    NVidia Jetson Jetpack 6 support?
    55 Posts 3 Posters 40.1k Views 2 Watching
    • O Offline
      Otca @veye_xumm
      @veye_xumm i did try the other cameras and i got the same results
        veye_xumm @Otca
        @otca
        Based on the current situation, it seems unlikely that the camera module is damaged because the probability of both cameras failing at the same time is very low. Do you have any other Jetson boards, or even a Raspberry Pi? If you do, you could try connecting the camera to them to determine if the camera is functioning properly.
        In addition, could you measure the voltage level of the following pin?
        O 1 Reply Last reply Reply Quote 0
        • O Offline
          Otca @veye_xumm
          @veye_xumm said in NVidia Jetson Jetpack 6 support?:
          Thanks for the suggestion! I do have other Jetson and Raspberry Pi boards available, so I’ll try connecting the camera to one of those to see if it’s working properly. By the way, I checked the J1-Pin11 voltage, and it reads 3.33V. If there are any other measurements or tests you think I should run, just let me know.
          • O Offline
            Otca @Otca
            Do u know this issue?
            • O Offline
              Otca @Otca
              Idk but i think this is helpful to know
              My jetson 24pin csi connector:
                veye_xumm @Otca
                @otca It looks like the driver is reporting an error. Suggest you don't use the jetson-io mechanism and try strictly following the steps on our wiki.
                • O Offline
                  Otca @veye_xumm
                  @veye_xumm well I done the whole process of jetson upgrade for MV-MIPI-IMX264M on another jetson orin nano jetpack 6 (5.15.136-tegra) and still the i2cdetect -y -r 9 and i2cdetect -y -r 10 returns the following:
                  i2cdetect -y -r 9
                       0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
                  00:                         -- -- -- -- -- -- -- --
                  10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                  20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                  30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                  40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                  50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                  60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                  70: -- -- -- -- -- -- -- --
                  i2cdetect -y -r 10
                  ls /sys/firmware/devicetree/base/bus@0/cam_i2cmux/i2c@0/
                  '#address-cells'   phandle              rbpcv3_mvcam_a@3b  '#size-cells'
                   name              rbpcv2_imx219_a@10   reg                 status
                  ls /sys/bus/i2c/drivers/
                  at24                fusb301     nxp-pca9450         sec_pmic
                  axp20x-i2c          ina3221     pca953x             simple-mfd-i2c
                  bd9571mwv           max732x     pca954x             smbus_alert
                  bq27xxx-battery     max77620    pf8x00              tpm_i2c_infineon
                  cros-ec-i2c         max8973     pfuze100-regulator  ucsi_ccg
                  cs2000-cp           mp8859      rk808               usb3503
                  dummy               mvcam       rohm-bd718x7        vc5
                  fan53555-regulator  nvvrs_pseq  rtc-ds3232
                  extLinux Config
                  LABEL imx264
                     MENU LABEL Ubuntu (MV-MIPI-IMX264)
                     LINUX /boot/Image
                     FDT /boot/dtb/kernel_tegra234-p3768-0000+p3767-0005-nv.dtb
                     INITRD /boot/initrd
                     APPEND ${cbootargs} root=PARTUUID=3354a552-d558-40fb-857c-8e1886cb2a67 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 nv-auto-config
                     OVERLAYS /boot/dtb/tegra234-p3767-camera-p3768-veye_mvcam-dual.dtbo
                  Upgarde Jetson Jetpack 6
                  My guess is that the drivers (.ko) are installed correctly but the device tree still need some works to do, because i don't detect the camera on my i2c.
                  These are the steps I have done till now:
                  sudo cp nvidia_jetson_veye_bsp/ko/$(uname -r)/downstream/i2c/* /lib/modules/$(uname -r)/updates/drivers/media/i2c/ -f
                  sudo cp nvidia_jetson_veye_bsp/ko/$(uname -r)/downstream/terga-camera/tegra-camera.ko /lib/modules/$(uname -r)/updates/drivers/media/platform/tegra/camera -f
                  sudo cp nvidia_jetson_veye_bsp/ko/$(uname -r)/upstream/*.ko /lib/modules/$(uname -r)/kernel/drivers/media/v4l2-core/ -f
                  sudo depmod
                  content of each folder is as follow:
                  ls /lib/modules/$(uname -r)/updates/drivers/media/i2c/
                  ar1335_common.ko  lt6911uxc.ko  nv_ar0234.ko    nv_imx274.ko  nv_ov5693.ko    veye_mvcam.ko
                  cs_imx307.ko      max9295.ko    nv_hawk_owl.ko  nv_imx318.ko  pca9570.ko      veye_vbyone.ko
                  cs_sc132.ko       max9296.ko    nv_imx185.ko    nv_imx390.ko  veyecam.ko      virtual_i2c_mux.ko
                  ds90ub954.ko      max96712.ko   nv_imx219.ko    nv_imx477.ko  veye_imx335.ko
                  ls /lib/modules/$(uname -r)/updates/drivers/media/platform/tegra/camera
                  tegra-camera.ko
                  ls /lib/modules/$(uname -r)/kernel/drivers/media/v4l2-core/
                  v4l2-async.ko  v4l2-dv-timings.ko  v4l2-fwnode.ko  v4l2-h264.ko  v4l2-mem2mem.ko  videodev.ko
                  I am clueless what it is wrong here.
                  Thanks
                    veye_xumm @Otca
                    @otca
                    In fact, when the following pin is high, i2cdetect should be able to show 0x3b that the device is online. This has nothing to do with either ko or dtb.
                    So I'm wondering why this is the case with your board.
                    Also, with your current configuration, can you use sudo dmesg and send me all the outputs to look at?
                    veye_xummV O 2 Replies Last reply Reply Quote 0
                      veye_xumm @veye_xumm
                      @Otca
                      I wonder if it would be convenient for you to send me your jetson board along with a set of camera boards and we'll test them?
                      • O Offline
                        Otca @veye_xumm
                        thanks for your guidance.
                        The dmesg log is appended.
                        MV-MIPI-IMX264.txt
                        unfortunately I'm too far away from you.I'm so sorry that it's not an option for me to send board and camera.
                          veye_xumm @Otca
                          All of this still suggests that i2c is not working.
                          When I look at your other postings, they seem to say that the camera itself is fine and not broken, right?
                          • O Offline
                            Otca @veye_xumm
                            @veye_xumm indeed the camera is fine. i can refrence you to my jetson nano b01 issue.
                            https://forum.veye.cc/topic/634/jetson-nano-b01-mv-imx264/5
                            Now what should i do in order to make the jetson orin nano jetpack 6 (r36.3) works with the IMX264?
                            Thanks alot
                              veye_xumm @Otca
                              @otca
                              I have a suggestion, you re-burn the jetson orin system and then don't do any configuration with jetson-io, follow the steps on our wiki exactly step by step.
                              If the i2c still doesn't work, I can only suspect that your board has a damaged hardware interface to the i2c.
                              • O Offline
                                Otca @veye_xumm
                                @veye_xumm now I have used new fresh jetpack 6.0 (R36.3) on jetson orin NX.
                                here is dmesg log.
                                I have detected camera and it has shown itself on i2c, but still I have some issues to get the video stream.
                                sudo dmesg| grep -i 'mvcam'
                                [    7.284769] mvcam 9-003b: veye mv series camera driver version: 01.01.04
                                [    7.786350] veye_mvcam: mvcam_read: Reading register 0x04 failed
                                [    7.786363] mvcam 9-003b: failed to read chip id
                                [    7.786367] mvcam 9-003b: mvcam_identify_module failed.
                                [    7.786928] mvcam 10-003b: veye mv series camera driver version: 01.01.04
                                [    8.288616] mvcam 10-003b: camera is: MV-MIPI-IMX264M
                                [    8.289601] mvcam 10-003b: firmware version: 0x1410206
                                [    8.295434] tegra-camrtc-capture-vi tegra-capture-vi: subdev mvcam 10-003b bound
                                [  354.885790] mvcam 10-003b: csi2_try format
                                [  354.885832] mvcam 10-003b: csi2_try format
                                [  354.885835] mvcam 10-003b: mvcam_csi2_get_fmt_idx_by_code success
                                [  354.963253] mvcam 10-003b: camera_common_mclk_enable: no device power rail
                                [  354.963265] mvcam 10-003b: camera_common_s_power: failed to enable mclk
                                [  373.489937] mvcam 10-003b: camera_common_mclk_disable: no device power rail
                                [  758.620283] mvcam 10-003b: csi2_try format
                                [  758.620326] mvcam 10-003b: csi2_try format
                                [  758.620332] mvcam 10-003b: mvcam_csi2_get_fmt_idx_by_code success
                                [  758.712221] mvcam 10-003b: camera_common_mclk_enable: no device power rail
                                [  758.712233] mvcam 10-003b: camera_common_s_power: failed to enable mclk
                                [  766.783908] mvcam 10-003b: camera_common_mclk_disable: no device power rail
                                Full DMESG Log:
                                IMX264.OrinNX.txt
                                i2cdetect -y -r 10
                                30: -- -- -- -- -- -- -- -- -- -- -- UU -- -- -- --
                                VLC:
                                I closed vlc manually after 3 seconds.
                                vlc
                                VLC media player 3.0.16 Vetinari (revision 3.0.13-8-g41878ff4f2)
                                [0000aaab02f4e590] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
                                [0000aaab02fee350] main playlist: playlist is empty
                                Opening in BLOCKING MODE
                                ArgusV4L2_Open failed: No such file or directory
                                [0000ffff44001150] v4l2 demux error: cannot get streaming parameters: Inappropriate ioctl for device
                                [0000ffff4c000ca0] main input error: Invalid PCR value in ES_OUT_SET_(GROUP_)PCR !
                                Segmentation fault (core dumped)
                                DTB :
                                 cat /boot/extlinux/extlinux.conf
                                TIMEOUT 30
                                DEFAULT imx264
                                MENU TITLE L4T boot options
                                LABEL primary
                                      MENU LABEL primary kernel
                                      LINUX /boot/Image
                                      INITRD /boot/initrd
                                      APPEND ${cbootargs} root=PARTUUID=a321b5a8-b267-427e-8e1b-73b06c528581 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 nv-auto-config
                                LABEL imx264
                                      LINUX /boot/Image
                                      FDT /boot/dtb/kernel_tegra234-p3768-0000+p3767-0000-nv.dtb
                                      INITRD /boot/initrd
                                at24             dummy               max8973      pca954x             sec_pmic          vc5
                                axp20x-i2c       fan53555-regulator  mp8859       pf8x00              simple-mfd-i2c
                                bd9571mwv        fusb301             mvcam        pfuze100-regulator  smbus_alert
                                bq27xxx-battery  ina3221             nvvrs_pseq   rk808               tpm_i2c_infineon
                                cros-ec-i2c      max732x             nxp-pca9450  rohm-bd718x7        ucsi_ccg
                                cs2000-cp        max77620            pca953x      rtc-ds3232          usb3503
                                O veye_xummV 2 Replies Last reply Reply Quote 0
                                • O Offline
                                  Otca @Otca
                                  would u please give me the complete guide to build drivers needed for IMX264 on Orin NX 16GB?
                                  For Jetpack 6.0 R36.3, I didn't find any clear instruction on the wiki.
                                  Thanks
                                  • O Offline
                                    Otca @Otca
                                    I have successfully built the drivers for downstream/i2c on the Jetson Orin NX running Jetpack 6 (r36.3). Based on my testing, it appears that the issue is likely related to v4l2 in the upstream code, or possibly the tegra-camera.ko module.
                                    Could you kindly provide me with the source code for v4l2 so I can attempt to build it myself? Alternatively, if possible, please share the pre-built .ko module.
                                    Just to clarify, the board model I'm working with is the Jetson Orin NX, though v4l2 reports it as XAVIER 10-bit. I have also attached the relevant Dmesg log for your reference.
                                    Additionally, I’ve tried both the prebuilt .ko file from your Git repository and my own built version, but both resulted in the same issue. This suggests that the problem isn’t related to the downstream/i2c modules.
                                    Thanks in advance for your support!
                                    Dmesg Logs
                                    Dmesg_01.txt
                                    v4l2-ctl --list-formats-ext
                                    ioctl: VIDIOC_ENUM_FMT
                                    	Type: Video Capture
                                    	[0]: 'GREY' (8-bit Greyscale)
                                    		Size: Discrete 1920x1080
                                    			Interval: Discrete 0.033s (30.000 fps)
                                    	[1]: 'XY10' (XAVIER 10-bit/16-bit Greyscale)
                                    	[2]: 'XY12' (XAVIER 12-bit/16-bit Greyscale)
                                      veye_xumm @Otca
                                      @otca
                                      Based on your suggestion, I believe the driver is fine. Please try the following command to see if it can receive data properly.
                                      export WIDTH=2432
                                      export HEIGHT=2056
                                      export FPS=28
                                      v4l2-ctl --set-ctrl roi_x=0
                                      v4l2-ctl --set-ctrl roi_y=0
                                      v4l2-ctl --set-fmt-video=width=$WIDTH,height=$HEIGHT,pixelformat=GREY
                                      v4l2-ctl --set-ctrl frame_rate=$FPS
                                      v4l2-ctl --set-fmt-video=width=$WIDTH,height=$HEIGHT,pixelformat=GREY --stream-mmap --stream-count=-1 --stream-to=/dev/null
                                      If there are no issues, please refer to the link below and try capturing images using qV4l2 and a Python script. I remember that VLC had some problems with JetPack version 6.
                                      https://wiki.veye.cc/index.php/Mv_series_camera_appnotes_4_jetson#Preview_GREY_format_images_using_opencv
                                      • O Offline
                                        Otca @veye_xumm
                                        @veye_xumm Hi,
                                        this is the results:
                                        The following lines and corresponding Dmesg log:
                                        export WIDTH=2432
                                        export HEIGHT=2056
                                        export FPS=28
                                        Dmesg log:
                                        [   84.571478] mvcam 10-003b: csi2_try format
                                        [   84.571495] mvcam 10-003b: mvcam_csi2_get_fmt_idx_by_code success
                                        and The last line didnt run successfully:
                                        ####Dmesg of Last Line:
                                        I terminated the above command after 10 seconds.
                                        [  113.809582] mvcam 10-003b: csi2_try format
                                        [  113.809604] mvcam 10-003b: mvcam_csi2_get_fmt_idx_by_code success
                                        [  113.886292] mvcam 10-003b: camera_common_mclk_enable: no device power rail
                                        [  113.886304] mvcam 10-003b: camera_common_s_power: failed to enable mclk
                                        [  116.962475] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
                                        [  116.962505] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
                                        [  116.963052] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
                                        [  119.522644] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
                                        [  119.522668] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
                                        [  119.524143] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
                                        [  122.082687] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
                                        [  122.082714] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
                                        [  122.084142] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
                                        [  124.642482] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
                                        [  124.642508] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
                                        [  124.643091] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
                                        [  127.202701] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
                                        [  127.202723] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
                                        [  127.204101] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
                                        [  129.762461] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
                                        [  129.762476] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
                                        [  129.762955] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
                                        [  132.322481] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
                                        [  132.322507] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
                                        [  132.323031] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
                                        [  134.850487] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
                                        [  134.850507] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
                                        [  134.851082] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
                                        [  134.854840] mvcam 10-003b: camera_common_mclk_disable: no device power rail
                                        Full Dmesg log:
                                        Dmesg.txt
                                          veye_xumm @Otca
                                          @otca Please check the version of camera.
                                          https://wiki.veye.cc/index.php/Mv_mipi_i2c.sh_user_guide#version
                                          sudo ./mv_mipi_i2c.sh -r -f version -b 10
                                          • O Offline
                                            Otca @veye_xumm
                                            sure!
                                            version is C 01.41 and L 02.06
