU load in the rest of the pipeline. Better luck next night.
          • T Offline
            tj @tj
            This problem seems to have solved itself, I cannot reproduce it.
              veye_xumm @tj
              @tj
              OK. If there is any new situation, please communicate with me again.
