    How to use the software trigger of the CSSC132
    cssc132agxxaviersoftware trigger
    3 Posts 2 Posters 3.2k Views 1 Watching
      lubertRoft
      Hello,
      I am struggling with the software trigger of the CSSC132 camera on the AGX Xavier and how to use it.
      I am taking the following steps:
      1. set the streammode to software trigger: ./cs_mipi_i2c.sh -w -f streammode -p1 3 -p2 0 -b 30
      2. reboot the camera: ./cs_mipi_i2c.sh -w -f sysreboot -p1 2 -b 30
      3. check if the correct streammode is chosen: ./cs_mipi_i2c.sh -r -f streammode -b 30
      4. trigger the software: ./cs_mipi_i2c.sh -w -f striggerone -b 30
      5. read from the sensor register: ./csipi_i2c.sh -r -f sreg -b 30
      But I can not get an image out of the camera. What steps do I have to do to get a picture using the software trigger?
      I know that the camera works as in free running mode I get a video stream using gstreamer.
      Regards
        veye_xumm @lubertRoft
        @lubertroft
        On the jetson platform, the mipi driver provided by Nvidia will report an error and cannot receive data if the frame rate is less than 5fps. I suggest you write a loop script, first implement a trigger larger than 5fps, and try to preview it with gstreamer.
          veye_xumm @veye_xumm
          @veye_xumm As the time is too long and there is no further feedback from the customer, I will mark this post as resolved.
