    Failure to run raspipreview after configuration i2c
    5 Posts 2 Posters 1.5k Views 1 Watching
    • N Offline
      Nathan Sinclair
      Here's the steps i followed to replicate issue:
      1. run ./enable_i2c_vc.sh
      2. Run ./camera_i2c_config
      3. Run a few commands on i2c (mirror mode)
      4. Run ./veye_raspipreview -t -1 -p '0,0,1920,1080'
      My system does not have an i2c line but is getting it from the csi cable. Camera and i2c enabled in raspi-config.
      Expected Result:
      Camera appears on screen
      Actual Result:
      before create camera com time out -1
      Hardare version: 9000c1
      mmal: mmal_component_create_core: could not find component 'vc.ril.rawcam'
      mmal: Failed to create camera component
      mmal: main: Failed to create camera component
      I did another test and worked out it's not likely to do with i2c, i reformatted sd card with a backed up image and it does the same thing as this.
      I can confirm that the camera IS working as I have another image which uses the VEYE_MPI-327 and it's working without issue,
      Here's the verbose log.
      veye_raspipreview Camera App v0.3.7
      Width 1920, Height 1080, filename (null)
      Time delay -1, Timelapse 0
      Link to latest frame enabled  no
      Full resolution preview No
      Capture method : Single capture
      Preview Yes, Full screen No
      Preview window 0,0,1920,1080
      Opacity 255
        veye_xumm @Nathan Sinclair
        @nathan-sinclair said in Failure to run raspipreview after configuration i2c:
        For bullseye system, it delete mmal component.
        Please refer to part 2:
        http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_for_Raspberry_Pi#About_piOS---Bullseye
        N 2 Replies Last reply Reply Quote 0
        • N Offline
          Nathan Sinclair @veye_xumm
          @veye_xumm We're using buster.
          • N Offline
            @veye_xumm were able to get it working. This is resolved for us.
              @nathan-sinclair Okay, you're great!
