    SOLVED CS-MIPI-SC132 got Internal data stream error on Xavier NX with Jetpack 5.1
    • R
      ryanclark last edited by
      Hello, I have an xavier nx devkit with jetpack 5.1.
      The kernel driver (with .sig) and dtb were installed as the wiki instructed, and the cam was successfully detected:
      When I was trying to test the cam with gstreamer, I got an Internal data stream error massage:
      New clock: GstSystemClock
      ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
      Additional debug info:
      gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
      Execution ended after 0:00:01.283335950
      Setting pipeline to READY ...
      Setting pipeline to NULL ...
      Freeing pipeline ...
      the command line I used was:
      gst-launch-1.0 v4l2src device=/dev/video0 ! "video/x-raw,format=(string)UYVY, width=(int)1080, height=(int)1280" ! nvvidconv ! "video/x-raw(memory:NVMM),format=(string)UYVY" ! nvoverlaysink sync=false
      Can anyone help me this out? Thank you!
      • R
        ryanclark @ryanclark last edited by
        @ryanclark said in CS-MIPI-SC132 got Internal data stream error on Xavier NX with Jetpack 5.1:
        I figured it out. It was my fault.
        The correct command line should be:
        gst-launch-1.0 v4l2src device=/dev/video0 ! "video/x-raw,format=(string)UYVY, width=(int)1280, height=(int)1080" ! nvvidconv ! "video/x-raw(memory:NVMM),format=(string)I420" ! nvoverlaysink sync=false
          veye_xumm @ryanclark last edited by
          @ryanclark
          You took care of it yourself. that's great!
