• 0 Votes
    6k Views
    @robot ok
  • 请问如何初始化?
    18
    11k Views
    @wqeeqweqwwccsd 可以
  • 关于FPD-link3的同步问题
    @wqeeqweqwwccsd 你好,具体请参考下面这篇文章。连接方法在6.4 http://wiki.veye.cc/index.php/FPD_LINK_III_for_Jetson/zh#CS-FPD-CAM-IMX307.E7.9A.84.E5.90.8C.E6.AD.A5.E6.A8.A1.E5.BC.8F.EF.BC.8C.E8.BF.9E.E6.8E.A5.E5.88.B0Jetson_AGX_Xavier
  • Camera sync mode
    31
    27k Views
    @g-towboat It is really nice. @g-towboat said in Camera sync mode: One question do i need to set the fpdlink-settings after each reboot? ./fpdlink3_i2c_jetson.sh -f sync_init ..... This cmd need to set after each reboot. ./cs_mipi_i2c.sh -w -f streammode The camera can save streammode.
  • csimx307-fpdlink
    @wqeeqweqwwccsd 摄像头你采用同步模式了吗?感觉像是从摄像头没有得到同步信号。
  • 签名文件
    Moved
    38
    31k Views
    W
    @veye_xumm [image: 1616566229110-ss.png] 应该怎么输入address 的参数
  • Camera hotplug
    @g-towboat right.
  • I want to synchronize the two cameras in sync mode.
    9
    6k Views
    O
    @veye_xumm I understood that the synchronization signal is very accurate in an environment close to hardware. We will check the details from time to time.
  • camera I2C configuaration for sync mode
    @g-towboat hi, I think this might be the sync signal connection problem. We can discuss it on the topic you post here : http://forum.veye.cc/topic/18/camera-sync-mode/6
  • 遇到during i2c read probe错误
    @jlin 你好,看起来你这个驱动和dtb都是安装成功的。 只是现在启动过程中,并没有检测到摄像头。 你查一下摄像头的供电和连接情况是否正常?
