    NVidia Jetson Jetpack 6 support?
    55 Posts 3 Posters 39.9k Views 2 Watching
      veye_xumm @Otca
      @otca
      The version is OK. Have you set the camera's operating mode? Please try this command:
      sudo ./mv_mipi_i2c.sh -r -f trgmode -b 10
      I did encounter images not being received properly due to compromised mipi signal quality caused by third party carrier board, but your board is supposed to be an official nvidia board, right?
      Could you please try connecting the camera to another csi port?
      O 1 Reply Last reply Reply Quote 0
      • O Offline
        Otca @veye_xumm
        @veye_xumm said in NVidia Jetson Jetpack 6 support?:
        sure I will try other CSI port and my board is Jetson Orin NX DeveloperKit (16GB). It's supported by VEYE and Nvidia.
        r trigger mode is 0
        I'll reboot and give you the result for other CSI
        • O Offline
          Otca @Otca
          I am experiencing an issue with CSI number 1. Specifically, it is not functioning properly on CSI-1, while everything works fine on CSI-0.
          I would appreciate it if you could provide insight into why this might be happening. Additionally, I would like to mention that the vlc component is working without any issues, so the problem seems isolated to CSI-1 in my case.
          v4l2-ctl --set-fmt-video=width=$WIDTH,height=$HEIGHT,pixelformat=GREY --stream-mmap --stream-count=-1 --stream-to=/dev/null
          <<<<<<<<<<<<<<<<<<<<<<<<<<<<< 27.99 fps
          In the End, I cannot express how truly grateful I am for all the assistance you've provided over the past two weeks. Your patience and dedication throughout the entire process have been remarkable. Thanks to your consistent help, everything is finally working perfectly, and I am incredibly appreciative of your efforts.
          Once again, thank you so much for your unwavering support and understanding.
            veye_xumm @Otca
            @otca You are welcome.
            I just tested it on my side with the Orin NX 8G version (P3767-0001), and both camera channels are working fine.
            This issue is a bit strange.
            Do you have any other cameras? Could you check if the cam1 on your board is functioning properly?
            • O Offline
              Otca @veye_xumm
              @veye_xumm Sure, I'll Check it.
              would mind helping me for getting Max FPS please?
              export WIDTH=1920
              export HEIGHT=1080
              export FPS=67
              <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 30.00 fps
              According to Veye Wiki, I can get 67 frames per second.
              Would you please tell me what should I do in addition to get the highest FPS?
              Thanks
              • O Offline
                Otca @Otca
                @otca Solved:
                ./mv_mipi_i2c.sh -r -f roi -b 9
                ./mv_mipi_i2c.sh -w -f roi -p1 0 -p2 0 -p3 1920 -p4 1080 -b 9
                ./mv_mipi_i2c.sh -r -f maxfps -b 9
                ./mv_mipi_i2c.sh -r -f fps -b 9
                ./mv_mipi_i2c.sh -w -f fps -p1 67 -b 9
                • V Offline
                  vitob
                  Ok, I have the same mvcam imx296m with adp-mv1 adapter connected to Orin nx 16GB board from seeed studio.
                  I used overlay dtbo loading method. The ‘sudo insmod veye_mvcam.ko’ ran w/o error returning.
                  But I got these errors checking ‘dmesg| grep -i mvcam’:
                  What could be the reason? I tried both local build .ko and downloaded (latest version) .ko files. Same symptom.
                  My system is R36.3 Jetpack 6.0.
                  BTW, where does the tegra_camera.ko come from? I seem do not find place to compile it. Thanks.
                  • V Offline
                    vitob
                    Also, besides the tegra-camera.ko question, I noticed the v4l2-core/*.ko also different between nvidia_jetson_veye_bsp release tar ball and default *.ko in /lib/modules/$(uname -r)/kernel/drivers/media/v4l2-core/. How are these *.ko files are compiled in nvidia_jetson_veye_bsp.tar.gz and where are the source files?
                    sudo cp nvidia_jetson_veye_bsp/ko/$(uname -r)/upstream/*.ko /lib/modules/$(uname -r)/kernel/drivers/media/v4l2-core/ -f
                      veye_xumm @vitob
                      @vitob
                      I think the first thing you need to check is whether this baseboard from seed is compatible with the official nVidia carrier board and whether it uses the same dtb?
                        veye_xumm @vitob
                        @vitob Pls try to get version:
                        https://wiki.veye.cc/index.php/Mv_mipi_i2c.sh_user_guide#model
                        • V Offline
                          vitob @veye_xumm
                          nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c.sh -r -f model -b 0
                          model 0 not recognized
                          nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c.sh -r -f model -b 1
                          nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c_new.sh -r -f model -b 1
                          NOT SUPPORTED!
                          nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c_new.sh -r -f model -b 0
                          NOT SUPPORTED!
                          • V Offline
                            vitob @veye_xumm
                            @veye_xumm , let me confirm this, although I used sdkmanager to flash the board with nvidia native packages w/o issues.
                            • V Offline
                              vitob @vitob
                              @vitob said in NVidia Jetson Jetpack 6 support?:
                              In the meantime, can you help explain this question on tegra-camera.ko and v4l2-core/*.ko? Why they needs to be updated and where can I find the source code of them? Once updating them using the veye release .ko, will that affect other cameras (for example, I want to port/develop driver for another sensor myself)? Thanks.
                                veye_xumm @vitob
                                @vitob
                                Please use -b 9 or -b 10 as an argument.
                                https://wiki.veye.cc/index.php/I2c_bus_number_and_video_node
                                For i2c bus number, please refer to this link above.
                                  veye_xumm @vitob
                                  These driver changes add support for RAW8 RAW10 RAW12 data types on the one hand, and externally triggered modes on the other.
                                  Their code reference:
                                  https://github.com/veyeimaging/nvidia_jetson_veye_bsp/tree/master/kernel_patch_4_mv/l4t-r36.3
                                  Compile step by step reference::
                                  https://wiki.veye.cc/index.php/VEYE_CS_Camera_source_for_Jetson
                                  1 Reply Last reply Reply Quote 1
