    SOLVED Does not working exposure time for manual mode in the CS-MIPI-SC132
    1222
    • D
      duvallee last edited by
      I'm testing the CS-MIPI-SC132 module for manual exposure and trigger in the Raspberry Pi 4B
      As follow, does not work in manual exposure.
      1. rebooting camera module
        $ /cs_mipi_i2c.sh -w -f sysreboot -p1 2
      2. set camera stream mode to Software Trigger
        $ ./cs_mipi_i2c.sh -w -f streammode -p1 3
      3. set exposure to manual
        $ ./cs_mipi_i2c.sh -w -f expmode -p1 1
      4. check while changing the exposure time, but does not applied exposure time.
      $ ./cs_mipi_i2c.sh -w -f metime -p1 10
      $ ./cs_mipi_i2c.sh -w -f striggerone
      $ ./cs_mipi_i2c.sh -w -f metime -p1 100
      $ ./cs_mipi_i2c.sh -w -f metime -p1 1000
      $ ./cs_mipi_i2c.sh -w -f metime -p1 10000
        veye_xumm @duvallee last edited by
        @duvallee
        1. Please read [expostate], this cmd shows the real exposure states.
        2. Please set meagain and medgain if needed.
        Look forward to your reply.
        • D
          I know the problem for metime. After setting the metime, it is applied after 2 frames.
          ex)
          ./cs_mipi_i2c.sh -w -f striggerone // old manual exposure time
          ./cs_mipi_i2c.sh -w -f striggerone // new manual exposure time (100)
          ./cs_mipi_i2c.sh -w -f striggerone // old manual exposure time (100)
          ./cs_mipi_i2c.sh -w -f striggerone // new manual exposure time (1000)
          Please let me know how to apply from the next frame after setting the metime.
          ex)
            @duvallee
            This feature is not supported now. Because the metime is set to isp, and the isp set to camera.
            I think maybe we can set to sensor directly.
            Does your application need to change the exposure time frequently and take effect immediately?
            • D
              Thanks for your quick reply.
              It may be ok in the free-run mode. But in trigger mode, only received one frame and it processed.
              Please tell me how to apply exposure time by directly using sensor register.
                @duvallee
                An upgrade of firmware will be needed. I will arrange the work, which is estimated to take a week to finish.
                  @duvallee
                  hi,
                  We have finished the upgrade I promised you last week.
                  Please check the version log here:
                  http://wiki.veye.cc/index.php/CS-MIPI-SC132_version_log
                  new trigger mode user manual here:
                  http://wiki.veye.cc/index.php/Camera_module_Trigger_Mode_manual#Configuration_of_exposure_and_gain_in_Trigger_mode
                    @duvallee
                    Hi, Have you test this upgrade for you?
                      As the time is too long and there is no further feedback from the customer, I will mark this post as resolved.
