    imx327 missing from raspberrypi_v4l2 ver 5.10.63-
    • R
      Roger last edited by
      The two 5.10.63 releases are missing the imx327 versions of the driver, would it be possible to release these files as well?
      • R
        I emailed 'xumm' and was told
        "Please use veyecam2m.ko, this module support all 2M pixel VEYE-MIPI-* camera modules."
        So I believe the installation line:-
        sudo ./install_driver.sh [camera module]
        should use a [module name] of veyecam2m, which seems to install but as yet I don't have a fully working system motioneye or allsky system using it. I should find out soon...
          veye_xumm @Roger last edited by
          @roger
          Which rpi board do you use?
          • R
            I have the IMX327E boards. I am currently trying with bullseye 5.10.63.
            I installed the veyecam2m driver and updated the raspi-config to be able to select legacy support but I cannot get motioneye to work nor can I get the gstreamer tests on your readme on github for the v4l2. I see that the readme is out of date compared with the wiki but I still cannot get gstreamer to work.
            This all seems in order....
            pi@raspberrypi:~ $ dmesg |grep veye
            [ 11.775403] veyecam2m 10-003b: camera id is veyecam2m
            [ 11.778121] veyecam2m 10-003b: sensor is IMX327
            [ 11.778144] veyecam2m 10-003b: board type is TWO board
            [ 11.779786] veyecam2m 10-003b: veyecam2m camera probed
            @raspberrypi:~ $ ls /dev/video0
            /dev/video0
            pi@raspberrypi:~ $ v4l2-ctl --list-formats-ext
            ioctl: VIDIOC_ENUM_FMT
            Type: Video Capture
                [0]: 'UYVY' (UYVY 4:2:2)
                        Size: Discrete 1920x1080
            But gstreamer gives:-
            pi@raspberrypi:~ $ gst-launch-1.0 v4l2src num-buffers=1 device=/dev/video0 ! 'video/x-raw, format=(string)UYVY, width=1920,height=1080' ! jpegenc ! filesink location=test_image.jpg
            Pipeline is PREROLLED ...
            Setting Pipeline to PLAYING ...
            New clock: GstSystemClock
            Additional debug info:
            ../sys/v4l2/gstv4l2src.c(659): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
            Buffer pool activation failed
            Execution ended after 0:00:00.004531494
            Setting pipeline to NULL ...
            ../libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
            Freeing pipeline ...
              @roger
              Hi,The bullseye version of the Raspberry Pi changed the camera driver architecture to support libcamera. I am still working on the v4l2 driver support on the bullseye system as well.
              I suggest you to use the older version of piOS first.
              • R
                Hi, I tried the V4L2 driver with Buster which worked OK on a Pi4 4 GB then I tested Bullseye with the legacy mode and the same V4L2 driver ( veyecam2m ver 5.10.63) and that worked OK too.
                I was previously testing with a Pi 3A which I would like to work but that does seem to have a problem with the v4L2 driver with both OS's.
