    Problem cross-compiling
    5 Posts 2 Posters 1.7k Views 1 Watching
    • T Offline
      tj
      As the raspberry folks have released a new kernel (20210430), I'm trying to compile the drivers for a new camera of @MK. Following the instructions, at the last build command I get the error:
      make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- zImage modules dtbs -j2
      make[2]: *** No rule to make target 'arch/arm/boot/dts/overlays/csimx307-overlay.dtbo', needed by '__build'.  Stop.
      make[1]: *** [scripts/Makefile.build:496: arch/arm/boot/dts/overlays] Error 2
      What am I doing wrong? I've double checked that I did the four steps:
      • add driver sources
      • update Makefile and Kconfig
      • add dts files
      • change Makefile in dts folder
        veye_xumm @tj
        @tj
        @tj said in Problem cross-compiling:
        You should edit this file:
        arch\arm\boot\dts\overlays\Makefile
        veye327.dtbo \
        csimx307.dtbo \
        cssc132.dtbo \
        • T Offline
          tj @veye_xumm
          @veye_xumm Thanks for having a look. I had already added those lines. However I still get the error.
            veye_xumm @tj
            @tj please attach your Makefile let me take a look at it.
            • T Offline
              tj @veye_xumm
              @veye_xumm Thanks for the offer. While posting the Makefile I noticed I had -overlay.dtbo in the filenames. Compiling now.
